Ideal tow vehicle for towing Scamp 19 - Page 5 - Fiberglass RV
Old 10-15-2016, 11:42 PM   #57
Trailer: Scamp 13 ft
Actually a number of the full size trucks get better gas milage than my 2011 V6 Frontier. Times are a changing. More power does not necessarily translate to a loss of gas milage these days.
I hope we all know that newer big trucks can get better gas mileage than older small trucks, Carol. But you only included part of my quotation ...... and not the ( lol ). That meant it was a bit of a joke. About tight spaces . . . . ( L O L )
DavidG is offline   Reply With Quote
Old 10-16-2016, 06:58 AM   #58
Off topic, but since we've beat this one to death, it probably doesn't matter...
Would someone explain the practice of inserting several rows of dashes before starting a post? I've observed it before but don't have a clue...
Old 10-16-2016, 08:16 AM   #59
True that! The problem is that more efficiency should not result in bigger trucks. The assumption seems to be that everyone would want a grotesquely oversized truck if only it got 30mpg.
Agree would be thrilled to have a truck with a smaller foot print with the same specs that would do the job its required for.
But the bigger is better phenomena is not restricted to the newer model trucks. Take a look at many of the compact cars! Many of the small car models that were made two decades ago and are still being sold today with the same name are much larger than the previous generation models of them. But at the same time parking spots are getting smaller. Go figure.
Funny enough The Pathfinder is an example of mid size vehicle that seems to have gone full swing on size. It originally was a fairly small SUV - then it got much bigger in size. In 2010 for example it was actually had the same foot print and mass as the Nissan truck. Mass wise the Pathfinder was actually larger than the truck.
Saw a new Pathfinder the other day and it totally redesigned and its smaller again. I assume its due to it have been switch from a truck based to a Unibody.
Old 10-16-2016, 09:10 AM   #60
Little Big Truck - We also have a 2012 Frontier V6 and it looks to me to be as large as the Titan. The Titan has a V8.
The Frontier gets almost the same fuel mileage as our V8 2007 Silverado.
Old 10-16-2016, 12:11 PM   #61
Jon, you may be referring to some of my posts, esp since your post was just below mine. I do it because sometimes it is hard on some sites to tell the post from the reply. I'm on some sites where you can put your reply before or after your reference to the last post. And on some, you can insert your replies to various questions or statements right into the (recopied) last post. Hard to tell which is which. On this fbRV site, most people hit the quote button so the quote is in a box, all separate and easy to tell when the reply starts. I also tend to use more indenting, spacing and full spelling and grammar, rather than , " Wat rv r u driving. ".
As I type this, there is my line of dashes separating our posts , but no box appears with the quote. (yet? ) DavidG in Fresno, Sonora
Old 10-16-2016, 03:30 PM   #62
Roy in TO's Avatar
If you look at the text you are quoting when replying it uses BBcode that is common on many forums, https://en.wikipedia.org/wiki/BBCode
The start of the quote says QUOTE followed by =username;postnumber all in square brackets,
the end of the quote says /QUOTE in square brackets.
not using the username and post number will give you a straight quote box.
Old 10-16-2016, 04:10 PM   #63
Paul O.'s Avatar
Trailer: '04 Scamp 19D, TV:Tacoma 4.0L 4door, SB
Also on the SOI forum that many of our Scampers frequent, the whole thing behaves very differently. It is a matter of getting used to it and sometimes takes a little bit of figuring. No big deal.
Old 10-16-2016, 04:40 PM   #64
Just wondering... as you say, no big deal.
I believe the quote boxes serve an important function- they allow the reader to look back at the full context of the quoted material. Statements sometimes get taken out of context and distorted.
Back to regular programming... how silly to think a discussion of tow vehicles is ever done!
Old 10-16-2016, 04:45 PM   #65
I believe the quote boxes serve an important function- they allow the reader to look back at the full context of the quoted material. Statements sometimes get taken out of context and distorted. Actually, there is nothing sacred about the quote box. It can be edited to say whatever you want. And attributed to the OP.
And that, is a misquote.
Old 10-16-2016, 04:50 PM   #66
It is, but when I click on the arrow, your misquote is exposed. Not so otherwise.
Quoting someone, in full or in part, without using the quote box is like quoting a source in a paper without a citation. It deprives the reader of the means to verify its accuracy and context.
And that is not a misquote.
Old 10-16-2016, 04:57 PM   #67
I always use the quote box, but I will edit it to the part I'm addressing. I find posts without the quote box can be quite confusing.
Your ideal towing vehicle for Scamp 13'? johnsoba Towing, Hitching, Axles and Running Gear 59 08-08-2014 01:14 AM
"ideal" trailer? Hazel in Sk General Chat 25 10-26-2011 08:58 PM
Ideal hitch height for Surfside Maui Gomez Towing, Hitching, Axles and Running Gear 2 09-14-2007 08:35 AM
The ideal wine for a FGRV? Andrew Gibbens General Chat 8 05-17-2006 09:19 PM
An ideal anode removal tool Legacy Posts Modifications, Alterations and Updates 4 10-28-2002 02:38 PM
