Introducing Nest Caravans - Page 2 - Fiberglass RV
Old 10-27-2013, 05:40 PM   #21
I'm awaiting the first post about pulling out the fridge and shower and water tank, replacing the toilet with a porta-potti . . .
Old 10-27-2013, 05:53 PM   #22
It's amazing how these little trailer companies keep popping up. And each designer makes their own choices about what they think is important and what to leave out. For me, I like the overall design and rear entry. The 16" tires are great and the combined heater/hot water seems wonderful but I'll bet it adds a lot to the price. I'm ambivalent about the "unit body" and we'll have to see how it works out. But a little pull-out pot for the toilet and a tiny electric-only refrigerator? Those seem way out of line for a $30k investment. If I had that kind of money for a new trailer, I'd probably think a new Casita or Scamp gave me more of what I wanted and I'd go travel Europe on the extra $12k.
Terry G is offline   Reply With Quote
Old 10-27-2013, 06:12 PM   #23
Robert Johans's Avatar
Trailer: 1988 Scamp 13 ft and 1982 Perris Pacer 13 ft
Hello Glenn,
The refrigerator pushes in and mounts to the face frame of cabinet. Easy to pull out, if necessary.
Nope, the shower enclosure itself cannot be removed, but all of the associated plumbing is accessible. And since the "Curve" porta-potty comes standard, there's no toilet to possibly replace.
The queen-size mattress is constructed in two parts with a "hinge". Folding it over and removing a hatch allows access to the fresh water tank up front.
BTW, all of the furniture components are built with high-quality, laminated birch plywood. No MDF or composition wood boards.
Old 10-27-2013, 06:19 PM   #24
The truck camper folks have been using the 12v tundra fridge for a number of years. There is a lot of info at rv.net.
Does the nest have a wood or any wood product in the subfloor? Is there a drain system if water intrusion did get into and down to the floor? Thanks in advance.... the design looks great
Old 10-27-2013, 06:26 PM   #25
Originally Posted by Robert Johans View Post
Hello Glenn,
I should have used a smiley face. Seems like most of the posts on FGRV are people ripping out conveniences that came with the trailer and replacing them with holes.
baglo
Old 10-27-2013, 06:32 PM   #26
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
I like the Eriba Puck-reminiscent rounded vee nose. I like 60" wide bed but there the 6 footer+ who can stand up in this trailer is going to touch both sides. Be interesting to see how this "frameless" monocoque hull works out over time. I don't know what an average box tube frame for a 17' weighs; can somebody translate 75% weight eliminated into lbs.?
jack
Old 10-27-2013, 06:47 PM   #27
Hello Glenn,
I've read a few comments expressing concern about our "monocoque" chassis concept. Ours indeed is more of a hybrid set-up, with a steel frame up front and a load-bearing axle/suspension more or less amidship.
The monocoque design has been around for nearly 100 years, and is very prevalent within the aviation industry. In fact, our fiberglass shell manufacturer has been building planes for over fifteen years. I cannot tell you in this writing all of the specific engineering involved, by our builder assures us of its veracity. Rest assured, extensive testing will be done before we go to market.
As to our choice to feature a porta-potty, in fact, this was a decision suggested in a survey by a majority of FG trailer owners on this forum. The simplicity and elegance of the design award-winning "Curve" can't be beat. Whether it appeals to anyone outside our focus group remains to be seen.
And the NovaKool R3100 refrigerator may be small, but it's is arguably one of the best in the industry.
As we move forward, we will obviously learn a lot from our mistakes. We are in a good position to be flexible and make changes -- or offer options -- as necessary. No way we can be all things to all folks, but, with all due respect to our predecessors, we will endeavor to produce the highest quality molded fiberglass travel trailer in the industry.
http://en.wikipedia.org/wiki/Monocoq...nd_development
Old 10-27-2013, 06:53 PM   #28
Hi Ken,
There is no wood in the composite floor, but yes, there will be strategically placed "weep" holes, in case of possible leaks in the plumbing. Of course, that's never gonna happen!
