m and m - Fiberglass RV
Old 01-28-2013, 09:14 PM   #1
Trailer: 1988 columbus coach van companion liberty
m and m
hi have been lurking for over a year but have almost finished my trailer on the inside ready to refinish the outside and be ready for this season
take a look 1988 columbus coach van companion 17' liberty
thanks for the great forum
m and m is offline   Reply With Quote
Old 01-29-2013, 03:30 AM   #2
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Hi Mike. That's a slick looking unit. I'm curious about the original interior. The registry pix combined with the Amerigo ancestry suggest that this trailer is a molded shell studded out and the frames bays insulated. Do you know how the skin was supported/reinforced originally. Did it have a combination of bulkheads and furnishings acting as beams or a "sticky" sandwich similar to current interior frame? Inquiring minds want to know.
Jack
Old 01-29-2013, 04:40 AM   #3
Hi Mike, welcome to FiberglassRV, we're glad you're here
WOW, you have done a TON of work. Thanks for adding the pictures and history in your trailer profile.
Old 01-29-2013, 06:18 AM   #4
Ian G.'s Avatar
Your trailer looks awesome, great work ... and welcome to the forum
Old 01-29-2013, 07:13 AM   #5
the shell had a stick frame, not as heavily built but it was there that all the cabinets hung on with fiberglass bat insulation. they where attached to 1/2 plywood fiberglassed into the shell about 12" up from the floor and another at the top of the sidewall the full perimeter and crossing the roof. the roof plywood was flat and had give up and let the roof sag down. the top side plywood is what i rested the mini trusses on to push the roof back up, held it there with props until after the foam was blown in. now the roof crowns up over 2 inches and is stong enough to support the ac with no problem.
the shell is being prepped now to be painted, going a light champagne with a real light silver accents
thanks for the comments
great to be here
Old 01-29-2013, 07:49 AM   #6
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
You did a fine job of fixing it up, Mike.
Looks cozy with all that spray foam.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 01-29-2013, 08:01 AM   #7
Trailer: uhaul, 84, 13CT
Massachusetts
pics
OK, what am I doing wrong? Why can't I see M and M's photos? mike
h.mike is offline   Reply With Quote
Old 01-29-2013, 08:35 AM   #8
bec
Trailer: Escape 15 A
can't see a thing either !
bec is offline   Reply With Quote
Old 01-29-2013, 08:36 AM   #9
Mike, click on the "Registry: My Trailer Profile" link at the bottom of their user profile. Their photos will all be displayed there.
2017 Escape 5.0 TA
Old 01-29-2013, 08:53 AM   #10
bec
Beautiful !
Old 01-29-2013, 10:19 AM   #11
rabbit's Avatar
Delaware
Hope you'll post a bit more on the interior spec and amenities included in the rebuild. If you had a target weight for the redone version, did you meet it? How does dry weight now compare to the weight of the original?
jack
Old 01-29-2013, 03:40 PM   #12
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Click on "Registry" under his name on this post and you will see the pictures of his Beautiful Redo! Great Job! And Welcome.
D Davis is offline   Reply With Quote
Old 01-29-2013, 05:40 PM   #13
Mike Magee's Avatar
Trailer: Li'l Hauley
Super job. Make me one too?
How to prepare Tofu
Step 2: grill some meat
Old 01-29-2013, 05:48 PM   #14
Massachusetts
Thank you D. Davis. I don't feel too goofy thinking about all the great things I've missed not knowing how to bring up those photos. Mike
