Tail lights help needed - Fiberglass RV
Old 12-25-2017, 04:23 PM   #1
Lsw
Trailer: Eggcamper
Wisconsin
I'm helping an elderly lady with her eggcamper. She has a tail light problem. Either all four stay on while driving or only upper left turn signal works when it feels like it.
Any suggestions where to start would be appreciated
Lsw is offline   Reply With Quote
Old 12-25-2017, 04:55 PM   #2
Virginia
This is a great thing to have. Should you have a problem on the road, take a few mi utes and you have tail light problems solved until you can do a proper fix.
https://www.harborfreight.com/12-vol...kit-63100.html
The following item is a Must Have. It will tell you if your tow vehicle wiring is OK.
https://www.harborfreight.com/four-w...ter-66526.html
Neto is offline   Reply With Quote
Old 12-25-2017, 05:06 PM   #3
Possibly a ground problem. Or bad connection in the plug.
Old 12-25-2017, 07:42 PM   #4
Trailer: Love Bug / Chevy Astro
Lighting problems are almost always caused by poor connections. I replaced all of my lights with LED's and replaced all of the wiring. My connections are all soldered and covered with heat shrink tubing. Every light has its own ground running back to a common wire that goes to the vehicle. The LED's are sealed so there is no connection problem with the bulb/socket.
I also have a seperate 12 volt plug for charging my battery that runs through a battery isolator.
Bob Cupp is offline   Reply With Quote
Old 12-26-2017, 04:33 AM   #5
Arkansas
99% of the time a faulty ground
ken.hibbs is offline   Reply With Quote
Old 12-26-2017, 04:47 AM   #6
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
Almost every time my Boler has an period of in-use....a few weeks, My tail lights work or don't work and I find it's always a ground issue. Check here then I would buy a new Female and Male plug for trailer and Tow Vehicle... Get a 7 prong, you never know when you want the extra prongs to use for things like a charging wire or other need.
Old 12-26-2017, 06:30 PM   #7
Lsw
Trailer: Eggcamper
Wisconsin
Thank you
Thank you everyone for your help and suggestions. If I can't figure out real problem, I will recommend the magnetic lights. I don't know if it has trailer brakes, if so, does it use that same harness? With using the magnetic lights mean no trailer brakes or doesn't this kind have them? Sorry for not knowing more details except that it's a 1994 egg camper. But I'm trying to help an elderly lady- a stranger- so the roads are safer for all of us
Old 12-26-2017, 07:15 PM   #8
I use a homemade set ot temp lights similar to the magnetic lights. They have saved me more than once when using a borrowed trailer.
Old 12-26-2017, 07:59 PM   #9
Virginia
LSW: If this device will plug in To the connector on her tow vehicle, it does not have brakes.
Old 12-26-2017, 08:20 PM   #10
I keep one of those testers in each of my vehicles. It sure takes the guesswork out of troubleshooting trailer lights. Make sure to use your 20% off coupon whenever you go to Harbour Freight.
Old 12-26-2017, 10:01 PM   #11
MYTH
Old 12-26-2017, 10:04 PM   #12
tail, running and turn signal lights are very easy to trouble shoot. If you don't know how the cheapest thing you can do is take to some body that does know.
rereading the OP I would guess that the problem lies in the tow vehicle. If she bought it used it could be anyplace. Again somebody with right know how and right tools can make quick work of it.
Old 12-27-2017, 06:47 AM   #13
If you have one of the testers mentioned above you will know if the tow vehicle is the problem. Once you know that your tow vehicle is good you can look for the real problem.
Connections that are held together with wire nuts or crimp connections are almost always the problem on trailers.
With today's vehicles, just buy the ready made adaptor kit for most vehicles for trailer lights and almost every time you will have good connections on the vehicle. Just make sure to use the dielectric grease that comes with the kit to avoid corrosion within the connections which will cause future problems.
Old 12-27-2017, 10:31 AM   #14
Lsw
Trailer: Eggcamper
Wisconsin
Do I need a coupon or a code to get the 20% off harbor freight?
There is power all the way back to the lights inside the camper but only one of four work outside.
A mechanic said replacing the light means replacing the whole light assembly on each one.
So now I'm hunting for those as the local trailer repair place doesn't have any in stock.
Thank you for testing tool suggestions. Having the right tool makes things so much easier.
light, lights, tail lights
Tail lights, marker lights, reflectors jeroen Modifications, Alterations and Updates 15 10-30-2017 06:06 PM
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
New Tail Lights - Help! Chris73 Problem Solving | Owners Helping Owners 13 07-12-2006 10:43 AM
