In need of a nice Fiberglass RV! - Fiberglass RV
Old 06-05-2017, 09:10 PM   #1
Trailer: none
Hi! I'm Frank in Georgia. I'm looking for my first ......well sort of second trailer. Years ago I purchased a nice lake front lot on Lake Oconee, GA. I purchased my first RV, a pop up from friends of my sister. They kept it in their garage and it looked like new. I figured I would occasionally take it on trips but mostly I wanted to keep it at the lake and stay there until I could afford to build a house. A year went by without finding the time to go to the lake. I finally went out there with my wife for New Years Eve. Opened it up, and found that it leaked and the entire inside was filled with black mold and rot! I never want a leaking anything again which explains my interest in a Fiberglass RV. Sorry if I got too wordy. Other than that I love restoring vintage cars, biking, and spending time with my college age son. Frank
Famous Frank is offline   Reply With Quote
Old 06-05-2017, 10:47 PM   #2
Civilguy's Avatar
Puget Sound, WA
Welcome to the forum Frank. I expect you'll find a lot of interesting information and discussions here.
- "Wag more, bark less." -
Old 06-06-2017, 03:27 AM   #3
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Welcome to FGRV Frank. Off hand, I would think any RV being closed up in a humid environment for a year would be subject to the same problems. Storing it at home and towing it for the camping trips would probably end that issue.
Borrego Dave is online now   Reply With Quote
Old 06-06-2017, 06:11 AM   #4
Carol and Mike's Avatar
Trailer: Oliver Elite II
Boerne, Texas
Welcome Frank. You'll find owners of all the different fiberglass brands here willing to answer questions and help. Mike
The Lonestar Oliver #135 | Ram 1500 5.7L
Carol and Mike is offline   Reply With Quote
Old 06-06-2017, 06:31 AM   #5
Trailer: 2013 Escape 19
I've seen several molded trailers pop up on Atlanta C/L in the last year. Just don't wait, launch immediately. I sold my last one in four hours. One to two days is typical for a good one at a realistic price. No time to wait until it is convenient, for the weekend, payday, or whatever.
A nice Scamp was listed for sale on Asheville C/L about a week ago. Gone in one day.
+100 To below. Leaving any trailer unattended for over a year = problems. As a minimum, invest in a relatively cheap carport to at least keep it out of the weather. Really, towing it home is by far the best option, running a dehumidifier, etc.
Old 06-06-2017, 07:09 AM   #6
Originally Posted by Famous Frank View Post
.... I never want a leaking anything again which explains my interest in a Fiberglass RV. ..
Good luck. I have been battling leaks off an on since I bought my fiberglass RV 19 months ago. Any cutout in the shell can leak, and will leak eventually. Knowing what I know now, I would never store my fiberglass camper remotely if it were outside, where I could not check on it almost every day. If your plan is to leave it at the lake property, I would put it under a good car port at the very least, and make sure it is is well ventilated, or use a dehumidifier.
But its also true that my Scamp is almost immeasurably better than the pop-up I had before it.
Old 06-06-2017, 08:04 AM   #7
I have to agree with Dave and Gordon. Everything is subject to leaks. Mold can grow even in the absence of leaks simply due to the humid climate. Everything requires attention and maintenance. Letting anything sit unattended for a year or more- even a cabin- is likely to produce some unpleasant surprises.
The advantage of a trailer over a cabin is you can bring it home with you and keep an eye on it. Second best, as Gordon suggests, is putting it under a covered structure and taking measures to reduce humidity inside: desiccant crystals, solar-powered vent fan, perhaps, or, if you have power, a dehumidifier (How do you drain it, Gordon?),... Being from Arizona I'm not an expert on humidity , but there are many old threads with lots of suggestions.
Most important, though, are regular inspections. If it's not a leak, a critter will take up residence, and if not that, then something else. If you can't check on it regularly yourself, perhaps you could arrange with someone local to check in once a month or so. Things will happen, and you want to catch them early.
Old 06-06-2017, 08:22 AM   #8
... or, if you have power, a dehumidifier (How do you drain it, Gordon?),... ...
Well if you must store it outdoors with a dehu where you can't tend to it.. drill a hole in the floor and run a hose. Holes in the wood floor are easy to patch later.
Old 06-06-2017, 08:38 AM   #9
I thought it might be something like that. I would want to run the hose far enough so that the water doesn't end up under the trailer. Hoses can also become an entry point for insects, so you'd want to protect the end in some way. We discovered that the hard way when ants invaded our Scamp icebox through the drain tube to get at a strawberry pie. The pie was a total loss.
I grew up in MD, so I actually do know a little about humidity. We did not have central A/C and ran dehumidifiers during the summer. Each one produced several gallons of water every day. Mom used it to water the garden.
Old 06-06-2017, 10:55 AM   #10
Not saying I did that.. just thats what I would do.. except that here in the humid southeast, so far I have done ok with the rain cover over the fantastic fan so I can leave that vent open, and the side jalousie windows open a little. And I open the door and run the fan sometimes on nice days. Also helps to remove the cushions, bed clothes, etc. when not using the camper for a week or two or more. Ventilation is great.
Old 06-06-2017, 04:28 PM   #11
Trailer: 2014 Parkliner
Alabama
Hello,
I have decided to sell my 2014 Parkliner as I have a 21' Bigfoot that has my name on it.
If you are interested in a loaded PL with all options let me know. I just put in two new deep cycle batteries (Interstate brand) and new load range D tires.
merflyer is offline   Reply With Quote
Old 06-06-2017, 06:06 PM   #12
Trailer: Parkliner 2013
Originally Posted by merflyer View Post
Hello,
Hi Darrell,
You should really have this notice as its own thread as it will be noticed by many more people than buried in another thread with a title that will attract folks that are selling (like you) rather than those who are looking. All that said, best of luck!
Bill Berry is offline   Reply With Quote
Old 06-07-2017, 11:07 AM   #13
Kai in Seattle's Avatar
OP, not too wordy at all, look at all the space they give us for even the most minimal of posts! And you can go a lot longer than that, too!
Paul and I feel for you! I agree with other posters here, frequent checks, using a carport, putting Dry-Z-Air or some other type of dehumidifactant inside, a dehumidifier, that kind of thing, really helps. Paul is out in Peanut at least every week and often every day (he reads out there and has coffee and a view down the neighborhood...it's his little man-cave)...no matter how sealed up, things happen. The best fort cannot stand without good vigilance.
BEST wishes.
Kai
(Kathleen near Renton)
Semper ubi sub ubi.
wanted nice used fiberglass camper in Ohio deeohcamper Wanted: Molded Fiberglass Travel Trailers 1 04-18-2012 08:33 AM
Still looking for a nice molded fiberglass camper in ohio deeohcamper Wanted: Molded Fiberglass Travel Trailers 3 03-28-2012 02:32 PM
WANTED: OH,TN,KY,PA nice fiberglass camper in excellent condition! deeohcamper Wanted: Molded Fiberglass Travel Trailers 0 01-03-2012 11:27 AM
Need a nice Casita or Scamp or ?? to go with new Vue BobGroh Wanted: Molded Fiberglass Travel Trailers 0 08-28-2008 08:12 PM
Looking for some NICE RIDES WITH FIBERGLASS TRAILERS KARL PROUDE General Chat 5 08-19-2006 10:29 PM
