New and exploring fiberglass option - Page 2 - Fiberglass RV
Old 07-17-2019, 04:13 PM   #15
Originally Posted by DebPaul View Post
In many ways (except interior height), the Little Joe does look like it has what we need. A long enough bed, a cook stove and sink and seating. But, the GVWR is listed as 2999. I thought I understood the GVWR to be what the camper weighs including the water tank full and average stuff people would pack into it. But, if the camper is 1100 # empty, that seems like a lot more weight than most add to get from their "dry weight" to the GVWR.
Also, if it is 2999# GVWR, I am surprised that 4-cylinder vehicles and hybrids can pull it.
That seems way high and a weird number to boot; 2000# seems more likely. Typo? "9" and "0" are only one key apart...
Actual GVW will likely be 1500-1700# pounds. It's not a lot lighter than a Scamp, which is a fair bit larger. Sturdier frame and shell may explain part of the difference. The Little Joe is also sold for commercial applications.
Just for fun, look up the GoBE trailer. It's a new expedition-grade unit using the same shell.
Old 07-17-2019, 04:32 PM   #16
Trailer: 2010 Little Joe / 2010 2 Dr Jeep Wrangler
FYI
I just had my 2010 little joe weighed ... without water ( holds 6 gallons) and partial filled 20 gal propane tank it was 1350
The only thing we would be adding to take off would be our food/drinks and clothes... the actual weight included bedding & cooking utensils
Just adding this as an FYI
We love the little joe for its queen bed and simplicity
alan H is online now   Reply With Quote
Old 07-17-2019, 04:43 PM   #17
Trailer: learning about
what is meant by "expedition grade" for the GoBe Trailer. Does look similar to the LIttle Joe.
DebPaul is offline   Reply With Quote
Old 07-17-2019, 04:47 PM   #18
Heavy duty frame, large tires for ground clearance. Not sure if it has a different axle & suspension set-up with shocks, maybe. Been a while since I visited that site. I believe GoBE buys the shells from the company that makes Little Joe, so the resemblance is more than coincidental.
Another member posted that his Little Joe scaled out at 1700# fully loaded. Clearly some people bring more stuff than others!
Old 07-18-2019, 12:56 AM   #19
John in Santa Cruz's Avatar
Mid Left Coast
gwr is the max total weight the trailer is rated for. my casita 16 was about 2000 lbs dry, and had a GWR of 3500 lbs. actual weight traveling would be the 2000 + whatever you actually put in it, including water, propane, and should be under 3500 lbs or you're overloading the frame and axles and tires and brakes.
Old 07-18-2019, 06:49 AM   #20
Bernese Bunch's Avatar
Trailer: 2015 Lil Snoozy
Delaware
Egg Camper is going back into production and their head room is 6' 7". The sons are starting up.
Bernese Bunch is offline   Reply With Quote
Old 07-18-2019, 06:59 AM   #21
John, I believe the correct acronyms are GVW (gross vehicle weight), the actual total weight of the vehicle and everything in it, and GVWR (gross vehicle weight rating), which is the maximum total weight of the vehicle and everything in it set by the manufacturer.
Similarly, there is GAW and GAWR (gross axle weight and gross axle weight rating) for each axle, as well as GCW and GCWR (gross combined weight and gross combined weight rating) for the actual and maximum weights of tow vehicle and trailer and everything in both.
UVW (unloaded vehicle weight), also called “dry weight” referring specifically to travel trailers, refers to the as-built weight of a trailer with all fixed equipment and options as it leaves the factory. Sadly, it’s not a requirement for manufacturers to weigh each finished trailer and post that number on a label, but some do.
Published dry weights are typically the base UVW for a model before options. That’s why they are particularly unreliable, because most molded trailers have a very long option list. It’s one of the benefits of the factory direct sales model- the ability to have it the way you want it.
The difference between the GVWR and the UVW is the cargo carrying capacity CCC of the trailer. There is a lot of variation in that number among travel trailers, too. Some (toy haulers especially for obvious reason) have a very generous CCC. On others it can be quite limited, but 500-1000# CCC is pretty typical for smaller travel trailers.
Motor vehicles use the terms “curb weight” and “payload” instead of UVW and CCC. Curb weight includes all vehicle fluids, in contrast to dry weight, which does not.
Ratings do not represent the true maximum capabilities of a vehicle. Of course manufacturers leave some safety margin. Your springs don’t immediately break, for example, if you exceed the GAWR by a hundred pounds. You may find the vehicle doesn’t handle as well, and over time things will wear out faster. Manufacturers take all that into account when setting ratings.
