Hi, I'm new and getting a 16' Scamp in July & questions - Page 3 - Fiberglass RV
Old 02-04-2017, 09:44 PM   #29
North Dakota
I agree with others who said to stay in the area at least one night to check things out. There is a nice resort nearby. It's called Ruttger's Pine Mountain.
Ruttger's Pine Mountain Camping Resort and Pine Mountain Cabins
Be sure to ask for a tour of the factory. You'll learn much about your camper. There is a good restaurant just down the road to the South near the Cenex gas station. If you didn't get the microwave...good! Too expensive. Get your own but ask for the brackets they use to secure it down. They want about $250 and your can get one yourself for about $75. Fleet Farm stores have good prices. Magic Chef has a good one.
Gene Masse is offline   Reply With Quote
Old 02-05-2017, 05:51 PM   #30
Originally Posted by David B. View Post
Welcome Alice. One thing I had difficulty with when picking up our new Lil Snoozy 2000 miles away from Arizona, was getting license plates. I could get transportation plates, but they were only good for a few days, so no camping for us, as it took 3 days just to drive it back here.
Dave & Paula
When we bought our motorhome in AZ we got at least a 30 day temporary with it. Most places give you 30-60 days because it takes that long to get the title done, especially if there's a loan. When we bought our Casita in TX we paid cash and still the title had to be sent. Again we had at least 30 days on it.
Old 02-05-2017, 06:01 PM   #31
Originally Posted by AliceGardner View Post
Hi Everyone,
I'm new to RVing but have only about a year until retirement, so I'm launching on a big learning curve to get up to speed on everything I need to learn. I've ordered a 16' Scamp and will go get it in MN in July (I live in CA) and then do some camping in the Tetons on the way home.
The first thing I need to know is when I go to MN, what things do I need to bring with me to make my Scamp immediately usable. I'm not talking about kitchen & camping stuff. I'll be bringing my whole pre-RV camping kit. What I need to know is what things are particular to Scamp RV camping that Scamp won't give me, like aids to hitching up & unhitching in the Tetons, dumping for the first time, hoses for filling with water, and stuff like that. I'm close to being a complete newbie at those things. Wow, there's a lot to learn.
I just had the correct hitch installed at U-haul, along with the brake controller. Next I guess I need a transmission cooler on my 2000 4Runner, right? Any advice on which one?
Thanks ahead of time,
Alice
You might not need a transmission cooler. Check with vehicle manufacturer for your need. Don't ask the person that will install it as they would say yes just to make money. We have never added one and we've pulled with 3 different vehicles. One vehicle was a 2002 4.2L 6 cyl in a Chevrolet Trailblazer. Walmart is a great place to buy a lot of RV stuff. Make sure to get some toilet chemicals and preferably without formaldehyde. Many places do not allow it in their septics. I like the drop ins as they are easy and don't ever spill. Camping World has everything you need also. If you are not a member it is worth the cost. Being a member of Good Sam makes you a Camping World member for your discounts and they have a lot of great benefits like real good tow service, etc. Not all tow services will tow your vehicle and trailer separate. Check all this out. You are smart to start way ahead of time.
Old 02-09-2017, 09:39 AM   #32
Trailer: Escape Trailer
Lots to learn from this thread for another newbie
disneydoc is offline   Reply With Quote
Old 02-09-2017, 11:21 AM   #33
Trailer: NotYet
Ohio
Great List (and I copied it and then added a few items).
Things You Might Need When Picking Up a Travel Trailer for the 1irst time.
Note the first item (deep socket for removing spare tire) as it might be the one and only thing that is unique to Scamps.
Or just throw the trailer spare tire in your tug.
That way you know you can use it when you have a flat.
Tier-One
Tier-One includes priority tools and supplies that you should not leave home without.
You should know how to safely use them, or have someone available who does.