Old 10-27-2013, 06:56 PM   #29
Rabbit,
The queen-sized bed is 60 x 78". So, if one is taller than 6' 6" it's gonna be tight!
Old 10-27-2013, 07:17 PM   #30
FTTRV's Avatar
Trailer: tp
The Nest is all real quality with hi end appliances and well thought out design. I like the back entry which gives you more room inside. It is a modern Compact Jr and Trails West.
Old 10-27-2013, 07:37 PM   #31
Jim Bennett's Avatar
Using a rear entry is definitely a huge advantage in layout, as it eliminates two corners to work with. Corners in any cabinet type layout or always awkward to make work.
The drawback for me is that most campsites are set up to have the outside living area off the passenger side, and often behind the trailer you are backed up near trees or something.
Like everything in life and moulded fiberglass trailers, there is always a compromise in some way or another.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 10-27-2013, 07:46 PM   #32
carlkeigley's Avatar
NE Oklahoma
There is a niche for just about everything.
Being different is a niche in itself.
I love how sleek it looks and I like the design.
Of course, my pic shows that I am definitely prejudice........LOL
http://www.fiberglassrv.com/forums/m...cture3955.html
Old 10-27-2013, 07:47 PM   #33
Robert, are there any of these built yet, and if so are there actual photos of the product?
Are there any thoughts or plans into the future for other models, maybe even a bit bigger one. I know for my wife (me too), a permanent bed, along with a decent sized dinette for two, is desired.
As mentioned above, I am really impressed with how things are sizing up with your trailer, and have a bunch of questions that I will likely fire at you in time, but for now will just let others take their turns.
And wood cabinetry for me is fantastic to hear. I have never been keen on the institutional moulded white look, though I know this is others preference.
You mention that you will build to suit, unlike the other guys. Not sure if you are aware, but Escape trailers has been doing this for a few years now.
2017 Escape 5.0 TA
Old 10-27-2013, 08:01 PM   #34
cpaharley2008's Avatar
Where is the shower mentioned?
Jim
Never in doubt, often wrong
Old 10-27-2013, 08:08 PM   #35
peterh's Avatar
Robert, I see a lot of your design aesthetic in the Nest. It won't appeal to all comers, but it does offer a cool and new vision of what a fiberglass trailer can be like. Very nice
Old 10-27-2013, 08:26 PM   #36
For shower, go to interior details, then scroll left and right arrows, then hover your pointer over the shower door icon.
I wonder if this cabinet was left out (circled), if it would allow for a side dinette to be able and sit and face each other. Me and the wife were also wondering about a side dinette.
Old 10-27-2013, 08:27 PM   #37
If you go to the Nest web page and click on the interior layout you will see the inside plans which have little blue arrows that you can click on - click on the tall door on the drivers side plan and it says "wet bath enclosure with porta potty".
I really luv the look of the Ramblewood stove top! Has move BTU's than my Wedgewood as well.
Old 10-27-2013, 10:04 PM   #38
U
Hello again, Jim.
Let's see how we make out with this first model before we come out with another!
Old 10-27-2013, 11:19 PM   #39
Beautiful inside and out! Well designed for a rear entry trailer.
Having owned a few rear entry trailers, I am not a fan of the type, however it does look nice, Maybe because of the large size.
At this price point I'd expect a real toilet ....and where's the shower?
Old 10-28-2013, 01:06 AM   #40
Paul Chet's Avatar
Trailer: 1986 U-Haul CT13 ft
Robert, while i have moved on to a vintage motor coach (but ... FIBERGLASS BODY!), this, like all of your work, is par excellence. i wish you only great success taking the fiberglass travel trailer to the next level.
Paul Chet is offline   Reply With Quote
All Molded Caravans From the Land Down Under Donna D. General Chat 11 12-10-2012 03:40 PM
Caravans BAMA & Pachyderm Posse Rallies, Get-togethers, Molded Meets (Archive) 3 12-04-2012 05:00 PM
UK retro caravans Tom Trostel General Chat 4 06-28-2010 10:42 AM
willerby caravans,,need to know more lloyd cicetti General Chat 7 09-03-2008 07:20 PM
