Newbie Scamper - Page 2 - Fiberglass RV
Old 12-03-2014, 03:18 PM   #15
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Prodigy P2 Steve, very good reviews and easy to install also.
Old 12-03-2014, 03:22 PM   #16
Originally Posted by scampersteve View Post
Thanks, Guys! Yes it has the 4-lug pattern ...so I'm guessing it's 2200 lb axle sad to say. But truthfully I don't see us loading this scamp up with much. It's has no AC, hot water. heater, just the 10-gal water tank, fridge, 3-burner range ...we may thrown in a portapotty, food/water and clothes maybe a few outside lawn chairs/BBQ that'll ride in back of my truck. SO we'll see how it goes with stock axle for now. Weather needs to warm up before I can get out there to work on it. Meanwhile I'm reading up on brake controllers.
Thanks, Steve
I believe that the Scamp 16' and 19' come with 3500 lb axles. The 2200lb brake drums are 7 or 7.5" drums the 3500 lb axle is 10" drums.
Byron Kinnaman is online now   Reply With Quote
Old 12-03-2014, 03:22 PM   #17
I agree with Dave, generally it's plug and play.
Old 12-03-2014, 03:43 PM   #18
Herman M Parker's Avatar
Name: Herman & Ann
Trailer: Scamp 5th Wheel
Pensacola Florida
Welcome aboard. When the weather warms up for you check on rally's in your area or as I like to say Road Trip and go to one. You will meet the nicest people.
Herman M Parker is offline   Reply With Quote
Old 12-16-2014, 10:21 AM   #19
scampersteve's Avatar
Trailer: 03 Tacoma pulling 83 Scamp 16
UPDATE: Recapping I recently purchased a '83 scamp that I was wondering if it had brakes? Well it does sorta ...the brake housing is there and so is the wiring (almost) thanks to cell phones w/cameras: https://www.flickr.com/photos/goathiker/15414444274/...you can see the blue & red wires go nowhere!! ...they just stop short of being hooked to the brake backing plate. Why is anyone's guess?
So my challenge now assuming the axle is still good (based on the prestine condition of the rest of this trailer it should be) is to determine the correct shoe size and magnet assembly and order some parts. Plus a set of wheel bearings for good measure. I'm thinking this trailer must have been kept indoors and jacked up for many of it's non use years!
Does Scamp/MFG keep records on what parts go into their builds over the years. For example if I gave 'em the VIN# would they be able to tell me what axle I have and what size brakes were installed (mine's a 4-lug wheel)
Thanks again for helpful info, Steve
scampersteve is offline   Reply With Quote
Old 12-16-2014, 10:39 AM   #20
Trailer brakes are basically sized by inside diameter of the drum. For the most part that should get the pieces you need. What was installed 30 yeasr ago may or may not be what's there today.
Check on etrailer.com and you may be able to buy entire loaded backing plates and drums for less than the individual parts.
Old 12-16-2014, 10:46 AM   #21
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Steve, you can get those parts at just about any RV store. Just unbolt the 4 nuts, & your spindle nut, and bring the assembly to the store with you and they can match you up. You should be able to read the bearing numbers once you wipe away the grease. Most auto parts stores can match those numbers up for new bearings if the RV store doesn't have them. I always carry an extra set (greased up & ready to go) in a zip lock bag.
Good Luck
Dave & Paula
New Scamper member from Carlsbad, CA ruscal Hi, I am.... 7 12-19-2011 05:22 PM
Update on "Great White Scamper" Susanm34 Modifications, Alterations and Updates 5 10-07-2011 04:47 AM
1985 scamper and camper: Advice on refrigerator, bunk beds, front window BradleyScamp Problem Solving | Owners Helping Owners 4 09-06-2011 04:52 PM
1991 13' ScampER Jake Jacobson Classified Archives 3 10-31-2008 01:35 PM
New Scamper General Chat 0 12-31-1969 07:00 PM