Running Gear:
Proper tools to change tires. Check beforehand
(Note Scamp needs deep socket to remove spare [from spare tire mount], but regular socket is OK for mounting wheels to hubs on axle.)
Air compressor (12volt type [unless you have access to an operable 120volt generator]) and tire pressure gauge
Jumper cables of the appropriate length
Spare hitch pin(s) and clips
Electrical:
Various voltage adapters (15 to 30, maybe 50 to 30, 15 amp extension cord with adapter to 30 plug and/or 30 amp extension)
Multi-meter or 12 VDC and 120 VAC testers (also surge suppressor or better is recommended).
Spare wire (10 and 14 g), crimp connectors, wire nuts
Fuses
Bulbs (tug and trailer, inside and outside).
Wire cutter / crimp / strip tool
Wire ties
Plumbing:
Sewer hose extension and fittings (black water might require a 45 degree elbow to fit on a different hose)
Water heater drain plug socket
One or two drinking water Hoses with spare washers
Pressure regulator (limiter)
Container for lugging drinking water, look for one with wheels, (esp. if you only carry one hose).
Assorted sizes of Hose Clamps
Multi-purpose:
Adjustable wrenches, channel lock pliers, crescent wrench, needle nose and vice grip pliers (sized to the gear on your rig).
Small hack saw
Phillips and flat screwdrivers, also torx if needed.
Duct tape and or Gorilla tape
Electrical tape
Butyl tape
Spare rivets and rivet gun
Emery cloth and small wire brush
JB Weld
3M 4200 Marine caulk and gloves to protect hands as needed.
Bailing wire
Plastic or Nitrile disposable gloves
Mechanics type work gloves
Any specialty tools or attachments required for your particular towing rig.
Owner’s manuals with parts lists.
Tier-Two
Tier-Two includes tool you might be able to get by without, but they come in handy or are required less frequently. Tier-Two tools are recommended when full timing or boondocking when ready access to stores or repair facilities is not expected. Some of these items are so lightweight that there really is no reason not to carry them.
Spare bearing and seal set with cotter pins. Bearing pre-packed with grease and sealed in baggie works well.
Tire plug repair kit
Metric and SAE Socket Set with extensions and appropriate adapters (1/4 inch to 3/8 inch drive, 3/8 inch to 1/2 inch drive.
Battery hydrometer
Torque Wrench
Hammer with claw or Axe–hammer and small crowbar
Electric screwdriver / drill and bits
Grease gun if you have “bearing buddies”
Can of WD-40, and silicon spray (with spray tube)
Chain quick links and shackles
Silicon Dielectric grease
Assorted bolts, screws, etc.
Sections of replacement hose(s)
TFE paste and Thread Seal Tape
Soldering iron with solder and applicable soldering flux
Small bubble level
Refrigerator flue brush and/or canned air.
RV antifreeze if you might unexpectedly experience sub-freezing temps.
apfixer is offline   Reply With Quote
Old 02-09-2017, 05:25 PM   #34
Trailer: Boler 13 ft / 31 ft Holiday Rambler
Maine
Hey Steve, don't know if your post was alittle tongue-in-cheek but if I carried all this, there would be no room for food, cloths, and real camping stuff. I would need a 3/4 ton truck to tow my boler,1300
CO | 2016, July 24th - July 29th Durango Colorado USA Thom Rowland Rallies, Get-togethers, Molded Meets (Archive) 25 07-26-2016 10:30 PM
WY | 2013, July 14-18: Yellowstone in July Wallo Rallies, Get-togethers, Molded Meets (Archive) 14 06-01-2013 07:23 PM
AB | July 2011 PRAIRIE EGG Gathering (3rd weekend in July) John J. M Rallies, Get-togethers, Molded Meets (Archive) 12 07-12-2012 09:42 PM
Impromptu gathering MI, July 28 & 29 Roy in TO Rallies, Get-togethers, Molded Meets (Archive) 5 08-09-2010 06:01 PM