However, manufacturer ratings are generally recognized as legal limits in most motor vehicle laws. In theory you could be cited or even impounded for exceeding a weight rating. Enforcement is rare (except large commercial vehicles), but it’s always a possibility if a vehicle appears grossly overloaded or unsafe to a LEO. It could also result in criminal or civil liability if a post-crash investigation uncovers an overweight condition.
Oops... got a little carried away. Hope some of this is helpful to a newcomer...
Old 07-18-2019, 03:28 PM   #22
And any options and the battery(ies).
thrifty bill is online now   Reply With Quote
Old 07-19-2019, 09:24 PM   #23
Mid Left Coast
trailers have a GWR rating on the data plate, while cars and trucks have a GVWR. I can only presume this is because a trailer is not a 'vehicle'.
Old 07-19-2019, 10:23 PM   #24
Anything can be a vehicle.
a thing used to express, embody, or fulfil something: I use paint as a vehicle for my ideas.
Old 07-20-2019, 10:35 AM   #25
Trailer: Scamp 5th wheel
We have a Scamp 5th wheel, which we have pulled with both 4-cyl and 6-cyl Tacoma's. Of course, the 6 gives a bit more oomph for getting up grades, etc.
But to comment on bed size: We sleep sideways on the upper bed, as we didn't like the specter of kicking our feet through the window screens. Made a pull-out shelf that we put foam on to extend over the stairs for foot room. A king-sized sheet fits in this configuration! It's not hard to do...
Highly recommend getting a FG trailer! Makes camping easier (we used to be tent campers) on the old bones, plus they can go almost anywhere. Our 5th wheel is super easy to pull and very stable, even in high winds.
Becca50 is offline   Reply With Quote
Old 07-20-2019, 03:26 PM   #26
The 17' Casita might be a little big for you, but I'm 6'2" and I have to slouch a little to clear the vent knob and the bed is just big enough for the two of us, BUT we love the bathroom, the fridge, the simplicity and durability of the Casita.
We've towed it 70,000 miles and it looks great and is as tight as the day it left Rice, TX (in 2006). The tag says it weighs 2700#, but I've never seen it at that. Fully loaded for a month plus trip it weighs 3500# +/- 100#. I pull it easily with a 2011 GMC Acadia (SUV).
Loring Green is online now   Reply With Quote
Old 07-22-2019, 03:00 PM   #27
Thanks, everyone. These posts on weights really are helpful. I will be printing and saving your post Jon in AZ. Thank you. Going to look at someone else's Little Joe on Wed. That should give us some idea of how a 13' feels, at least.
Old 07-23-2019, 07:58 AM   #28
A Little Joe is not exactly representative of all 13’ers, being quite a bit narrower. Most of the space is taken up by the bed. If that’s all you really need, perfect! I hope you’ll find a way to see some other trailers as well, including other 13’ers. We like having enough space to hang out, cook, and eat inside when the weather turns nasty.
Regarding weights, John may well be right that trailers simply use GWR rather than GVWR. My Scamp lacks a weight sticker so I couldn’t check.
However, trailers are indeed vehicles, not in the abstract sense Glenn suggests, but according to the legal definition used by motor vehicle departments. So GWR and GVWR are technically synonymous. The latter is what you’ll find in motor vehicle laws and applies to towed vehicles as well as motorized vehicles.
The terminology gets confusing. Just remember a “gross weight” is an actual loaded weight and a “weight rating” is an upper limit set by the manufacturer.
Tires have weight ratings, too, and they’re dependent on inflation. The maximum load listed on the sidewall assumes maximum inflation, also listed on the sidewall.
Exploring BigFoot 25' trailer MK Evenson General Chat 36 06-05-2019 10:37 AM
Real Weight of 2016 Scamp 13’ Std. Layout 2 and Option Ideas if placing Factory Order Triker Towing, Hitching, Axles and Running Gear 19 04-15-2016 01:08 AM
For Sale: Bargman L-300 Door locks for Trilliums and other option - direct replacement Lock idiotsniff Parts: Buy | Sell | Trade 0 01-13-2012 11:56 AM
New, exploring possibilities, trailer virgin itlives Hi, I am.... 11 06-27-2011 03:39 AM
New Option for ensolite... thenoob Problem Solving | Owners Helping Owners 0 09-20-2010 07:47 PM
