Hi, Rebecca here - Fiberglass RV
Old 03-28-2016, 02:42 PM   #1
Kansas
Hi, Rebecca here
I'm looking for a trailer that I can pull with my '08 Subaru Outback (manual says for automatic transmission max weight with brakes is 2700 lbs, long uphill for over 5 miles at 104 degrees F is 1350 lbs. I will browse other threads but I think this is pretty limiting... plus I'm wondering whether I should buy anything based on my Subaru... maybe I should go ahead and look at different cars...
Rebecca3 is offline   Reply With Quote
Old 03-28-2016, 03:04 PM   #2
Mike Magee's Avatar
Trailer: Li'l Hauley
Your Subaru is also limited by a maximum hitch weight of 200 lbs. From a practical standpoint I feel you should stick to a 13' egg, like Scamp or Casita. Some other folks have towed successfully with Subarus. Occasional trips, you should be fine. But if you want to tow on frequent, extensive trips you might do better with a different tug, because the towing can take its toll in wear and tear when you tow close to the max.
5-mile-long uphill grades can be found in the Rockies, but the 105* temp is unlikely there.
How to prepare Tofu
Step 2: grill some meat
Old 03-28-2016, 03:09 PM   #3
Kansas
Thanks, Mike. I'm also tall, so I'm not sure a Scamp or Casita will be comfortable for me either (nearly 6 ft.)
Old 03-28-2016, 05:52 PM   #4
Trailer: Burro
Burros are good for 6ft folk
Hi,
My hubby is 6'1" and has no problem with our Burro.
gbeever is offline   Reply With Quote
Old 03-28-2016, 06:43 PM   #5
Kansas
OK! Thanks, gbeever
Old 03-28-2016, 08:48 PM   #6
Newer Scamps (2007 and later) are taller inside, about 6' 2".
Old 03-28-2016, 08:57 PM   #7
Gilda's Avatar
Trailer: 2011 Scamp 13'
We pull our 13' basic Scamp with a 2008 manual Subaru Legacy sedan. The only problems are 1) that the after-market hitch stem can drag when we go over speed bumps or on certain steeply-cut drive-ways and 2) the box for the trailer brake sticks out a bit in the limited space to the left of the steering wheel thereby getting in the way of my knee ( I am 5'4"). We are just careful to go slowly or at an angle over bumps or driveways.
We had the car before we had any idea that we would be getting a trailer. Our mechanic says the wear and tear on our vehicle is NOT impacted by towing the trailer partially because we drive conservatively and infrequently. We LOVE our Subaru and will not hesitate to get another although it might be a Forester or Outback. I think their clearance is higher and the storage space is bigger. I am NOT a mechanic but I've heard some say that it makes little difference as to whether your car has a manual or automatic transmission when towing a small Scamp.
The Gleeful Glamper
Gilda (Jill-da)
Old 03-28-2016, 09:26 PM   #8
Kansas
Thanks Jon and Gilda.
Question: To move fast on something (if something pops up that's good), I'd have to buy before I have my car outfitted to tow! Any suggestions about this? Right now I have a u-haul trailer hitch for a bike rack on it. Fly to see it, buy it, fly home, get the car outfitted, drive to pick it up?
Old 03-28-2016, 09:35 PM   #9
KenjiFox's Avatar
Few more bits of info;
The newer Scamps are taller as mentioned, but this only applies to 13 foot units. The 16's were always taller. My 86 16 foot is.
You shouldn't have any issue with a 13 foot fiberglass trailer and your current vehicle. That said, do be careful about the tongue weight on it. Since it is a unibody vehicle without a solid frame this is particularly important.
As for the weight of the trailer and the wind resistance, the car doesn't know you are towing anything. Think of it like always driving up hill. If you can currently go up steep hills without temps rising or other issues then it will not be any different while towing.
Depending on what you need the trailer to do, and what kind of camping you intend, you could even get a 16 foot and still stay within the weight limits. The wind resistance of a 16 foot isn't that much higher than a 13 as the basic profile is almost the same. Not so much with the uphill at 105F stipulation, but in that case just go up the hill slower.
