Scamp 5th wheel - Fiberglass RV
Old 05-20-2016, 09:22 PM   #1
Trailer: Scamp 19
Scamp 5th wheel
Hello all.
I'm new to RV's so please forgive what may seem like dumb questions
I am considering buying a Scamp 19' 5th wheel. My tow vehicle is a Tundra Crew Max short bed. Can this work especially in sharp turns?
All opinions/experience will be appreciated.
Jimmie
Cedrar Park, Texas
Jimmie is offline   Reply With Quote
Old 05-21-2016, 06:32 AM   #2
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
Welcome to the Towing World!
You will have to mount the 2" ball hitch according to the Scamp specifications, I think it is 59.5 inches (minimum) from the bumper corner, so there is enough clearance to turn. The Scamp might require the 3" raise option, so it tows reasonably level. Both can be accomplished with not too much trouble.
Re: turning radius, I have a Tacoma (4-door, short bed). I can turn the tightest turn and the cab to Scamp loft has probably 8 - 10 inches clearance. Backing up is different, jacknifing can close that gap and cause damage, so you need to pay attention. Hope this helps.
By the way, don't list phone numbers in your posts. Use the PM (Private Messaging) system.
Old 05-21-2016, 09:31 AM   #3
Dennis mn's Avatar
I can turn my rig at full lock either direction. Sharp turns are no problem. If you mount the hitch properly, you can turn with the trailer as sharp as allowed by your truck.
1999 Scamp Fifth Wheel, pulled by a 2014 Nissan Frontier Pro4-X
Dennis mn is offline   Reply With Quote
Old 05-21-2016, 09:48 AM   #4
Trailer: Scamp 19
Thank you. Good idea on the phone number. I get so many telemarketing calls I just assume everyone has it anyway so I forget sometimes.
I need to find a Scamp 19' close to me and touch and feel before getting to serious about buying. If u know of anyone in central Texas area please let me know. I'm thinking buying used .
Again appreciate your help.
Jimmie
Old 05-21-2016, 09:59 AM   #5
Virginia
Scamp 19 Tow Vehicle
I think the bed rail height of your truck is the most important measurement. I used to tow my Scamp 19 with a 2000 Tundra 4x4. It was a little taller than Scamp recommended. At the time my Scamp did not have any lift added to it. I had to set the hitch so that the Scamp was high in the front when hitched up. I had to be careful going up and down sudden changes in road height.
When I replaced the 2000 Tundra my next truck was another 2" taller. I went ahead and had the Scamp body lifted at that point so I could tow the Scamp level. When I was shopping for the replacement truck I had ruled out the newer style Tundras because of how tall the bed rails were. At some point I believe Scamp manufactured the 19 with some body lift standard. Just be sure to check out your potential Scamp 19 for lift. BH
bertherr is offline   Reply With Quote
Old 05-21-2016, 10:23 AM   #6
I agree. On the Scamp website, it looks like the 3" lift is still optional. Given the high bed rails on most new trucks, though, I expect most new builds include it. I'm pretty sure you will need it for your Tundra, and not all used units have it.
You may be able to edit your post to remove the phone number. If the 12-hour edit window has expired, there's a "Contact Us" link way down at the very bottom of the page, and a moderator can remove it for you.
Best wishes finding your trailer!
WI | Looking to trade 13 Scamp for 5th wheel Scamp or similar Mcmarkrazz Classified Archives 8 10-27-2014 12:20 PM
Scamp 5th wheel or Escape 5.0 or other small 5th? Linda Gaudet Wanted: Molded Fiberglass Travel Trailers 16 04-27-2012 09:21 PM
Front wheel drive, rear wheel drive, all wheel drive, and weight-distributing hitches Meg A. Towing, Hitching, Axles and Running Gear 14 04-26-2011 09:04 PM
SCAMP 5TH WHEEL?? Dan Quinn General Chat 11 12-07-2005 10:01 AM
