Hi Im Billie - Fiberglass RV
Old 02-22-2015, 08:22 PM   #1
Indiana
Hi Im Billie
Hi I am Billie I'm from southern Indiana I bought a 1982 13ft. Scamp that was in need of some major love. I have fully gutted it and the next step is window replacement my problem is that they have discontinued the 82' side Windows. I stripped the ensolate as well due to major mold. So my next step is going to be replacing the front and back plexiglass and replacing the side Windows with plexiglass as well. I'm still debating what to do with the walls I thought about using a roll on bedliner coating and a friend mentioned using tar to seal it up and leave it a raw look then I need to replace the floor.
Billie Basham is offline   Reply With Quote
Old 02-22-2015, 10:57 PM   #2
Trailer: 1984 Dolphin
Wisconsin
Don't go with tar, it will get soft in the heat.
Ace57 is offline   Reply With Quote
Old 02-22-2015, 11:53 PM   #3
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Just because the original style windows are not made anymore, doesn't mean that you can not replace them with whatever new style that you wish, as you can cut the openings larger, or fiberglass the openings smaller. HEHR is one RV window manufacturer that I have used. You can cover the walls with Reflectix insulation rather easily, and cover that with marine headliner just like the new Scamps. Definitely do not use tar. Dave & Paula
Old 02-23-2015, 08:16 AM   #4
Hi Im Billie
Welcome, Billie!
Are the side windows the old-style square jalousies? If so, they're considered a prize. They give the best ventilation, even in the rain. Are you sure they can't be rebuilt with new gaskets and parts? Member Ian G. rebuilt the jalousie side windows on an old Boler and they came out beautifully. Look for his thread "It Started as a Kitchen Reno." In any case I would not use plexi on the side windows- you will want some ventilation in there. Worst case look for new windows in a slightly larger size and enlarge the opening to fit as Dave suggests.
Regarding the walls... Wish you hadn't taken out the Ensolite. It can almost always be saved. Absolutely do not use tar. A few people have used bedliner, but it only minimally addresses the three reasons for wall coverings: insulation, condensation, and sound-deadening. I agree with Dave that going with the current Scamp combination of marine hull liner (known in these parts as "rat fur") over Reflectix foil-bubble insulation is your best bet. Again, you should be able to pull up some useful threads here, but if not, ask and someone will point you in the right direction.
Best of luck with your rebuild. Take it one step at a time, resist the temptation to shortcuts, and don't feel like you have to have everything done to enjoy camping in it.
Old 02-23-2015, 10:20 AM   #5
Borden's Avatar
Name: Borden and Carole
If you have not completed the task at hand just a note:
Lexan is tougher than plexiglass and works much the same harder to break or scratch.
1978 Ontario made Boler
Old 02-23-2015, 12:13 PM   #6
1ATony's Avatar
Trailer: Dutchman
Massachusetts
Thanks for joining Billie
Tony
1aauto.com
Tow Mirrors - Trailer Hitch
1ATony is offline   Reply With Quote
Old 02-23-2015, 12:22 PM   #7
papa-t's Avatar
Glade Valley, North Carolina
Welcome Billie
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 02-24-2015, 04:40 PM   #8
Indiana
Thank you I didn't think about that
Old 02-24-2015, 04:43 PM   #9
Indiana
Thank you i didn't think about that
Old 02-24-2015, 08:16 PM   #10
Ian G.'s Avatar
Hi Billie and welcome
The advice give is very good
Here are a few links that may help you:
How Do You Like Your Eggs?
Proud Canadian Custom Boler Build
Proud Canadian Videos
