Movin' On Up - Page 2 - Fiberglass RV
Old 04-15-2013, 06:59 PM   #21
Originally Posted by Brian M. in NY View Post
Hi Donna,
I noticed your posting on the ParkLiner site.
Yeah, I hang out everywhere Never know where I'll learn something new.
I like the new color on the cupboard doors better too... and I just happen to like yellow, just not on those doors
Old 04-15-2013, 07:02 PM   #22
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Congrats Brian. Great looking little trailer!!! Glad to hear your first tow was a good one.
I don't know what tires came with your trailer are but just a heads up that many of our trailers come with special trailer tires (marked on the sidewall as ST) and they are not rated for doing more than 65 mph.
Hope you make lots of great memories with your new trailer.
The tires aren't necessarily only rated for 65, but the RATING of the tire was done at 65mph.
Here's info from Maxxis:
Jared,
According to the Tire and Rim Association the inflation pressures and load specifications in general for any ST Radial trailer tires, regardless of the manufacturer, are designed and rated at 65 MPH. However, if the speed is higher than 65 MPH, the pressure and load need to be adjusted according to the following guidelines:
From 66 to 75 MPH – the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) but requires no load adjustment.
From 76 to 85 MPH – the tire inflation pressure needs to increase 10 PSI (not to exceed the maximum PSI the tire is rated for) and load should be reduced by 10%.
ST (Special Trailer) Radials are designed specifically for use on trailers. They have different construction features and materials that vary from Auto and/or Light Truck tires. There are no merits in using a Light Truck tire over an ST Radial if the intended use is for a trailer. Maxxis would not recommend any tire be used in any application it was not designed for.
Thanks for your inquiry and interest in Maxxis Tires.
Best Regards,
The Maxxis Support Team
Old 04-15-2013, 07:08 PM   #23
carlkeigley's Avatar
NE Oklahoma
Thanks Jared. The "rest of the story" is always welcome.
I just went out an copied all the information off my tires to see if there was a problem.
LOL
Old 04-15-2013, 07:23 PM   #24
Brian M. in NY's Avatar
Trailer: 2013 ParkLiner
Upstate New York
Jared,
Thanks for filling in the details. I read pretty much the same recommendations on the TireRack website. I must be getting old as I don't really like driving much above 65 even when I don't have anything in tow. As for getting down on my knees and adjusting my reading glasses so I can determine the maximum inflation pressure could be a problem. Maybe I can't get back up. Maybe I should take a sheet of paper and pencil and take a tracing???
Brian M.
Always remember you're unique, just like everyone else.
Brian M. in NY is offline   Reply With Quote
Old 04-15-2013, 07:46 PM   #25
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Maybe you should just keep the speed down to around 65 and fahgeddabouddit! Jared won't get there any sooner than you will...
Francesca
Old 04-15-2013, 07:48 PM   #26
Jared J's Avatar
Kansas
I'm the apparent idiot doing speed limit (70-75 depending on state) or 5mph over with the rest of traffic that causes everybody to freak out.
I asked Maxxis about running a commercial LT of theirs, due to the "speed limitation", and that's how that came about.
I have another 35 (probably 40, then) years until retirement, and I don't have time to waste, I want to get to the site.
I'm not saying that's right for anybody else, but I've had more weight in the bed than the scamp weighs, and I've had 11,000 lbs behind the vehicle down the highway before (bit of an oops, no idea it was that high until I scaled at the dump, over 16k with pickup and trailer ), and it handled it fine. Your mileage may vary, and your vehicle will spontaneously burst into flames if you go over 55...
Old 04-15-2013, 07:51 PM   #27
Jared J's Avatar
Kansas
Francesca
We've been down this road, not true.
Old 04-15-2013, 08:06 PM   #28
Upstate New York
fahgeddabouddit! ..
Francesca
Are you sure you're from Washington? Sounds like New Jersey to me! Either way, good advice!
Brian M.
Old 04-15-2013, 08:51 PM   #29
deryk's Avatar
New Jersey
I wanna refinish mine this fall or winter...I dont really care for the yellow either but I wasn't not gonna buy it just for that reason. Not looking forward to drilling out all the rivets lol
Hi Donna,
I noticed your posting on the ParkLiner site. The original cabinet doors on the first units, that had kind of a yellow finish (which really turned us off), are gone for good. Chandler has gone to a maple veneer plywood with a clear (water based??) polyurethane which really shows off the wood grain but does not turn it yellow. We were pleasantly surprised when we picked up ours and found the new finish. There are so many cabinets and we really didn't want to refinish all of them!
deryk
Old 04-15-2013, 10:06 PM   #30
My genes are showing...my Mother's from New Jersey!
Or, perhaps more properly: "Noo Joisey"...
Francesca
Old 04-16-2013, 05:10 AM   #31
You're not an idiot Jared. We just want you to be safe and you are sharing the road with others....
Old 04-16-2013, 08:54 AM   #32
Upstate New York
New Avatar
Courtesy of accrete (Thom on the WET Coast of Oregon, USA)
Thanks Thom!
Brian M.
Old 04-16-2013, 10:30 AM   #33
Robin G's Avatar
Trailer: 2007 Casita
Congrats! Loveeeeeeeeeeeeee, the interior cushion color! So fresh looking. Enjoy............
Old 04-16-2013, 10:36 AM   #34
Me too!
Brian was that material an options from the factory or did you have to supply it???
Old 04-16-2013, 12:25 PM   #35
Upstate New York
Me too!
Both the cushions and curtains were from the standard factory palette. The cushions are Dupione Peridot and the curtains are Canvas Vellum. All fabrics are Sunbrella.
Brian M.
Old 04-16-2013, 12:31 PM   #36
Now, that's the kind of detail that sets Parkliner above so many other trailermakers.
Talk about "fit and finish"!
Enjoy, Brian!
Francesca
Old 04-16-2013, 12:42 PM   #37
Upstate New York
Enjoy, Brian!
Francesca
I guess it's kind of logical, too. The Sunbrella factory is located in NC only about 15 miles from the ParkLiner factory. The quality is fantastic and the person who sews them for PL does beautiful work the fit is so tight that none of the cushions every bounce out of place. Chandler will have them made of any material you want outside of the standard selections, you just have to purchase and ship him the requisite 25 -27 yards of fabric, (depending on the pattern.)
Brian M.
Old 04-16-2013, 12:50 PM   #38
It's nice that the factory is local, but still- Sunbrella is a premium product for which there are many cheaper substitutes and Parkliner is to be congratulated for using it as their fabric of choice.
I don't know of any other fiberglass trailer maker that uses Sunbrella or a comparable material as a matter of course for their upholstery...I'm sure if I'm wrong I'll shortly be hearing about it!
Francesca
Old 04-16-2013, 01:10 PM   #39
arlon's Avatar
Trailer: 2002 Casita Bunk Delux
If I'm going to go to the trouble of towing anything, it might as well have enough comforts to make the effort worthwhile.
2002 Casita 17' Bunk Model Delux (replaced 28' 5th wheel)
2003 Dodge/Cummins quad cab (daily driver/tow vehicle of choice)
2005 AWD Astro Van/camper (my solo camper)
2006 Xterra MT (for sale)
arlon is offline   Reply With Quote
Old 04-16-2013, 01:14 PM   #40
Upstate New York
Do I hear an AMEN to that!
Brian M.
