Looking at a Sunrader - Fiberglass RV
Old 01-14-2015, 08:03 PM   #1
Trailer: Currently Shopping
Talking Looking at a Sunrader
Hi Guys, Got the fiberglass RV fever..
Found a 1989 SunRader 21 ft with dinette in the rear. Just like I want it.
6 bolt floating rear axle, 6 bolt front. and looks clean.. 135k miles.
But it has a v6 efi engine, automatic trans with overdrive...
$8500
What is your opinion of this engine and transmission?? Worth the chance?
Haven't checked engine s/n to see if it's had the head gasket replaced.
Let me know.
Bill
willorwaybill is offline   Reply With Quote
Old 01-14-2015, 11:37 PM   #2
Borrego Dave's Avatar
Bob M, your number is called for the answer
Old 01-16-2015, 07:40 PM   #3
Trailer: Bigfoot
Everyone will have an opinion for you. MY personal opinion is run for cover. Probably THE only "bad" motor Toyota ever built. I have friends with built trucks & all have gotten rid of the 3.0, one downsized to a 22RET & several that swapped in the newer 3.4. You will run into some that swear their 3.0 has run 300K with no problems, but they are well known for HG problems. Think Fords reputation with the 6.0 diesel. The trans has a good history & generally not be the weak link. You might be lucky, but i'd try to get it at a price that WILL allow for engine work.
pete luchka is offline   Reply With Quote
Old 01-16-2015, 09:19 PM   #4
Bob Miller's Avatar
As mentioned, the 3.0 is the weak link in the driveline, followed by the transmission, especially if the owner tried to tow anything. In the motorhome the engine is working much harder than in the pick-up and performing routine maintenance is essential. The biggie is valve adjustment. As the valves wear they tighten up until there is no clearance and you get a burned #6 exhaust valve, quickly followed by others.
The bad news.... Valve adjustment uses shims and is about a $600 job and often is overlooked or done wrong. At 135k that is a high mileage engine and, without a lot of service records I would look elsewhere.
That said, Sunraders are the primo of all Toyota Motorhomes and nice ones with the V6 have sold as high as $18,000+ in the past year. But to repeat what Pete said, the VZ-E 3.0 V6 is Toyotas most problematic engine.
PM me for more info if desired.
1986 toyota sunrader rv rare 17' gas 4x4 turbo efi 5 spd ac 22r-tec ollcnv Classified Archives 31 04-23-2016 05:02 PM
MI: Toyota Sunrader Thomas G. Referrals: Molded Fiberglass Trailers 37 01-15-2016 10:06 AM
*~*~RARE For Sale: Toyota / Sunrader 4X4 22RE SR-5 Opt. checkursix Classified Archives 4 04-16-2015 07:03 PM
MI: Sunrader Mini Motorhome Thomas G. Referrals: Molded Fiberglass Trailers 9 04-03-2013 08:41 PM
MI: Sunrader Thomas G. Referrals: Molded Fiberglass Trailers 4 11-10-2012 04:01 PM
