Replacement battery - Fiberglass RV
Click Here to Login
Old 07-31-2016, 06:12 PM   #1
Replacement battery
Hi. I've just tried to replace the battery on my 2011 13' scamp and keep blowing my 20 amp fuse. I installed a group 27 65 amp battery. What am I missing?
Philup is offline   Reply With Quote
Old 07-31-2016, 06:50 PM   #2
Are you sure you connected the battery back up as it was?
Scamps are set up with:
+Positive to Black and - Negative to White
Old 07-31-2016, 07:21 PM   #3
I believe so. But it has had some other wires added for the tugger. Wondering if something's wrong there. Have I purchase the correct battery
Old 07-31-2016, 09:14 PM   #4
If its a group 27 battery that would not blow a fuse. But installing the battery incorrectly is a pretty common error as it is not hooked up as many folks think it should be.
Might help if you post a photo so we can see what other wires you are referring to that are go to the tug. The only wires that you would normally see coming out of the battery box is one white wire and one black wire that has an inline fuse on it. Wires do tie into the wiring harness for the tug but not normally right at the battery itself.
Old 08-01-2016, 05:26 AM   #5
Would a group 24 make a difference?
Old 08-01-2016, 06:24 AM   #6
No difference. It's still a 12V battery.
Think of a group 27 as a larger gas tank. Same gas, same fuel lines, same power available, just lasts longer.
Old 08-01-2016, 07:54 AM   #7
The Minimalist's Avatar
Louisiana
All have given good information on the hookup.
I'm curious about the amp rating you gave. By any standard, that is very low output for a 27 series battery. What is are the amps, and are they listed as CCA, MCA, etc?
Clif
Old 08-01-2016, 08:04 AM   #8
I have not replied to this question because there is too much ambiguity for me to help.
Which 20 amp fuse is blowing? Is all the 12 volt stuff turned off when you hook up the battery? Have you verified proper polarity connection to the battery? Are you also using shore power at all when this occurs?
I have to assume that "tugger" is Canadian for "tow vehicle." Is your tow vehicle connected when the fuse blows? Dis everything work OK with the prior battery? If so, did anything other than the battery change? 65 AH is rather low for a group 27 battery. Please provide photos of the battery and the "added tugger wires" as well as location of the failing fuse.
You could pull all the fuses from the power distribution panel and/or converter and see if the battery still blows the 20 amp when its connected, but I would find the problem before hooking up the battery to prevent possible injury.
More details and well annotated photos might provide more clues to the problem.
battery
Replacement Battery jbscamp Electrical | Charging, Systems, Solar and Generators 1 07-29-2016 09:57 AM
BATTERY REPLACEMENT Darral T. Care and Feeding of Molded Fiberglass Trailers 10 06-13-2015 09:04 AM
Battery replacement= Converter clicking on/off iplumb Electrical | Charging, Systems, Solar and Generators 11 03-31-2013 03:52 PM
Battery Replacement Don W. Care and Feeding of Molded Fiberglass Trailers 15 08-26-2012 06:42 PM
Fiber Stream Battery Box Replacement Victor Benz Problem Solving | Owners Helping Owners 3 05-19-2006 10:23 PM
