Hi,I'm Joe from Phoenix - Fiberglass RV
Old 01-07-2013, 08:42 AM   #1
Trailer: 1988 Casita 16ft
just bought a 1988 casita that's been sitting in a barn for the last 13 years. any input would be helpful . it's a 16 ft self-contained, just real dirty. Thanks for your time ,Joe
joeep is offline   Reply With Quote
Old 01-07-2013, 09:25 AM   #2
David Tilston's Avatar
Being in a barn, it should be OK. Have the bearings repacked. Make sure the lights work, and give it a good scrub. Maybe wash the cushion covers. Then go camping.
For the first outing, maybe just go for a couple of days. Any issues will make themselves obvious.
Old 01-07-2013, 09:28 AM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
I'd add replace the tires. They are good for 5 to 6 years regardless of usage. You will probably need a new battery, too. Costco / Walmart are a good source for deep cycle batteries.
I'd also verify that the brakes are working - you can check them out when the bearings are repacked,.
Old 01-07-2013, 10:05 AM   #4
Trailer: 28' Bigfoot Silver Cloud
Oak Park, IL
You might want to just camp in your own driveway the first night to check out all the systems. Look for evidence of mice and other rodents, too. They love dark places in barns! They will often chew through the wiring to make their nests, so you may find some lights don't work because of that. Corrosion may make some ground connections bad, too.
Old 01-07-2013, 10:06 AM   #5
Roger C H's Avatar
Smile That first camping trip
My reccomdation for the first trip is your driveway. That way if anything untoward happens or you forget some vital thing, you only have to go into the house.
Congratulations on your acquisiion.
Old 01-07-2013, 11:14 AM   #6
Mike Magee's Avatar
Trailer: Li'l Hauley
Barn storage is great, as long as there weren't chickens or cows or something in the barn too! Welcome, and congrats.
How to prepare Tofu
Step 2: grill some meat
Old 01-07-2013, 12:05 PM   #7
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
+3 or 4 on the driveway shakedown. The closer you simulate the actual conditions, amenities, and activities of camping, the more you'll learn/discover. Don't just sleep in it. Fill fresh water tank or hook up to house supply by hose. Hook up electrical if you desire to test 120V outlets or charge battery thru converter but use the shortest 12 or 10 guage grounded extension cord possible with an appropriate adapter for your trailer amperage rating and plug, and don't choose this moment to test your air conditioner for a long period of time. Pump water, heat water, cook food, wash dishes, take a shower if available. Convert and reconvent bed/dinettes, learn where to place the attendant apparatus of conversion. There are a hundred situations and surprises of towing, hitching and unhitching, and topographical peculiarities of site which you aren't yet mentally prepared to siimulate but the driveway is a very good place to start on ones attendant to "living" in the trailer.
jack
Old 01-07-2013, 12:12 PM   #8
Why not sleep in it?
Old 01-07-2013, 03:07 PM   #9
Welcome and congrats! Nice find. I am with the others in so far as the need for new tires and new battery and having the bearings repacked and brakes checked out. Also check the date stamp on the propane tank as well, as it may be past its prime as well.
Trying everything out at home before going out on the a road trip is the best way to avoid any surprises and remember to pack what you need. Getting the propane system checked out is also not a bad idea. If there are any spider web you may find your fridge or hot water tank will not work on propane and they may simple need to be serviced and cleaned out. A tiny little spider or web is all it takes to stop them from working correctly.
Have fun with it!
Old 01-07-2013, 04:49 PM   #10
Trailer: 77 Scamp 13
+1 on what Carol said and I would add wasp nests in the furnace chimney smell pretty funky when they burn.
After 13 years if it moves find out what lubricates it and apply. Holding tank valves for sewage dump, cupboard hinges, window mechanisms, latches,faucet handles. Think Tin Man from Wizard of Oz and lubricate all the joints. Avoid strain on moving parts that may still move but move harder than they should.
And enjoy what sounds like a good find.
Old 01-07-2013, 06:34 PM   #11
Hi Joe ... welcome to FiberglassRV!!!!!
Something that's been sitting in a barn for years is truly a find... you scored. Ditto to camping in your driveway, etc. How about some pictures of you and your new-to-you rollin' home? We love pictures here
Old 01-07-2013, 06:50 PM   #12
Thanks for all the info , I spent the whole day cleaning and still not done.
Old 01-12-2013, 07:29 PM   #13
Pam Garlow's Avatar
Trailer: U-Haul 1985
Welcome to the group! sounds like you'll have a great camper as soon as you've got all that cleaning and prep work done
Old 01-15-2013, 07:39 PM   #14
John & BJ S.'s Avatar
Name: John & BJ
Trailer: 2010 Scamp D19
Mesa AZ
Joe - if you get it checked out, consider coming out to the Quartzsite Egg gathering February 8-10. There will be lots of egg owners there (majority of them with Casitas) that can answer any questions.
John & BJ
Mesa, AZ
"We're not lost. We're just finding our way."
www.justfinding.blogspot.com
John & BJ S. is offline   Reply With Quote
Little Joe RangerBuff General Chat 4 04-24-2012 06:34 AM
Little Joe RangerBuff Problem Solving | Owners Helping Owners 10 03-06-2012 10:51 AM
Anybody Know About the Little Joe/Ponderosa? george oviatt Care and Feeding of Molded Fiberglass Trailers 8 10-25-2009 06:46 AM
Little Joe? Cathy P. General Chat 10 06-30-2009 06:19 PM
Little Joe Kevin K General Chat 12 09-16-2008 12:59 PM
