Introducing Nest Caravans - Page 7 - Fiberglass RV
Old 12-17-2013, 09:35 PM   #85
Robert Johans's Avatar
Trailer: Nest Caravans
Ha! You guys are awesome!
As a matter of fact, David Is absolutely right. Though I'm not exactly sitting on my hands, while the real talent works on the refinements of our design, I spend the day wrestling with vendors. And reading the forum!
Incidentally, tomorrow we go through another design review. If all goes well, next month we should have CAD files complete. These will be translated into CNC files to guide the cutting of the plugs for the molds.
I am committed to delivering a spectacular product, and creating a successful business. Obviously, that includes nurturing a tight-knit, steadfast and respectful relationship with the FGRV community, and ultimately, our clients.
Old 12-17-2013, 09:51 PM   #86
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
So...will you be able to meet the January actual-built roll out date spoken about in the threadstarter ?
We begin the manufacturing process with the creation of patterns and molds within the next two weeks. If all goes according to plan, we should have prototypes built by end of January, 2014. Sales commence next spring.
Robert Johans
Old 12-17-2013, 10:20 PM   #87
When I opened this thread, we were on track... Then Bryan Thompson joined the design team and messed up our calendar. But his contribution to the process is so important that we are gladly willing to delay the schedule. Hold on to your hats!
Old 12-18-2013, 07:31 AM   #88
Vicki A.'s Avatar
Trailer: 2014 Escape 5.0 TA
Go get'um Robert!
Vicki A. is offline   Reply With Quote
Old 12-18-2013, 03:16 PM   #89
Alabama
Does the refrigerator vent to the outside? ... The NovaKool R3100 is an electric-only, compressor-style refrigerator and requires no outside venting.
Robert,
My question about outside venting for the electric-only refrigerator was more in regard to the additional heat load introduced into the cabin from the warm air coming off the condensor coil. That warm air coming off the condensor coil can help warm the cabin in cooler climates, saving your area heater some work, but it seems it would add more work for the A/C unit during hot summer months here in the South (when refrigerators have to work even harder to keep their contents cool). I know the NovaKool is small and efficient, and maybe it doesn't make enough difference to worry about in the long run, but it seems that having the option to vent the warm air coming off the refrigerator's condensor coil to the outside of the cabin would be a nice option when camping in warm (hot!) weather here in the South. Does that make sense? (I'm sure there are some engineers out there already looking up product specs and calculating thermal unit displacement x cabin volume / air turnover rate - or whatever! )
Dale
Old 12-18-2013, 08:23 PM   #90
Good question, Dale. Up here in the Northwest, I hadn't thought the heat from the compressor would be an issue. I'll check with NovaKool and see if they have any thoughts and/or suggestions.
Old 12-19-2013, 04:31 AM   #91
Trailer: 13 ft Boler 1986
Well Robert, there you have it. Everybody has an option they want, but that's just not possible and I fully expect you have done your home-work. For me, if I had the money, I would be watching your progress with anticipation. Seems well thought out to me. Good luck.
Bizzian
Vivian L is offline   Reply With Quote
Old 12-19-2013, 01:49 PM   #92
Dale,
According to my rep at NovaKool, the R3100 will "produce about 250-300 BTUs of heat about similar to that of a person at rest."
In the cooler climes up here, the subtle effects of the R3100 on the interior ambient temperature might be a good thing. But for those of you down south, perhaps we should try to incorporate a discreet vent of some kind.
Something for us to think over...
Old 12-19-2013, 09:47 PM   #93
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
If you've ever spent a hot sticky night in the South, you know that any BTU's produced by someone else nearby is too many.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is online now   Reply With Quote
Old 12-20-2013, 01:52 PM   #94
Sounds like the "Southern" model better have a twin beds option, Robert! ...
Old 12-20-2013, 05:46 PM   #95
Roger C H's Avatar
Smile Roger come lately
Just found this thread. Looks like an interesting concept. A few thoughts from my point of view.
Sleeping under windows can be cold.
Sleeping side to side requires the far person to climb over the near person when using the facility at night.
I wonder if the heavier glass construction required weighs more than the steel frame. I used to have an early fiberglass sailboat (Balboa 20) which had really thick walls to support its 400# swing keel.
Good luck in your endeavors.
Old 12-20-2013, 06:24 PM   #96
Hi Roger, thanks for your note.
Double-pane (thermal) windows will be an option. (Though, can't imagine not having windows around the bed. In fact, we're even toying with the concept of a retractable "skylight" for sleeping under the stars!)
We recognize that crawling over one another is a hassle, but our queen-size bed must be oriented as it is. This is a very common situation with compact trailers. Just ask folks with 13 footers!
The walls of our shell construction will not be much thicker than any other single hull configuration, though the infusion molding process provides more uniformity, strength and integrity. The floor, however, is a 1.875" thick combination of rigid materials, sandwiched between FG composite layers.
Old 12-22-2013, 08:55 AM   #97
MCDenny's Avatar
Trailer: Lil Snoozy
Robert, your new trailer looks like a smart move into a "higher quality" niche where your only competition is all shiny silver. If your actual product is as nicely done as your website you should have a winner.
We bought a Snoozy last year and certainly would have considered a Nest had it been available. There are obvious similarities to the Snoozy in size, layout, rear door, modern fg composite hull, etc. The rear door is great, I see no problem with campground layout and we can carry our bikes inside the trailer. The casette toilet is very easy to 'service'. Maybe yours is too. Did you consider molding a 3D hatch cover to fit the body profile but allow access to the casette tank?
Great idea to include a good 12v compressor fridge. I wish I'd done that instead of driving the cheapo dorm fridge with an inverter.
A must have for us was twin beds to avoid that midnight 'climb over'. I had to build that myself. When other campers check out the trailer they often say the layout (L configuration, one across, one lengthwise) is the best feature, I think because it is so rare in a little trailer and night time potty runs are so common. Check out the "about the trailer" link on our blog www.wanderingourway.wordpress.com
Again, best of luck.
MCDenny is offline   Reply With Quote
Old 12-22-2013, 09:00 AM   #98
cpaharley2008's Avatar
I loved my cassette toilet in my T@da, self contained water source and disposal. Easy to empty in a cg toilet and one can fill with antifreeze and use all winter. Vey versatile.
Jim
Never in doubt, often wrong
All Molded Caravans From the Land Down Under Donna D. General Chat 11 12-10-2012 02:40 PM
Caravans BAMA & Pachyderm Posse Rallies, Get-togethers, Molded Meets (Archive) 3 12-04-2012 04:00 PM
UK retro caravans Tom Trostel General Chat 4 06-28-2010 10:42 AM
willerby caravans,,need to know more lloyd cicetti General Chat 7 09-03-2008 07:20 PM
