Noisy A/C - Fiberglass RV
Old 06-15-2017, 12:10 PM   #1
Noisy A/C
I have a 2016 16' Scamp and the A/C is very noisy. Actually it's impossible to sleep with it on.
I have read various posts on the subject. I recall one that referred to a fix for Coleman A/Cs whereby a kit was available to reduce the noise.
Does anyone else know of a fix for a noisy Dometic A/C?
Larry Linderman
llinderman is offline   Reply With Quote
Old 06-15-2017, 02:21 PM   #2
IllAnnoy
Is the noise normal or is it something like the fan striking the shroud or something?...
Old 06-15-2017, 03:29 PM   #3
likeair2me's Avatar
Trailer: 1981 SCAMP 13
Have you checked to see if it a problem common to the particular model? It could be a design failure. One thing about the internet, people will point out failures and remedies.
If it is a fairly new development, is it...
a) that the unit or a component inside has vibrated loose
b) there is a foreign object lodged inside it somewhere
c) always noisy when the entire unit runs, or is it just the blower (could be bearings failing)
d) drawing a lot more amps than usual (motors failing)
The first tools to use will be your eyes and ears. If it makes it to your nose, it's already burnt.
likeair2me is offline   Reply With Quote
Old 06-15-2017, 05:46 PM   #4
rbryan's Avatar
Larry Linderman
Dometic sells an anti-vibration damper kit which consists of some rubber bushings that go under the compressor mounts, some small foam blocks, and some zip ties. It runs about 20 bucks. But, if your unit is a 2016, it may already have the kit installed, since Dometic started doing that a few years back.
I'm afraid it's the nature of the Dometic units, combined with being mounted directly on a thin fiberglass roof. They're all noisy. You might be able to reduce the noise somewhat by wrapping the compressor in some fiberglass insulation, followed by a wrap of rubber sheeting, and then using some sort of rubber bushings or foam blocks along the pressure lines leading to the compressor to keep them from moving. Some have done so and achieved about a 5dB noise reduction. But, you really can't do anything about the roar from the air. The only reasonably quiet roof mounted units these days are the ones that are ducted, and you won't find those on a single hull fiberglass trailer.
Old 06-15-2017, 08:38 PM   #5
IllAnnoy
I sleep like a baby parked between running semi trucks in a rest area.
I think the answer is to train yourself to ignore those sounds which are normal and expected.
When I worked night turnarounds I would place a noisy but consistent fan next to my bed to make "white noise" which would cover the sounds of traffic outside or activities inside the house. It worked well and I came to depend on the fan for a full day's sleep.
Old 06-16-2017, 07:18 AM   #6
Trailer: 2008 Casita 17 SD
Your problem is solved, for $300 bucks. Yes, it's not cheap, but IT WORKS!!!
I installed one of these in my rooftop A/C and now you can't even hear it cycle on. Before I installed this thing, the whole trailer would shudder and it was really loud. Now it's whisper quiet. I have a Polar Cub A/C unit, but they can be retrofitted to just about any A/C unit on an RV or trailer.
Do not confuse this with a "Hard Start" capacitor. That is totally different, and doesn't work at all like this thing does.
It all depends on what peace and quiet is worth to you.
https://www.microair.net/products/ea...nt=30176048267
Old 06-16-2017, 09:22 AM   #7
Noisy A/C
Casita Greg,
I spoke to Roger about the Easy Start you recommended. He said it only reduces the noise of the start-up, when the A/C is running it cuts out completely. Perhaps you misunderstood my post which is about the roar coming from the A/C while running, not just starting.
Larry Linderman
Old 06-20-2017, 01:57 PM   #8
DeBreez's Avatar
Trailer: 2015 Casita 17SD
Miami, FL
Larry, I would contact Scamp or Dometic directly. If it's bothering you, it's possible others have complained too. The Coleman Mach 8 on our Casita had an exterior noise issue and Coleman/AirExcel came out with a modified fan that helped but did not eliminate the issue. I've heard that they've made some further changes since then.
An outside vendor came up with a solution that fixed the exterior noise issue. We then found, like Casita Greg, the biggest problem for us was that when the compressor kicked on, it literally caused the trailer to shake. We also installed the EasyStart kit and it made a huge difference.
Part of the issue is that these are small trailers with very large air conditioners, and you are sleeping right under it. Don't rule out earplugs.
"...I keep blowin' down the road."
2015 Casita 17' Spirit Deluxe
2002 Toyota Tundra V8
DeBreez is offline   Reply With Quote
Fixing noisy Suburban furnace Scamper Jim Modifications, Alterations and Updates 2 04-02-2017 07:02 AM
Noisy Endless Breeze Fan CliveAlive Problem Solving | Owners Helping Owners 7 10-16-2012 06:47 PM
Noisy water pump. peterh Problem Solving | Owners Helping Owners 20 04-20-2011 02:42 PM
Talking to the noisy ravens at camp shane n General Chat 0 07-13-2009 02:02 PM
Noisy water pump Per Walthinsen Plumbing | Systems and Fixtures 15 06-11-2006 11:30 PM
