Over my head Amerigo - Fiberglass RV
Old 09-01-2018, 12:34 PM   #1
Trailer: Amerigo
New member since I just got a PROJECT Amerigo F-16 that is more than I really wanted to do. I never heard of them until I saw and had to buy this one. It is just a shell, windows, and cracked door. I've never done a rebuild like this so ANY help(manuals, specs, pics, parts, and sources) is appreciated. I'm in the Knoxville,TN area if anyone is around. I wasn't sure why I felt like I had seen it before until it came to me(search Star Trek Galileo).
Galileo is offline   Reply With Quote
Old 09-01-2018, 04:06 PM   #2
ShelbyM's Avatar
Trailer: Casita SD
There is a nice one for sale in Nashville TN. I sure miss... You could buy it for inspiration or just ask for the 90+ detailed pictures. Seem like cool trailers, good luck!
Old 09-01-2018, 07:47 PM   #3
Trailer: Amerigo
ShelbyM
Thanks for the link. I emailed for the pictures with an explanation for the request. I'm sure they will be a help.
Old 09-01-2018, 08:44 PM   #4
Trailer: '82 Burro 13'
Northern VA
Originally Posted by Galileo View Post
Star Trek Galileo
A shuttle craft paint job would be kinda cool on that trailer.
Dan-NS27 is offline   Reply With Quote
Old 09-01-2018, 09:31 PM   #5
Trailer: Amerigo
I'm seriously considering it.
Old 09-02-2018, 02:46 PM   #6
Kai in Seattle's Avatar
Check out all the threads on the FGRV site under SEARCH (go to the lower blank to type in "Amerigo") for various fix-ups. We have Leoni Belcher here whose Amerigo FG16 is called the Galileo after the Star Trek shuttlecraft. It is such a cool idea.
Semper ubi sub ubi.
Old 09-03-2018, 11:43 PM   #7
Trailer: Amerigo
Does anyone have a 'correct' pattern and thickness for the floor?
Old 09-04-2018, 03:46 AM   #8
SteveV's Avatar
The plywood floor is 5/8" & you can see how it was laid out in my thread that documents most of what I've done to my FG-16 here: Cape Perpetua, S. of Newport OR
The plywood is bonded to the shell's fiberglass floor as well as having a layer of fiberglass mat/resin laid up along top of the outer 8" - 12" perimeter in the front section. If you have any plywood left in your's use that as a pattern otherwise you'll have to make some patterns from large pieces of cardboard. Fortunately the rear section of flooring is a full 48" wide piece that sets between the frame rail bump ups & overhangs the 2" step up by about 3". This overhang is where the electrical & water lines tuck under from side to side. If you have any interior pics post them up so we can see what you're starting with, that will help with any advice.
Best wishes on your new project!
SteveV is offline   Reply With Quote
Old 09-04-2018, 09:58 AM   #9
I concur with Steve V's assessment. The back piece is pretty straightforward. We did the front in two sections from side to side. We used 5/8" marine ply. Others have used a fiberglass board product--I would not use ordinary plywood. We also put some rubber cush tape under the ply on top of the high portions of the fiberglass shell--and a sealed-in-plastic single page account of who, what, where, and when we redid the trailer--for posterity and to amuse ourselves.
Semper ubi sub ubi.
Old 09-05-2018, 11:58 AM   #10
Trailer: Amerigo F-16 1978?
New Hampshire
Hello Galileo,
I also am doing a major restoration on my Amerigo F-16.
I have a lot of behind the scenes pictures that I have not got around to posting.
What is it you would like to do to your camper, perhaps seeing what others have done can remove some of the hesitation in starting or even get you up to speed more quickly.
I have learned a lot about fiberglass repair. Including resins and glass selection.
I have removed all the windows and ordered new as well as filled in one window and the refrigerator louvered panel. I even pulled down the interior glass shell so I can send you shots of what is up there if need be.
Good Luck
Jonathan
JonnyX151 is offline   Reply With Quote
Old 09-05-2018, 05:41 PM   #11
Trailer: Amerigo
Thanks for the info. Steve, that's some very helpful pictures. All I have now is the windows and totally gutted outer shell. Not even the inner ceiling unfortunately, which lets the top sag at least 8 inches when not supported. That's why I need all the info I can get. I'm currently researching construction materials and techniques along with working out what I want to do to it. I will be gathering all I can before I start so I don't have any major delays once I start hopefully. It will be a while before I get to it.
Old 09-05-2018, 06:18 PM   #12
New Hampshire
No ceiling Support
Here is what I have left also!
E1353B62-8D33-40FE-A9E1-BB0B893BE537.jpg   66908B94-A9FF-4D82-A47E-3E423BE65C93.jpg
Old 09-05-2018, 10:35 PM   #13
It looks like the ceiling was created as a SIP system. SIP stands for structural insulated panel. How they provide support in a FGRV is the outer layer, insulation and inner layer are bonded together and for a single structural unit. This is much like creating sheets of plywood. It is most likely that the bonding work was one before the upper shell was removed from the mold. That way they had gravity working for them and could also put weights on top of the inner layer to make sure all the layers had good contact while the adhesive was curing.
When you peeled off the inner layer you ruined the structural support system. This is a not an untypical thing for Newbies to do as they are not structural engineers and have no clue about SIP systems and how their roof is being supported. A lot of owners of the Sunrader fiberglass motorhomes which are also built with a SIP get into the "gung-ho" mode and tear out the inside layer and the insulation and they too destroy the structural integrity of the engineered design.
The bad news is your can't undo the harm you have done as it will be next to impossible to apply sufficient pressure to recreate the glue bonds of those original layers. You can't just hit or miss it with construction adhesives, the adhesive has to be spread across the whole of the surfaces as is done when fabricating sheets of plywood.
I wish there was a way to warn all the new owners of the FGRVs that have a SIP roof system not to tear out the layers on the ceilings when doing the renovation. But hopefully the other Amerigo owners will now understand that you should pass this warning on to new members who show up with an Amerigo they want to renovate.
k corbin is online now   Reply With Quote
Old 09-05-2018, 10:49 PM   #14
How many times have you read, "I have gutted my trailer"?
amerigo
In over my head supersean86 Hi, I am.... 12 11-04-2014 09:30 AM
What do you put in your over head shelves? samcrimm Problem Solving | Owners Helping Owners 18 02-07-2013 05:13 PM
Fiberglassing over your head Cat futrell Problem Solving | Owners Helping Owners 15 11-21-2012 02:51 PM
amerigo slide-in and amerigo on a dodge chassis Tim O'Toole General Chat 4 02-27-2008 10:11 AM
Stuck in your head Lew King Jokes, Stories & Tall Tales 7 01-03-2006 10:28 AM
