New 1978 Boler owners James and Anita - Fiberglass RV
Old 04-21-2015, 12:12 AM   #1
Hi everyone! Really excited to take the little egg out for its maiden voyage! Needs some work as they all do, haha, but am more than willing to tackle what's needed. The po knew a welder that took care of the frame before it became a problem, I checked and it has been reinforced in the problem areas. The fabric and foam was replaced not long ago. No heater, fridge was replaced with a bar fridge, kinda sad about that, but at the worst it can be used as an ice box while dry camping. Needs a new vent, it was leaking and they sealed it shut with what looks like tar and roofing shingles? Yeah, I know.... Sigh. Does anyone know of a good replacement? I know about the fantastic fan, but don't like the spacing issue. Is there an alternative to that that doesn't have the gap? I don't mind cutting a larger hole, in fact with that mess of a "fix" they did, cutting it out would be easier! Also, anyone install a water pump? I would like to tap it into the existing water tap, do I just need to tee line it and install a check valve on the city water line? I would also like to keep my manual pump, is that possible? Thanks so much for all the info you have all already given me, this site has been useful in buying a Boler as well.
James Mc is offline   Reply With Quote
Old 04-21-2015, 01:51 AM   #2
Borrego Dave's Avatar
Welcome to FGRV, you'll get some answers from Boler owners soon. Most everybody has a powered vent. I have a FF but don't understand your spacing comment/concerns. Sounds like you have a real cleanup job around your current vent to do. Be sure to use butyl tape as a sealer when you do install another vent, not sillycone. Installing a water pump isn't hard but you may want do a little searching in the document center for threads on the plumbing questions you have. BTW, a number of members have replaced their inop refers with used ones from tent trailers being parted out pretty cheaply too .
Old 04-21-2015, 06:29 AM   #3
Ian G.'s Avatar
Welcome James great to see another Alberta Boler owner, looking forward to meeting you this summer at an event.
You may like the power roof vent mod I made on my Boler.
DIY Power Roof Vent
Also your idea of adding an electric water pump is a common mod, is your resivour still usable? If not here is a solution that works very well, the inlet line into the trailer can be to either street water or the reservoir, the reservoir uses an electric pump to pressurize the system.
External Water Reservoir
Old 04-21-2015, 11:51 AM   #4
Massachusetts
Fantastic idea for fan! Are they reversible or can the setup be turned around easily to have the air come in through the roof?
mrmdvo is offline   Reply With Quote
Old 04-21-2015, 01:39 PM   #5
That is a good idea! I'm not too concerned with massive air flow, just like you said, keeping the humidity down would be a big plus. Had problems with that in our last trailer.
Old 04-21-2015, 01:42 PM   #6
I have seen a couple of installations where the FF needed a spacer made for either the roof or on the inside of the trailer, due to the trim ring being too deep/long.
Old 04-21-2015, 03:46 PM   #7
David Tilston's Avatar
1.25" square tube makes a great spacer on the outside.
Your fridge was likely an RM211:
Tent trailer parts | parts, accessories | Calgary | Kijiji
1974 tent trailer furnace, fridge and stove and sink | travel trailers, campers | Lethbridge | Kijiji
Old 04-21-2015, 04:12 PM   #8
Wow, great links! thanks.
Old 04-21-2015, 04:24 PM   #9
Ian G.'s Avatar
Lethbridge is where I got my RM2300 fridge (which would be too large to install in the stock locations). The local pick-n-pull auto wrecker, searched the custom vans & found three 3-way fridges, I grabbed the one that still had the cap on the propane inlet and the 110V still wire tied, paid $100
Old 04-21-2015, 05:27 PM   #10
The local Pick and Pull, in Calgary charged me $25 for a fridge. I wish I had bought the 12VDC compressor fridge I saw.
Old 04-21-2015, 05:45 PM   #11
I frequent pick n pull in Edmonton, definitely something else to keep an eye out for now.
boler
Tales from James G James G Fulltiming in a Molded Fiberglass Trailer 1 03-27-2009 12:21 AM
