Went on an Egg hunt & found this! - Fiberglass RV
Old 03-26-2013, 06:09 PM   #1
luvrOlife's Avatar
Trailer: UHaul
I'm SO happy! It's been over 5 years of searching for The fiberglass trailer. I was looking for a Burro or Casita...and then via this board I learned about uHauls and my heart went a flutter. See a hundred years ago I was going to rent one on a trip to Gatlinburg. Our plans changed so we never did...but I never forgot about the lil Egg trailer. I thought it was a Burro, but learned here of its own special history.
Picked her up in Tehachapi, CA on Saturday. Spent the night in her before heading home to the SF bay area Sunday. My TV is a 2011 Ford Escape V6 that gets 26 mpg. With the 1985 CT I get 23.5 mpg. At one point I noticed that I was going over 80 miles per hour, passing a a convoy of big rigs. I decided to slow down a bit. I hardly noticed she was back there. She's in good enough shape to camp in this summer. I'm going to pack the wheel bearings tomorrow and fix the window seals. Other than that she's good enough to go. But definitely a project for next winter!
Did I mention that I'm pretty happy!
-Vanessa
....no matter where you go, there you are!
luvrOlife is offline   Reply With Quote
Old 03-26-2013, 06:17 PM   #2
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Welcome to the UHaul club. They are a great little trailer and I'm sure you'll love it.
No you aren't. UHaul uses an automotive type sealed bearing hub that is lubed for life - don't even try to get it apart.
Lots of good information here on windows. Use the Google search function at the bottom of the search pull down
Old 03-26-2013, 06:21 PM   #3
Thomas G.'s Avatar
P.S. The curtains look original. We have a forum member looking for original curtains if you decide to "upgrade".
Old 03-26-2013, 08:03 PM   #4
luvrOlife's Avatar
Trailer: UHaul
Whoopsie! Wish I'd have seen your post a wee bit sooner. Ha...dropped the trailer off at the shop... I didn't bother to remove the hubcaps to check. Guess I'll find out what kind of mechanic I really have. ;-p
There IS great info here! I've learned so much lurking about in such a short time...and even found my Pearl here!
I did see where Julie, if I recall her name correctly, posted about the window seals...what a mensch that gurl is!
Thanks for your support, Tom! You're a Font of Knowledge (-:
-Vanessa
Old 03-26-2013, 08:05 PM   #5
Pam Garlow's Avatar
Trailer: U-Haul 1985
Hi, Vanessa, I love my UH too I've had it for about 6 years and really enjoy camping in it. I've put a lot of girly fru-fru stuff into it. And you do not have to pack your bearings, just like Tom said.
Old 03-26-2013, 08:42 PM   #6
If it has the original Uhaul hubcaps, they are rare. Rumor is that Uhaul removed them in order to make it easier to check lug nuts. Bridget T had a good report on rebuilding the windows, however I disagree on her recommendation as to what weatherstrip to use. I'll leave that decision to you.
Old 03-26-2013, 08:45 PM   #7
Just noticed, looks like the furnace vent is gone and a flat cover there? Has the furnace been removed?
Old 03-26-2013, 09:01 PM   #8
carlkeigley's Avatar
NE Oklahoma
Welcome to the Forum.
Looks like you've made a great find.
Congratulations.
Old 03-26-2013, 09:43 PM   #9
Mike Magee's Avatar
Trailer: Li'l Hauley
I'm curious about those sealed hubs. I know that over time just about any grease will dry out and get stiff. At some point, if the hub can't be re-greased, doesn't it have to be replaced? Just wondering how long it will last.
In the '60s, people took LSD to make the world seem weird.
Now the world is weird, and people take Prozac to make it seem normal.
Old 03-26-2013, 10:31 PM   #10
Trailer: 1978 Trillium 4500
Make sure you check the lug nut tightness. Folks have had wheels pop off on the road.
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 03-26-2013, 10:53 PM   #11
Trailer: '77 Scamp
Your little trailer is so cute Vanessa. You'll have a lot of fun with her. I'm in Pleasanton. Where are you located? Let me know if you like the place you took the trailer. I need to take the Scamp in and I'm looking for a competent person. And if they tell you they repacked the bearings--well I won't be going there.
Happy Trails!
Linda
Otters is offline   Reply With Quote
Old 03-27-2013, 03:21 AM   #12
Pam Garlow's Avatar
The UHaul production happened in the 80's, with most UHauls titled as 1984-85. My tire guy has checked my hubs when changing the tires, and says that they're still fine. I suppose at the time they start to go, I'll also consider changing the whole axle so that I'm not locked into this type of hub (including the proprietary nature of the UHaul rim/tire relationship).
Old 03-27-2013, 05:47 AM   #13
Mike: Since they are a moving mechanical part they are certainly subject to failure by a variety of causes such as deterioration of the grease, load conditions, or road hazards. I've only seen a couple sealed hub failures when I worked on big trucks, but they were not commonly used either. I've heard of one Uhaul hub failure that I believe was on Cindy & Kevins trailer. Since the bearings can not be disassembled and visually inspected, it's hard to determine their condition. Without expensive test equipment the only means is to check for play and roughness when spinning the wheel, and the start of a failure is difficult to detect. I'll jack up our trailer a few times a year and check the bearings. I also have a spare set of hubs that I have carried with me on trips, I'll probably just install them this year due to the age of the trailer. Much easier to do it at home than on the road. Since the Uhauls were built for rental use and long life, no doubt the hubs are plenty heavy for the weight of the trailer.
Old 03-27-2013, 07:14 AM   #14
Trailer: 1971 hunter compact jr
Talking
Isn't it great I love my lil hunter but if I find me one I want a u haul too . I wasa wanderin if u found u a camper then there it is.u haul city baby I'm green with envy and proud for u at tha same time . The hunt is over now make it your own. Enjoy
frankie is offline   Reply With Quote
I think I've found my EGG!! Rvicsvol General Chat 10 03-15-2012 04:44 PM
Our egg hunt Raz General Chat 16 05-19-2010 07:29 PM
An Egg Hunt melissab General Chat 12 12-12-2009 12:44 PM
We found our egg! DonInChatt General Chat 33 01-27-2007 09:22 PM
