New- Subaru Forester-What Can it Pull? - Page 5 - Fiberglass RV
Old 12-25-2016, 06:43 AM   #57
Originally Posted by Veggiegirl View Post
... I'm even looking at the Burro; I would prefer it actually. I like that no one else can stay in it. Haha. Thank you for your help!
Burros, at least the smallest 13'era, are a good option for you. They have pretty much the same layout as a Scamp, though- they can sleep up to 4 depending on configuration. They may be a little lighter, but beware of the 880 pound Burro in the "Trailer Weights" database- pretty sure that's a gutted, empty shell. I'd expect one to weigh 1300-1500 pounds loaded for camping.
Old 12-26-2016, 04:10 PM   #58
SilverGhost's Avatar
Trailer: Egg Camper
As for head gaskets, way back when I worked at a Subaru dealership the simple "recall" was some gunk in a bottle we put in the cooling system. The main issue most people run into is because of where Subaru put the sensor for the temperature gauge. It is in a high point that commonly will get an air pocket and as result engine will get hot/overheat but temperature gauge won't move to warn you. First warning most people get is car running poorly after the damage is done.
So, keep an eye out (or rather a good shop/mechanic) for coolant stain around head gaskets that warn of needed replacement. Also be extra fastidious on keeping cooling system full and coolant is good shape.
Jason
SilverGhost is offline   Reply With Quote
Old 12-26-2016, 05:18 PM   #59
Trailer: 82 Scamp 13 ft
Seattle Subaru Repair has a good page on the years and symptoms for Subaru headgasket problems. I replaced the headgaskets in our first-gen 2.5 liter Forester at about 175k; that was almost 100k miles ago. We towed a basic Scamp 13 successfully over many years and I wouldn't tow any more than that with a Subaru. I did put in a big transmission cooler, first thing. I wish they still made a 2.5 liter with a traditional automatic/ not CVT.
John A is offline   Reply With Quote
Old 01-01-2017, 10:43 AM   #60
Denece's Avatar
Trailer: Compact II
We have a Forester
2011, 4 cylinder, automatic
We tow a Compact II, which we try to keep as lightly loaded as possible.
We made one trip from California to Denver.
We ended up going 15 mph on the long uphill grades.
It was terrifying being on the freeway and going so slow ( not to mention it is illegal in some states).
Doing secondary roads would have been much better had we known the situation we would put ourselves in.
Our solution?
We now tow with our 4 cylinder Tacoma.
Others may be happy towing with the Forester but we were not.
Denece is offline   Reply With Quote
Old 01-01-2017, 11:01 AM   #61
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
Originally Posted by Denece View Post
We have a Forester
Our solution?
When I tow on hills I've often downshifted to 3rd- not so much freeway hills as other roads, though. My feeling with Mom's automatic was that it didn't kick in at lower gears as quickly as you'd want it to for towing. But that may have varied some by model year- hers was 2002, first generation, I think yours as a 2011 was 3rd. Same as mine but mine is a manual so I choose when to go to a lower gear.
Old 01-01-2017, 12:07 PM   #62
Denece's Avatar
Trailer: Compact II
Oh we downshifted!
The tiny engine is just no match for the Rocky Mountains!
BTW we drove the same route the year before without the trailer and had no issues.
I do not believe Subaru offers a manual transmission at this time.
Old 01-01-2017, 12:15 PM   #63
Oh we downshifted!
They also now limit towing to 1500 lbs. But your year was 2400.
The advantage of a stick is that you can shift down before you slow down- once you slow down on a hill you can't get speed up again very fast. My last trip I had to stop on an uphill due to construction and never did get up to speed again. I didn't have the hill holder problem someone else had with theirs, but I just couldn't get the trailer up to speed after a full uphill stop. Normally before I slow too much I'd downshift. At least in Mom's automatic, it won't shift until you are already slowed.
Old 01-01-2017, 01:13 PM   #64
All you have to do to downshift an automatic is stomp on the accelerator. If you do that before you've slowed, it will downshift and maintain speed.
My RAV4 manual says to tow in 4 ( not overdrive ) and not to hard tow in 3 or 2 for an extended period ( no definition ). I leave it in 4 and just stomp on the gas when needed.
Old 01-01-2017, 02:43 PM   #65
Trailer: Wtd: Something Tiny!
Re: Denece
Denece, that sounds terrifying! But my tow capacity is 1,000lbs more than yours is.
We have a Forester
Our solution?
Veggiegirl is offline   Reply With Quote
Old 01-01-2017, 02:47 PM   #66
To John
Thank you! Yes, mine is the 2.5 automatic. Don't know what that means - but am glad it's something positive.
Sorry for not responding to other comments. My spam folder stole your messages.
Old 01-01-2017, 02:55 PM   #67
No, it isn't. Her 2011 has the same as your 2003- 2400 max, 1000 without brakes, 200 lb tongue weight.
However, I bet you can get a good idea what your car would do if you load it up with about half a ton of stuff and do some driving on some hills.
Old 01-01-2017, 08:39 PM   #68
So....there's really nothing
I can pull and go up hills? Coz.....15mph = terrifying!
I thought the older ones could pull more - but maybe 2011 is still 'old'. Hari
Old 01-01-2017, 08:51 PM   #69
Models were 1998-2002 (2000 lb max) then 2003-2008? at 2400, then 2009-2013 (2400) and then 2014 on (1500).
But I still think Denece's experience probably isn't average for the car. Or the mountains are steeper in Colorado (likely, too). I think you can pull a lightweight trailer, somewhat heavier with brakes. I wouldn't go all the way to 2400 but if you get one with a dry weight around 1200-1400 (with brakes) you can be judicious about how much you carry.
Old 01-01-2017, 10:32 PM   #70
And, if you're wrong, and get to the top, there are always those runaway lanes on the way down.
Anyone towing with a Subaru Forester competitor? Bobbie Mayer Towing, Hitching, Axles and Running Gear 50 07-13-2011 05:22 PM
More Subaru Forester Towing Questions Michelle A Towing, Hitching, Axles and Running Gear 12 04-04-2009 10:18 PM
Subaru Forester Diesel? Bobbie Mayer General Chat 11 03-07-2009 06:23 PM
towing a 13' burro with a Subaru Forester Pamela H Towing, Hitching, Axles and Running Gear 5 07-23-2008 08:15 AM
Electric Brake Control for Subaru Forester Todd Sleeman Problem Solving | Owners Helping Owners 20 10-27-2007 10:08 PM
