Hi I'm Kathleen - Page 3 - Fiberglass RV
Old 08-27-2013, 12:05 PM   #29
MC1
MC1's Avatar
Originally Posted by Kathleen M View Post
Thanks all for the advice so far. I'm feeling better about using the Forester as my TV. For the hitch, am I better to take it in to the dealer to get it installed? Otherwise, I'm sure my brother would have someone he uses (he's a excavating and concrete contractor so he tows equipment a lot, plus their camper).
We used a towing specialist here in our area. They have been in business for 40 years and have a rock solid reputation for getting it right the first time. Sorry, not sure how to help you since we are not familiar with the resources in your area.
Old 08-27-2013, 12:09 PM   #30
Originally Posted by Infogypsy View Post
Wondering myself if ALL water needs to be dumped before towing or just grey water tank (per scamp video suggestion)?
Water does not need to be dumped out of any of the tanks prior to towing BUT you will need to make sure you have stowed the trailer correctly to compensate for the extra water in the tanks. IE if you tow with water in the fresh water tanks or the grey water tanks which are located at the rear you will need to add some weight up and over or in front of the axle to balance the trailer to avoid sway issues. The black water tank is located just ahead of the axle so towing with it with some water in it is not a big stow changer.
Keep in mind that water weights 8.3lbs per US Gallon - which can add up fast to a lot of extra weight if the tanks are full. Thats 215lbs extra weight at the rear of the trailer if only the grey water tank is full. Another 99lbs if the fresh water tank is full. Most people try to avoid towing with water if possible as the added weight will impact MPG as well.
Old 08-27-2013, 12:14 PM   #31
Kathleen suspect you will be better off going to a hitch specialist. Subaru only started offering up their own hitch a few years ago so not many of their people are overly familiar with installing them as most come from the factory installed. Not to mention Subaru only offered a Class I hitch at first (that may have changed) and you should be getting a Class II . As others have said your Forester will tow the 13' just fine. Lots of us here tow with Subaru's and are pretty happy with them.
Edit: Forgot to mention that Subaru requires (as do many vehicle manufacturers) that you have brakes on any trailer you tow over 1000lbs and they *do not* recommend that you use a Weight Distribution hitch on their cars as they claim (when I asked) it may interfere with the safe operation of their AWD system. You should not need one on a 13' trailer regardless, but some folks like to recommend them anyways ;-)
Old 08-27-2013, 12:20 PM   #32
Trailer: 16' scamp standard side diner
Indiana
Price-wise Ziebart was $430.
Infogypsy is offline   Reply With Quote
Old 08-27-2013, 12:40 PM   #33
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
Kathleen,
I just sent you a private message. If you didn't get it please let me know.
Nancy
Nancy is offline   Reply With Quote
Old 08-27-2013, 01:28 PM   #34
I have had U-Haul install hitches twice on an Outback without a problem. They also installed the wiring harness and modular that needs to be added to the basic trailer wiring that Subaru supplies. You will need to have a break wire added from scratch as Subaru as with many other manufactures does not prewire the break wire at the factory.
Old 09-01-2013, 04:02 PM   #35
Trailer: Trying to decide
I went to the Minnesota State fair today and Scamp had a display with 5 trailers on display. They had the 13' both with and without the bathroom so I could see them side by side. I definitely want the one without the bathroom.
It made dealing with the huge crowds today worth it. I'm very happy and I talked with the reps about what options I want to go with, although I'm still considering used too.
Kathleen M is offline   Reply With Quote
Old 09-01-2013, 04:27 PM   #36
Mike Magee's Avatar
Trailer: Li'l Hauley
Glad you got to see some new ones like that! Scamps hold their value very well. They may depreciate a little faster in their first 2-3 years, then after that they decline in value verrrrry slowly. If you see a used one you think you might like, jump fast to look and perhaps purchase... or it will probably be gone the next day! And it can take a lot of looking and patient waiting for the right one to come up for sale within a reasonable distance. If you decide to spring for a new Scamp, late fall/winter is a great time to shop because they might have a few on hand (trying to keep the workers busy) that they would be willing to discount a bit during the slow season.
Those folding A frame trailers look so cool, and I like them also. But there's something to be said for not having to set up the walls (especially in wind or rain!) before using the trailer, and for having eye level storage cabinets (none of those in the A's). I talked to a couple in Yosemite with their Chalet this July, and they had to carry much of their stuff in boxes, milk crates, or other containers in the tow vehicle... and then haul them into the trailer at setup time and put them on the front seat or the floor. Not for me!!
Fortunately, FG eggs look cool also. And so much more practical. More tight from wind and the elements, less frame flex, more convenience.
Check around your area for places that sell and service cargo trailers, or a rental like U-Haul (one of their big main places, not necessarily the guy on the corner), for a good price on hitch installation.
How to prepare Tofu
Step 2: grill some meat
Old 09-02-2013, 01:07 AM   #37
Night Sailor's Avatar
Connecticut
I drove a 2008 Forester company provided car for several years and picked out of a large list that I test drove. I was very impressed with it and even bought a second set of rims with studded snow tires. It was the best 4 wheel drive vehicle I've ever driven. I owed several trailers, one 500 lb w/o brakes and one quiet a bit heavier--also without brakes for short distances. It handled the weight well and I would have gotten trailer brakes if circumstances had not changed.
If you try it I think you will be happy with it as a TV and agree with the other comments about adding trailer brakes--always ago of idea with alight weight TV. Good luck to you.
Old 09-02-2013, 01:09 AM   #38
Connecticut
I had my hitch put on by Ziebart. Recommend dealer instead. Forrester was apparently hard to hitch. Took them four hours and had to take it back after first tow to lower bar and raise connector.
I put mine on myself. I can remember how long it took. No more than 2 hours. A 2008 Forester. I buy most of my stuff from eTrailer.com and read the reviews. Sometimes I research there and buy in eBay.
