Using top coat marine Rustoleum paint - Fiberglass RV
Old 10-22-2019, 01:56 PM   #1
Trailer: 2009 Monaco Holiday rambler Neptune
United States
We live in our motorhome full time , when using top coat marine rustoleum do you have to be out of your rv due to vapors ? How long ?
LPC1 is offline   Reply With Quote
Old 10-23-2019, 11:01 AM   #2
Is that the above water version or the below water version. I understand that the below water version has a lot of copper in it to keep barnacles at bay.
Lee
Captleemo is offline   Reply With Quote
Old 10-23-2019, 12:59 PM   #3
I suggest a careful read of the label. I’d also look for a nonVOC paint if you want to occupy immediately. And any primer may be an issue too!
Certainly the paint I used both as a primer and top coat on my cabinet doors, I would not have recommended for immediate occupancy. In fact I had the doors out of the trailer for all painting and prep work, as well as a long dry time.
I thought that the rustoleum top side was an exterior paint. As such they may have put less effort into VOC control.
I worked in the emulsion polymer business for years (the base for paint). Our low and zero VOC products were much more costly. So paint companies tended to go with the cheaper stuff whenever they could.
Old 10-23-2019, 02:45 PM   #4
TN
Most of the VOCs will flash off within the first hour. That's about 99.9%. The remainder will take anywhere from 24 to 48 hours depending on temperature and humidity. Once it is no longer tacky to the touch you should be good to go.
Eric Frye is offline   Reply With Quote
Old 10-24-2019, 02:19 PM   #5
Trailer: Scamp 2017 16-ft SD / FB
Top Coat Marine Rustoleum Paint
OK Have a question as this is a first for me.
Is Top Coat Marine Rustoleum Paint better than plain Rustoleum Paint?
If it a better paint why??
Henry
Houston TX
Scamp 2017 16ft FB/SD
Gattopuin64 is offline   Reply With Quote
Old 10-24-2019, 03:14 PM   #6
What is the application? Top side is exterior paint, meant to paint fiberglass boats above the water line. You are talking an interior of a motorhome, not a boat, nor the outside of a molded FG trailer. I can't imagine it being the best choice.
In the paint business, you pay extra for certain performance capabilities like boat, fiberglass, and exterior.
My vinyl covered fake wood cabinet doors, I used a primer and then cabinet paint.
Old 10-24-2019, 04:09 PM   #7
United States
I will be using this top coat marine rustoleum to paint my fiberglass roof on my motorhome, I was just wondering if there was toxic vapors and if we needed to stay out of motorhome for a few days ?
Old 10-26-2019, 06:20 AM   #8
TN
The difference is that the Marine paint will self level better leaving a smother / shinier surface.
Old 10-30-2019, 01:39 PM   #9
Iowa
I just used Rustoleum topside paint with a 4” foam roller and was impressed with the shine. There was some odor initially but not overwhelming. As long as it’s exterior, you shouldn’t have any issues. You do have to lay it down consistently -not too thin or thick -and keep moving. Once it levels don’t touch it until it dries otherwise you will dull the shine. Light sanding/clean between coats will ensure a good shine.
Scamp-13 is offline   Reply With Quote
Old 10-30-2019, 02:08 PM   #10
Kai in Seattle's Avatar
Yes, topside paint is better for fiberglass than regular Rustoleum paint. It's more flexible, for one thing.
Give it an hour or wo to fume off. The final residual fumes can take months to dissipate...but as some have pointed out, it's a very minimal residual.
I'd be inclined to paint it in the summer or when you can leave a window partly open all the time for a while...but chances are good it's not going to even make you sick briefly.
We love using Rustoleum Topside paint. And it's UV resistant, too. And it self-levels nicely. And it has a nice gloss but isn't overly shiny. You can mix the colors, too. No problem.
BEST
"K
Semper ubi sub ubi.
Kai in Seattle is online now   Reply With Quote
Old 10-31-2019, 10:25 AM   #11
Quebec
Rustoleum Marine Top Coat
Is that gel coat? From what you describe, it seems to be gel coat, such as we use for boat topsides. Gel coat has a smell, and it will take longer to vent out if it gets into porous surfaces, such as cushions or mattresses.
My advice would be to take out as much textile as possible: curtains, cushions, pillows, and the like. Move them to your car if you can, anywhere dry will do. Paint away, and don't re-touch the paint/gel coat once it's applied. Once it's no longer tacky (the can label will tell you how long that takes), you can bring back the mattresses and cushions etc.
That's how we did it in our sailboat, which, when you think of it, is no different than a trailer. Except for the wheels. And the sail. And the car. And...
dsalvail is offline   Reply With Quote
paint
Rustoleum topside paint Tonnie Problem Solving | Owners Helping Owners 25 06-20-2017 04:55 PM
Rustoleum Topside thinning Seldomseensmith Problem Solving | Owners Helping Owners 11 04-03-2016 12:04 AM
Rustoleum marine topside paint davb Modifications, Alterations and Updates 11 08-24-2014 11:33 PM
Rustoleum Paint for Fiberglass Peter_Crowl Care and Feeding of Molded Fiberglass Trailers 6 06-02-2011 07:45 AM
Gel coat restoration using Penetrol John & Sandy M Care and Feeding of Molded Fiberglass Trailers 2 04-30-2006 07:05 AM