If you need space more than function the larger trailer could be used like a large hard wall tent.
You could just as easily put too much into a 13 and go over the limit too. So there are multiple factors to consider.
TLDR;
You should be perfectly fine with any 13 foot fiberglass trailer and your current tow vehicle, so long as you are mindful of the weight and its position inside of the trailer.
Put the heaviest stuff directly in the vehicle.
KenjiFox is offline   Reply With Quote
Old 03-28-2016, 09:42 PM   #10
KenjiFox's Avatar
Sorry I didn't include my input to this in my last post, it was being written while you were posting.
The hitch U-Haul installed will likely be perfectly sufficient for pulling a 13 foot egg. You will need a brake control installed. Make sure to ask for a proportional controller NOT a time based one. Some of the 13 foot eggs out there may not have electric brakes. In this case I would factor that into the cost and add them ASAP. You could tow it without them being very careful about stopping distance and avoiding sway. The thing is, the closer you are to your vehicles weight limit, the more important those trailer brakes become. Stopping is more important than going.
You could drive to buy it, then immediately drive to the nearest trailer supply or U-Haul to have the brake control and wiring harness installed.
Of course, you could have those things installed now before you find the trailer.
I would think it would be a better idea to drive to go buy the trailer rather than fly, so long as the person selling it is decent about showing you the thing before you get there.
If cost is no issue though, that's up to you. Most folks will be cool and not sell it out from under you when they know for sure you are driving over to get it.
Old 03-29-2016, 02:48 AM   #11
OneOleMan's Avatar
Trailer: Escape 17B Sold 5/2016
Rebecca3, I was driving a Forester when I started looking for a trailer and it didn't take long to fully understand the limitations of that fine car. I ended up ordering the cart I wanted then looked for the horse that could pull it.
Pat
Life is Good
When "Escaping Reality" Sold 5/2016
2012 4Runner Ltd
OneOleMan is offline   Reply With Quote
Old 03-29-2016, 09:22 AM   #12
Gilda's Avatar
'Sorry, 'just a note to add to your angst... It took a full day and a half to install our hitch with brake system after a week wait to get an appointment. In addition, they he forgot to connect the back-up light wires! We later found out that our installer had been fired. If you have your hitch modifications done at home with a trusted source you can easily go back to them if there is any need. One does need to factor in unforeseen complications.
The Gleeful Glamper
Gilda (Jill-da)
Old 03-29-2016, 10:30 AM   #13
Dbybe's Avatar
Trailer: Happier Camper HC1 pulled with a 2011 Subaru Outback 4cyl CVT
Hi, Rebecca here
I am 6'5" and we purchased a Happier Camper HC1. (Happiercamper.com) The bed is a bit longer but I still have to sleep a little on the diagonal. For that reason we make up a bed at the front of the trailer for my wife. (Easy to do with all of the modules). The height inside is 6'1" so I have to bend my head a little when standing. I expected this and figured that would be the case with any 13 footer. We tow with the 4 cyl Outback and CVT. We are under the 200 lb. tongue weight, but have not weighed the total yet, but the trailer tracks very well. I have towed about 5000 miles now with no problems, but not on long hot climbs yet. I am shopping for a transmission cooler install presently. The long hot Sacramento summer is coming up.
As far as purchase price, there are not so many on the road so it will likely be impossible to find a used one. We loved the trailer so bit the bullet and went ahead and got it.
Don
Sacramento
Don
Sacramento, California
Dbybe is offline   Reply With Quote
Old 03-29-2016, 10:33 AM   #14
Kansas
Thanks, Don. Have you had any other fiberglass campers to compare it with? I'll take a look at these.
It's here, it's here, it's here!!! melissab General Chat 30 09-24-2015 08:35 PM
Rebecca - Just Starting Out rebecca m General Chat 3 10-27-2007 08:51 PM
Here are three minor mods Barbara Gardin Modifications, Alterations and Updates 7 11-29-2005 10:50 PM
Someone here might need a project... Lizbeth General Chat 15 11-14-2005 02:04 PM
What happened(In the dark here) Kev&Melis B. General Chat 3 11-13-2005 09:09 AM
