Trillium 4500 (quebec) - Page 6 - Fiberglass RV
Click Here to Login
Old 03-04-2018, 04:58 PM   #101
Seaross's Avatar
Trailer: Trillium 4500
Today worked on cabinets, table pull out and wine rack plus curtain railing around windows.
Seaross is offline   Reply With Quote
Old 03-04-2018, 05:02 PM   #102
Clayton's Avatar
Trailer: 1975 Trillium
Love the alloy curtain railing. Awesome idea.
Clayton is offline   Reply With Quote
Old 03-04-2018, 05:14 PM   #103
speakers
check out those speakers!!
bob
Old 03-13-2018, 04:42 PM   #104
Seaross's Avatar
Worked again on cabinets today.
ID:	116683 under sink tray drawer
ID:	116686 wood boxes
Will be able to pack inside house and just place in camper. Click image for larger version
I have much more space then I originally had.
Old 03-13-2018, 04:46 PM   #105
Are you going to add a lip to those cubbies to prevent the boxes from sliding out and dumping their contents?
Old 03-13-2018, 05:29 PM   #106
Seaross's Avatar
Still have not decided as how I will safely box them in . Thinking of having a pin lock on the back of the box. Putting a lip will wear out with time by pulling out the boxes. Unless having a lip that can come down.
Old 03-13-2018, 07:27 PM   #107
R A Mar's Avatar
Saskatchewan
Nice work!!
Rick
R A Mar is offline   Reply With Quote
Old 03-29-2018, 05:46 PM   #108
Seaross's Avatar
More cabinets.
Old 03-29-2018, 05:57 PM   #109
Seaross's Avatar
Also mounted spare on my trillium bumper.
Now just need to connect led lights.
Old 03-31-2018, 04:29 PM   #110
Seaross's Avatar
Installed antenna in window frame (did not want to put a hole in fiber. Connections at bottom.
Old 04-11-2018, 04:25 PM   #111
Seaross's Avatar
Today installed maxxfan. ✔️
Old 04-23-2018, 05:02 PM   #112
Seaross's Avatar
Today glued tissue to bed plywood, it’s now ready for a full ikea matrand mattress (54x75x8” thick) it’s coming together. Just can’t wait to start on washroom.
ID:	118111Click image for larger version
Old 04-28-2018, 05:51 PM   #113
Seaross's Avatar
Today I was planning and thinking about how I was to install my 150watt solar panel. After looking at my rounded trillium roof I decided that the roof would need a bit more support and strength as to installing the 23lbs panel. I had just completed the inside and had not thought of placing support, so today I cut open the tissue to place support.
ID:	118381 lined up for cutting
ID:	118382 two places for support and attachment
ID:	118383 cut the material for plywood insert
ID:	118384 glued plywood to fiberglass and placed 1x2 supported by 2x2 for the time that glue will settle.
Old 04-28-2018, 06:29 PM   #114
Seaross's Avatar
Today I worked on electrical , placing smart pwm, batteries, converter , fuse distribution box, 300w inverter for ikea led lighting, 110v bar, etc . Still got a couple of days to complete all. Click image for larger version
Old 04-28-2018, 08:26 PM   #115
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
Good job Ross!
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 04-30-2018, 07:07 PM   #116
Seaross's Avatar
Installed 110v fridge , kitchen faucet, water pump, and lock for back fridge grill.
Old 05-01-2018, 04:57 PM   #117
Seaross's Avatar
Connection box for wire trailer running led lights to tow vehicle. Box on Side wall of fridge and access via outside lock vent.
Old 05-04-2018, 05:59 PM   #118
Seaross's Avatar
Can’t work outside because of bad weather, so started on the washroom.
Old 05-06-2018, 05:03 PM   #119
Seaross's Avatar
Nice weather, so installed 150watts solar panel on roof. Where I placed zinc coated carriage bolts through the roof I also placed marine gloozit.
ID:	118778 Click image for larger version
ID:	118779Click image for larger version
ID:	118780Click image for larger version
Old 05-07-2018, 05:16 PM   #120
Seaross's Avatar
Today continued on making my new washroom. Yes we will have a bathroom in our 15 foot trillium. It’s getting there.Click image for larger version
Built structure for glueing vinyl sheeting.
ID:	118833 vinyl sheeting
ID:	118834 measuring sheeting for glueing.
ID:	118835 clamping vinyl to bathroom vanity Click image for larger version
Placed and glued top portion of shower wall.
Across the shower is the toilet, will need to build black tank vent to roof and complete plumbing prior to finishing that wall.
trillium
Trillium for sale kijjiji gatineau quebec Barrett family Referrals: Molded Fiberglass Trailers 0 07-31-2012 09:05 PM
'79 Trillium Jubilee 4500 $5350, Otter Lake Quebec GlenP Classified Archives 0 04-17-2009 10:38 PM
