Pics of the "New" Fiber Stream - Fiberglass RV
Old 04-03-2012, 06:53 PM   #1
flyby's Avatar
Trailer: Bigfoot 25
Pics of the Fiber Stream once I've applied the 4 step process of washing, oxidation removal, primary wax and then final overcoat wax..supposedly good for a year. It sure looks a whole lot better than it did! Looking to put the stripes back on..they were already gone when I purchased it. Any ideas on what to use? Paint, Tape, other? If so what kind of paint or tape would one use?
Looking forward to the upcoming get together..see you all there! And if a girl needs help..since this is after all her 1st ever trip..would that be a problem?
Click the link below to see pictures
http://flickr.com/gp/karencole22/8vY583
flyby is offline   Reply With Quote
Old 04-03-2012, 06:59 PM   #2
Certainly looks clean to me! Karen, you go to a rally and ask or need help... you'll get lots of offers. Truly. Egg folks are grand!
I'll leave the stripe question to those in the know.
Old 04-03-2012, 07:07 PM   #3
Looks good - what did you use to oxidation off?
Old 04-03-2012, 07:17 PM   #4
Trailer: Fiber Stream
I have seen several Fiber Streams that never had stripes. Others only have little stripes along the mold seam near the floor at the widest point of the trailer. Was there evidence like "ghosting" on the gel coat? Mine had definite stripe ghosts of shiny gel coat amidst the very faded fiberglass.
I used "Boot Stripe Tape" for the stripes on my Fiber Stream. I "designed" my own pattern and did not try to duplicate the factory stripes.
Old 04-03-2012, 07:28 PM   #5
flyby's Avatar
Trailer: Bigfoot 25
I used Meguiar's Marine/RV Fiberglass Restoration System. I like it and it worked very very well. The trailer looks 100% better than it did. All the oxidation is gone leaving a nice smooth surface and with the final coat of wax, it just glows!
As for the Stripes..Yes! They were there, have ghosting where they once lived, but now have completely faded or have pulled away. I like the tape idea and most likely will go this route.
Thanks for the promise of "help" if needed. I must say, I am a little apprehensive about doing all this on my own and with no experience. I've taken good notes and am pretty competent..so we will see.
Old 04-03-2012, 10:00 PM   #6
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
The beauty of using tape stripes is that if you apply them over a waxed surface they are pretty easy to remove or redo. I knew of a guy who regularly changed the striping on his car and he said as long as you have a fresh coat of wax on the surface it is no big deal to remove them. He used standard auto striping tape. Best of luck to you.
Reid Larsen is offline   Reply With Quote
Old 04-04-2012, 06:00 AM   #7
CindyL's Avatar
Illinois
We used tarp tape from Menards. It is peeling loose in a few spots, but it lasted for several years. We replace it when it comes loose.
CindyL
CindyL is offline   Reply With Quote
Old 04-04-2012, 06:02 AM   #8
Trailer: scamp 13
thats gonna be a fun one!
Old 04-04-2012, 06:33 PM   #9
Cyndivg11's Avatar
Trailer: 1984 FiberStream
Beautiful Fiber Stream!!! Wat a find!!!
Cyndivg11 is offline   Reply With Quote
Old 04-05-2012, 04:14 PM   #10
Pam Garlow's Avatar
Trailer: U-Haul 1985
Very Very Very nice Karen!! Did you do all the work by hand, or did you polish with a motorized buffer or something?
Old 04-05-2012, 07:45 PM   #11
flyby's Avatar
Trailer: Bigfoot 25
I did most of the work by hand...but! my arms got tired and sore after doing 2 sides so I changed over to the motorized buffer. The only problem with that is the bonnets get filled up fast and you have to change them frequently. So, I'd say I used the buffer but finished by hand. I am a perfectionist and wanted the finish to be smooth and shiny. The only way to get that was to finish by hand.
Old 04-05-2012, 07:51 PM   #12
flyby's Avatar
Trailer: Bigfoot 25
Taking the FS in for wheel bearing packing, brake check and overall check-up. I have an appt on Tuesday. I'm taking it to Camping World as they seem to have the best prices for this service plus a discount for Good Sam members. The trailer was last worked on in 2007. The previous owners who had it for 4 years did nothing to it. Since I know less than NOTHING on trailers, I'm hoping that they'll be able to check it all out and make sure everything is doing exactly what it is suppose to be doing. Keeping my fingers crossed that I'm not looking at big money here to get it travel ready. I do know at this point that all systems work..but for how much longer..that is the question!
Old 04-05-2012, 08:22 PM   #13
Pam Garlow's Avatar
Be sure topPut a big note on the trailer that they are to NOT use any silicone for any reason anywhere on the trailer. Also have them put it on your service tag in BIG words also.
Old 04-06-2012, 10:48 AM   #14
flyby's Avatar
Trailer: Bigfoot 25
Pam
Thanks for the warning, but why is silicone so bad? Please explain the reason..I'd much appreciate it.
Thanks
Karenm
fiber stream
1985 "20 ft Bigfoot tandem axel" 19ft 5'er? $6200 Robin G Referrals: Molded Fiberglass Trailers 0 02-14-2010 10:09 AM
overcoming a "charm-ectomy", rotten floor & other issue Kelly G Problem Solving | Owners Helping Owners 5 05-22-2009 12:57 PM
INFO RE Fiberglass "Travel Lite" Trailers of Early 60s Don Cordier General Chat 4 07-23-2008 11:18 AM
SOLD 13ft Play-Mor II For Sale "The Brown Egg" Susan Tiller Classified Archives 3 01-13-2007 03:48 PM
