Introducing Nest Caravans - Page 10 - Fiberglass RV
Old 01-27-2014, 10:48 AM   #127
Robert Johans's Avatar
Trailer: Nest Caravans
Good morning...
Thanks for the comments. Keep 'em coming. We are paying close attention to everything said. We won't compromise on our intent to deliver quality, but nevertheless, since we're still in engineering, we will consider any good suggestion that provides a better product.
The Kinro windows are available with insulated glazing.
About the "moonroof": of course, we won't be offering a product that leaks, but keep in mind these things have been available and installed on automobiles for a long time, so we have high confidence they should work for us. If not, adios!
The Airstream 16' Sport is similarly sized/scaled to the Nest, but weighs 2860lbs. We're shooting for 2000...
The "step/kink" (joggle) at the waistline has not gone away, just not so easy to see in the posted image. This design has been defined as the preferred method of assembly by our fabricator. We have to trust the experts here.
Old 02-03-2014, 11:18 AM   #128
cramar's Avatar
Trailer: Currently researching
Your Nest looks very interesting. I'd certainly put it near the top of the list if I was ready for a new trailer. However, something looks a little "off" to me in the pictures. I think it is sitting too high off the ground and would look better if lower. My wife would probably ask if there is a ladder to climb in.
I'm just new to FG trailers and trying to find out what the market has available. I think if I was going to design a new trailer I would distinguish it with the best insulation in the industry. I like your floor, but I would do something unique in the whole unit. A double wall construction with a FG outer and inner layer with at least 2"-3" of spray foam between, plus energy-efficient windows. That way it will be easy to heat and cool with minimum energy, and useable in all climate conditions.
cramar is offline   Reply With Quote
Old 02-03-2014, 01:11 PM   #129
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
Based on your stated criteria, the Oliver has a lot of what you're looking for. You can see them here.
Oliver Travel Trailers
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 02-03-2014, 02:24 PM   #130
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
cramar. that is what Bigfoot does to some degree too. I think the thickness of insulation you suggest might be too much, as it would take away a lot of volume.
The problem with this construction is twofold. It costs more and is heavier. Weight especially is something that most try to avoid with lightweight moulded fiberglass trailers. Bigfoot for example, I believe to be a very well built unit, but almost everything they make now requires a big tow vehicle due to weight.
The Oliver is spec'd out quite nice, but I am just not a fan for the cost. The exterior to me looks awkward, and I am one that does not at all like the institutional look of stark white fiberglass interiors.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 02-03-2014, 02:36 PM   #131
cramar's Avatar
Originally Posted by Steve Outlaw View Post
Based on yor stated criteria, the Oliver has a lot of what you're looking for. You can see them here.
Real beautiful looking trailer too! But at 23 1/2' it is not in the same market segment as a Nest or smaller Escape. I image the Oliver is competition with the 21' Escape and even Airstream around that size.
Old 02-05-2014, 08:52 PM   #132
Trailer: currently shopping
The nest caravan looks interesting. It is a bit to high for my current budget but given a chance, I would love to own one.
luxecaravan is offline   Reply With Quote
Old 03-17-2014, 08:50 AM   #133
A new thread was created to specifically cover the process of the building of the moulds, and the new Nest Caravan.
Nest Caravans — Building a new FG trailer, step by step
2017 Escape 5.0 TA
Old 03-17-2014, 01:10 PM   #134
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Thanks, Jim!
Old 03-19-2014, 04:25 PM   #135
US
New from gopower just passing it along to Robert. I Didn't know if it would help out or not, but thought it was interesting. Sure love those Nest build photos! Cheers
"can be secured with fasteners through pre-cut eyelets or adhesively mounted to metal, rubber, fiberglass and plastic surfaces with parabolic bends of as much as 30 degrees."
http://gpelectric.com/files/gpelectr...Solar_Flex.pdf
Old 09-24-2014, 06:29 AM   #136
Trailer: small
State
It has been really fascinating to watch the progress of this build, and I am very impressed with the attention to detail. I think this is going to be a premium quality build, taking the smaller size to a new level.
One thing that is a must-have for my wife and me is a full-time bed that does not require crawling over each other. Is there any possibility of having an island-double-bed option in this camper?
Mr. W. is offline   Reply With Quote
Old 01-15-2015, 03:04 PM   #137
US
For Nest owners who don't want to go the portable thetford route, good info here on the portable composting route. Natures head brand covered.
Composting Toilet
Old 01-15-2015, 05:00 PM   #138
Ken infers that composting toilets could be interesting alternatives. True dat. But just to be clear, Nest will not be offering one as an option.
Old 01-16-2015, 10:36 AM   #139
Trailer: Currently shopping
Red face Nest Caravans
Very interesting and creative. Looks great for the high desert. Any breaks for ONDA members?
Youlanzhe is offline   Reply With Quote
Old 03-13-2015, 01:03 PM   #140
Roger C H's Avatar
Unhappy COMPOSITING TOILET
Composting Toilet
They tell you to dump the urine ON THE GROUND. I don't think this a good idea. I could do this with my Thetford which we only use for urine.
All Molded Caravans From the Land Down Under Donna D. General Chat 11 12-10-2012 02:40 PM
Caravans BAMA & Pachyderm Posse Rallies, Get-togethers, Molded Meets (Archive) 3 12-04-2012 04:00 PM
UK retro caravans Tom Trostel General Chat 4 06-28-2010 10:42 AM
willerby caravans,,need to know more lloyd cicetti General Chat 7 09-03-2008 07:20 PM
