Trillium 4500 (quebec) - Page 9 - Fiberglass RV
Old 04-28-2018, 05:51 PM   #113
Seaross's Avatar
Trailer: Trillium 4500
Today I was planning and thinking about how I was to install my 150watt solar panel. After looking at my rounded trillium roof I decided that the roof would need a bit more support and strength as to installing the 23lbs panel. I had just completed the inside and had not thought of placing support, so today I cut open the tissue to place support.
ID:	118381 lined up for cutting
ID:	118382 two places for support and attachment
ID:	118383 cut the material for plywood insert
ID:	118384 glued plywood to fiberglass and placed 1x2 supported by 2x2 for the time that glue will settle.
Seaross is offline   Reply With Quote
Old 04-28-2018, 06:29 PM   #114
Seaross's Avatar
Today I worked on electrical , placing smart pwm, batteries, converter , fuse distribution box, 300w inverter for ikea led lighting, 110v bar, etc . Still got a couple of days to complete all. Click image for larger version
Old 04-28-2018, 08:26 PM   #115
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
Good job Ross!
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 04-30-2018, 07:07 PM   #116
Seaross's Avatar
Installed 110v fridge , kitchen faucet, water pump, and lock for back fridge grill.
Old 05-01-2018, 04:57 PM   #117
Seaross's Avatar
Connection box for wire trailer running led lights to tow vehicle. Box on Side wall of fridge and access via outside lock vent.
Old 05-04-2018, 05:59 PM   #118
Seaross's Avatar
Can’t work outside because of bad weather, so started on the washroom.
Old 05-06-2018, 05:03 PM   #119
Seaross's Avatar
Nice weather, so installed 150watts solar panel on roof. Where I placed zinc coated carriage bolts through the roof I also placed marine gloozit.
ID:	118778 Click image for larger version
ID:	118779Click image for larger version
ID:	118780Click image for larger version
Old 05-07-2018, 05:16 PM   #120
Seaross's Avatar
Today continued on making my new washroom. Yes we will have a bathroom in our 15 foot trillium. It’s getting there.Click image for larger version
Built structure for glueing vinyl sheeting.
ID:	118833 vinyl sheeting
ID:	118834 measuring sheeting for glueing.
ID:	118835 clamping vinyl to bathroom vanity Click image for larger version
Placed and glued top portion of shower wall.
Across the shower is the toilet, will need to build black tank vent to roof and complete plumbing prior to finishing that wall.
Old 05-19-2018, 04:32 AM   #121
Seaross's Avatar
Today was a plumbing day, black tank exit with shower and sink.
ID:	119305 completed holes in bottom of floor.
ID:	119306 installed black tank outlet
ID:	119307 shower and sink drain will clean out after black tank trap.
ID:	119308 set outlet the best I could close to frame for ground clearance. Just hope it’s high enough.
ID:	119309black tank venting pipe via top wall exit.
Old 05-22-2018, 07:11 PM   #122
Trailer: Trillium 4500 1979
Quebec
Salut! Beau travail! Dis moi donc, où as-tu pris ton rail pour rideaux? Ta grille de ventilation pour l accès a ton frigo, tu as pris quelle model pour remplacer l'ancien?
inukjuak is offline   Reply With Quote
Old 05-23-2018, 04:09 AM   #123
Seaross's Avatar
La rail et de chez Ikea, la grille était déjà là seulement Pienture
Old 05-27-2018, 08:42 PM   #124
Quebec
WoW!
Magnifique travail! Je suis l'avancement du projet avec beaucoup d'intérêt!
lacastafiore is offline   Reply With Quote
Old 05-28-2018, 04:48 AM   #125
Seaross's Avatar
Old 05-31-2018, 07:34 PM   #126
Seaross's Avatar
Today did my installation for awning .........ok ok half awning ............. ok ok half umbrella.... but I like it and it’s easy to installClick image for larger version
ID:	119863Click image for larger version
ID:	119864Click image for larger version
trillium
QC | $5500 MONTREAL QUEBEC Trillium 1980 model 1300 Refait a neuf !!! je.bedard For Sale: Molded Fiberglass Travel Trailers 20 04-07-2016 03:18 PM
Southwestern Quebec Eastern Ontario 13ft Trillium wanted Joybell Wanted: Molded Fiberglass Travel Trailers 0 08-31-2012 02:50 PM
Trillium for sale kijjiji gatineau quebec Barrett family Referrals: Molded Fiberglass Trailers 0 07-31-2012 09:05 PM
Wanted: Trillium 13' in Ontario/Quebec MadgeW Wanted: Molded Fiberglass Travel Trailers 8 03-20-2012 11:22 AM
'79 Trillium Jubilee 4500 $5350, Otter Lake Quebec GlenP Classified Archives 0 04-17-2009 10:38 PM
