in the Trill' family since the '70s - Fiberglass RV
Old 02-13-2013, 01:05 PM   #1
josh kobrin's Avatar
Trailer: Trillium 4500
Hey all, so glad I landed on your little gold mine. I just drug my family's Trillium 4500 out of the garage where it's been hiding since '92. It was responsible for quite a few childhood adventures, and I'm pretty excited to get a few more out of it.
So far the only thing replaced are the 25 year old Sears brand tires. Hard to let go of the white walls, but those aren't the kind of adventure I'm looking to have. Somehow no rodents discovered it, or at least left evidence. Though the padding and fabric are crusty and tired.
Biggie question: besides the obvious, what should I look for when shaking it down? Is there already a sticky hiding somewhere? And I'm getting it back on the road behind it's original tow vehicle, a '72 Bronco Half-cab.
Also, anyone have a closet door for sale?
josh kobrin is offline   Reply With Quote
Old 02-13-2013, 01:12 PM   #2
Josh, how lucky for you to find it in your own family garage!!!
It would be a good idea to change out your propane tank and battery before heading out as as well & check your wheel bearings and repack them. Try camping in the driveway before heading out - hook up water turn on the lights & fridge etc and see how it all works out.
Old 02-13-2013, 01:29 PM   #3
David Tilston's Avatar
Wow! Score! The only issue I see is a missing closet door. It's too bad you don't have it. The data sheet for the trailer is typically stuck to the inside of the closet door. Do you know what year it is? I would guess it is a 1977 Deluxe. The two 1978's that I have use a larger fridge and the window in the door opens, but that may have been options.
Something you may want to evaluate is the condition of the torsion axle. Does it look like it is sagging? The arms should be horizontal. Get the bearings inspected and repacked. It may be worth replacing the coupler.
Old 02-13-2013, 01:37 PM   #4
Larry C Hanson's Avatar
Old Trill
Hello,
Congrats getting the old rig back on the road.
Since the trailer has been in a garage probably
in pretty good shape. In addition to the previous
post, I would check to make sure the caulking around
the window frames is not cracked and deteriorated.
The old stuff usually eventually dries out and one
should take out the windows to install new caulking.
The roof vent is another potential problem. Same drill.
The foam on the cushions may be deteriorated.
Spend a night sleeping on them before you hit the
road to make sure they are OK.
Also, take a look at the mounting bolts that hold
the trailer body onto the frame. My '78 Trillium 1300
had one missing and several very rusty when I
bought it.
I am sure I am overlooking a few that some other owners
will point out.
Regards, Larry H
Old 02-13-2013, 02:44 PM   #5
I'm more interested in the Bronco! I have a '69 that I bought new, by '76 it was really rusty so I bought a new body from Ford in '77, and haven't put it together yet!! You probably don't have the rust issues in California like we do in the Northeast.
Old 02-13-2013, 06:00 PM   #6
Score!!
Ditto to Carol's post about checking and packing the wheel bearings... absolutely!
Welcome to FiberglassRV, we're glad you're here!
Old 02-14-2013, 12:10 PM   #7
Wow such a warm welcome, and thanks for the wise words!
Carol - Good tip on the propane tank and battery. Those just got bumped to the top of my list.
David - Attaching pics of the axles. Do I need to have an RV joint repack the bearings or can any mechanic do it?
Larry - Is it possible that the caulking around the windows has completely dried out and vanished? Having a hard time finding evidence of it. Best not to use silicone, yes? And I've got a foam pad that'll go on top of the bed foam, that is until I replace it all. Also good tip on the frame bolts, I'll crawl under and take a look.
Mary/Bob - Yeah, we're spoiled out here, just a touch of surface rust. Repainted twice but it's about due. It's actually the vehicle I learned to drive with when I was a little kid.
Donna -
Old 02-14-2013, 12:18 PM   #8
You have a slight upward angle to the axle. It will likely be fine for at least a few years, just keep the 13" wheels. What I am surprised to see is no brakes. You have the mounting flanges for the brakes, and should look into getting them. If you have brakes, then you also need a brake controller in you tow vehicle (TV). Is the electrical connection between the trailer and the TV a four pin straight connector? If so, your TV probably wont charge your trailer battery.
Do you know the year?
Old 02-14-2013, 01:15 PM   #9
Hi Josh,
On the window caulking it is hard to tell if you need
to redo it until you find it leaking on a rainy hight.
My first trillium (1972) had a leaky front window.
I did not even notice it until the lady I sold it to pointed
it out. She lived in a rainy area. Consequently, when
I got my '78 I redid all the windows just to be sure that
leaks would not be a problem. It is a time consuming
operation but surely not rocket science. Often, one
does not know there have been leaks until the windows
are out and the wood backing that the screws go into
are found to be dry rotted. If you get that far into it
there are other threads regarding re-caulking the windows.
Also, I would be happy to discuss it with you.
NO, NO SILICONE!!!!!!!
I made a sleeping pad to go over the cushions out of
a memory foam mattress pad complete with a cover.
The cover was fabricated using two regular home style
mattress pads custom sewn into a two sided cover by
the local upholstery shop with a zipper on one side.
Both sides are usable.
Have fun! Larry H
Old 02-14-2013, 02:15 PM   #10
Glad to see your into classic recycling. Have fun. I too am a Bronco Fan. I have a 1974 that I have owned since 1978.
Old 02-14-2013, 02:30 PM   #11
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Originally Posted by David Tilston View Post
.........What I am surprised to see is no brakes. You have the mounting flanges for the brakes, and should look into getting them......
Great suggestion. Brakes are surprisingly inexpensive. Example:
Electric Trailer Brake Assemblies at Trailer Parts Superstore
http://www.trailerpartsdepot.com/ite...c=0007&eq=&Tp=
10" brakes can be cheaper than 7" .
Old 02-14-2013, 02:39 PM   #12
[QUOTE=josh kobrin;362639 Do I need to have an RV joint repack the bearings or can any mechanic do it?
[/QUOTE]
Josh, you dont need an RV place to do them for you a mechanic can do it for you or you can do them yourself - lots of people here do them. They should be done every year or 12,000 miles which ever comes first.
Here is a video on .
Old 03-04-2013, 11:20 PM   #13
Hey all, sorry for the radio silence, been swamped with work and just now found time to visit the Trillium.
Two new questions:
Battery - Do the electricals below look normal? This is a shot of inside the bench next to the sink where I'm assuming a battery normally goes. But looks like it was removed at some point and never replaced. You can see black and white wires that look like they could theoretically go to positive and negative terminals, but the gauge looks a lot thinner than I've ever seen for a battery.
Table - Is it normally held to the wall with dowels? It looks to me like something that was added later on. And also that the two tabs under the table should slip into those two slots on the wall, but the dowels are keeping it from swinging into place.
Also including an amusing pic of some of the vintage packaged goods I found in it. Like I said, it's been sitting for a few years
Old 03-04-2013, 11:47 PM   #14
calindor's Avatar
Trailer: 19' 1977 BIGGAR
I love the flashlight! That needs to stay with the trailer
1977 19ft Biggar
calindor is offline   Reply With Quote
NEW Trill on ebay melissab General Chat 19 09-07-2011 10:49 PM
Holy 70s! 1976 orange classic Boler SherLynn Classified Archives 4 09-22-2009 04:13 AM
Dewey the Trill - Sold Brenda Novakovski General Chat 2 05-18-2008 11:22 AM
Early Trill Alistair Camelford General Chat 2 10-22-2006 10:31 AM
First Main Trip with Trill Chester Taje General Chat 0 12-31-1969 07:00 PM
