New Member - Fiberglass RV
Old 07-24-2015, 07:48 PM   #1
Trailer: In The Market
New Member
Hi I am Sean and have just joined this forum. I am in the market for a fibreglass trailer and am leaning towards the Lil Snoozy, but I want to do a propane conversion including hot water, furnace (thinking Propex) and a 2 burner cooktop. Looking at the new GMC Canyon for a TV. Also thinking of the Anderson hitch. Might be overkill but I like the idea of the truck and trailer completely level and with sway control.
Was also looking at 2 6Volt deep cycle AGM Batteries placed on a slide out tray with access from the left hand side of the Snoozy. Would require a cutout to the wall.
Any ideas on this?
Sean Murry is offline   Reply With Quote
Old 07-24-2015, 10:36 PM   #2
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Oklahoma
Sean, welcome. There's a cargo access door on the side, near the front end of the Snoozy. Maybe install a tray inside there? I'm not sure, though, if it's entirely safe to have them inside. I've read that AGM batteries still can vent sometimes; Optima recommends ventilation to outside on theirs.
The rig you're contemplating sounds like a good one. If you have money to burn, send me some and I will buy a rig to match yours!
Old 07-25-2015, 07:53 AM   #3
charlsara's Avatar
Trailer: 2014 Lil Snoozy
The LIL Snoozy factory will add a cargo door to the left side if you want. I know of at least one owner who had it added. Richard will do just about any custom work within reason. Just add money.
charlsara is offline   Reply With Quote
Old 07-25-2015, 09:11 AM   #4
lil snoozy
I did hear they would add a cargo door to the left. My idea was to have a sealed battery box in the storage area, with the slide out within the sealed box. The door would have venting to release any gases. I have seen similair ideas on pop up campers. Hallmark RV does this with their campers.
For the hot water tank I was thinking The Precision RV-550 NSP Tankless water heater which takes up about the same space as the standard electric heater that comes with the Lil Snoozy and weighs less. It also vents through the floor for combustion and exhaust, so no need for a cut out for that.
I must say this forum is a very helpful one. I have been viewing it for quite awhile and there are a lot of good ideas shared.
Old 07-25-2015, 09:26 AM   #5
Bob Miller's Avatar
That RV-550 looks interesting, but the price is a real killer. I'd wait until there are some time based experience evaluations before I put that kind of money into one.
I think that you are overly concerned about battery venting. Even conventional batteries only require a 3" vent be added to the sidewall. There are also battery boxes with vent tubes attached.
Old 07-25-2015, 12:22 PM   #6
Thanks for the feedback on the battery. I will do a bit more research into the type of venting required. The idea of the slide out tray was for convenience when needing to service or replace the battery.
I agree the pricing on the hot water heater is expensive, and will continue to research the idea.
Does anyone have experience with the tankless hot water on demand heaters versus the hot water heaters that have storage tanks?
What about any experience with the Propex heaters?
Old 07-25-2015, 02:17 PM   #7
charlsara's Avatar
You can get a lot of LIL snoozy info over on the LS Owners site and by searching here. A couple of people have installed the Propex.
New (Older) Scamp Owner, New Member Harvey Hi, I am.... 12 02-06-2011 10:34 PM
New Scamp owner & New member. 1992 Scamp 16 project LanM Hi, I am.... 16 01-31-2011 09:05 PM
Junior Member versus Senior Member ? Dave Baston Forum Admin, News & Announcements 5 01-02-2011 07:41 PM
New Member, New to me Burro Scott B. Hi, I am.... 10 07-21-2009 08:52 PM
New member, new "old" rig Marv Watson Hi, I am.... 4 09-23-2008 12:18 PM
