I need help - Fiberglass RV
Old 04-07-2014, 11:30 AM   #1
I need help
Hi I have a 1980 big foot trailer the fa7912 hydro flame furnace is given me trouble.It lights goes one full cycle then the pilot light goes out help what could it be.
Lizy is offline   Reply With Quote
Old 04-07-2014, 12:04 PM   #2
Trailer: former class c now an egg hunter
Ummm spiders?
Is there an adjustment....like lighters have?
reetired is offline   Reply With Quote
Old 04-07-2014, 12:18 PM   #3
If there is an inspection plate, look to see if there is any water inside the combustion chamber.
Old 04-07-2014, 01:28 PM   #4
That problem is typical of a defective thermocouple or flame safety valve. Happens all the time with water heaters.
if you are lighting it the first time with a match, be sure that the thermocouple is in the pilot flame.
Old 04-07-2014, 02:06 PM   #5
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
I'm not exactly sure what you mean by "one full cycle", but:
Do you have the owner's manual? If not, here's a link to the correct manual.
Do check out and adhere to starting sequences described therein. That furnace is most particular and will not function unless they're strictly followed.
Good luck!
Old 04-07-2014, 02:29 PM   #6
It you manually light a pilot with a match, the match can heat the thermocouple causing the valve to latch when turned to run. But, when the furnace cycles OFF, either if there is no working pilot or it isn't impinging the thermocouple, the pilot safety gas valve will release.
This is a reason why match light water heaters do a single cycle and then don't relight.
Old 04-07-2014, 03:05 PM   #7
What I mean by full cycle is I set temp on the thermostat it gets to that temp as it is cooling down the pilot light goes out.
Old 04-07-2014, 03:37 PM   #8
What may be happening is that the furnace flame keeps the thermocouple hot, but when it turns off the pilot is not hitting the thermocouple enough and it releases the safety valve, shutting off everything. Check to see if the thermocouple probe is in the center of the pilot flame.
Old 04-07-2014, 04:01 PM   #9
I looked at the manual that Francesca posted above and it appears that furnace is available with and without a pilot. Does yours require pushing the igniter button to light or is it automatic. Is the last letter of the model number a D or a P?
Old 04-07-2014, 05:09 PM   #10
Found another source that gives general troubleshooting tips covering many furnaces including this one. Here are the possible causes they list for the symptom you describe:
PILOT FAILS TO IGNITE OR STAY LIT
Plugged pilot orifice ---------Clean or replace pilot orifice.
Electrode out of adjustment ---------Adjust electrode to furnace’s specifications.
Pilot tube defective -------Replace tube.
Piezo sparker defective ---------------Replace sparker
Defective thermocouple -------------Replace thermocouple.
Defective valve--------------------Replace valve.
Vent kit not sealed ----Seal vent where it meets with the furnace.*
MICA window missing------------Replace MICA
Combustion air hose plugged or collapsed-----Replace combustion hose
Water in propane ----------Add alcohol to the propane bottles.*
Burner plate gasket or --------Replace gaskets
pilot gasket not sealed
Old 04-07-2014, 06:04 PM   #11
Need help
It has pushing igniter model is fa -7912 PF
Old 04-07-2014, 06:19 PM   #12
papa-t's Avatar
Glade Valley, North Carolina
Ummm also check for other critters like mud daubers. Mine on another unit would light and then go out. The tube was full of mud daubers. Just a suggestion.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
papa-t is offline   Reply With Quote
Old 04-07-2014, 06:48 PM   #13
Spiders are the worst. You can't see the web. Get a long pipe cleaner and clean. Try the cheap stuff first!
Old 04-07-2014, 06:49 PM   #14
All it takes is one tiny spender or a little web for the pilot to go out.
HELP!!! New to be 13’ Scamp owners. Need help with bed barcode Problem Solving | Owners Helping Owners 56 03-20-2014 09:49 AM
Need rear sliding window channel with flocking - need exact part number idiotsniff Problem Solving | Owners Helping Owners 16 06-27-2013 08:45 PM
Need Help with Carpet Removal on Trillium Jola & Liz S Care and Feeding of Molded Fiberglass Trailers 4 06-21-2009 01:17 PM
Need Help with Outside GFCI Recepticle Kevin A Problem Solving | Owners Helping Owners 4 06-09-2009 09:23 PM
Need Help with Locating VIN or S/N of Triple E Surfside sherrid Problem Solving | Owners Helping Owners 0 05-31-2009 01:21 PM
» Trailer Showcase
tbd
robz5
Pearl
Dick & Joanne
