What to look for on older Scamp - Fiberglass RV
Old 09-27-2012, 07:04 AM   #1
Trailer: 96 Scamp 13'
Hi, I just discovered The egg type trailers. I have only looked at one and am going this morning to see a 1987 13' Scamp that is claimed to have only been slept in 3 times and in storage. I have not been able to get any model info.Any suggestions on what to look for on a unit like this. An advice would be appreciated. What would be a fair price for a unit like this that is claimed to be in pristine condition?
les c is offline   Reply With Quote
Old 09-27-2012, 11:04 AM   #2
Trailer: scamp 13
um....money under the cushions?
just look at the obvious, over all condition will tell you a lot.
look for leaks, rusty appliances. other wise depending on price theres almost always some little thing you will need to fix,,,sccrew loose leaky fawcet, that sort of stuff.
shouldn't be much more then lots of cleaning on one with so little use.
Do not neglect to show hospitality to strangers, for by doing so, some have entertained angels unaware.
Old 09-27-2012, 11:06 AM   #3
Trailer: scamp 13
oh,,, check the forsale section to see what prices they get. i can tell you these little guys hold value better then stcik built aluminium trailers. but maybe they don;t know that.
Old 09-27-2012, 04:31 PM   #4
Roy in TO's Avatar
Hey Les,
Welcome!
Download the buyers checklist from here and go look at it.
Fiberglass RV - Document Center - Buyers Check List
You can search for historical asking prices on both http://www.fiberglass-rv-4sale.com/node and http://www.fiberglassrv.com/forums/f80/
Old 09-27-2012, 05:17 PM   #5
Hi Les, welcome to FiberglassRV. We're glad you're here .
You'll find lots of kind, helpful people here at FiberglassRV to answer all your egg questions
Old 09-27-2012, 09:36 PM   #6
Thanks to all for your responses.
Old 10-04-2012, 06:07 PM   #7
chse's Avatar
Trailer: 13' Scamp
Hi-
I just bought a 13' scamp. I think first you will have to decide how much fixing you want to do - if you want one you can immediately take on the road you will have to invest some money (around $5000 for a basic 10 year old without flaws would be a very good price)- and maybe you should consider a new one - their prices are quite stable.
Things I saw several times:
Rotten spots in the floor- mostly from leaking windows: Bring a screwdriver or small fashlight and knock with the handle on all areas of the floor from below (take your time this is important) see if the sound changes and gets soft in some spots indicating rot. If the rotten area is small you can fix it but if it is larger you will need a new floor - which is a major fix and will require several weeks of work. Mostly there is more rot on the inside than you can detect from underneath, scratch on the wood to see how big the area is. Next you will have to find out were the water came from- if it is from a screwed in window the fix is relatively easy - but harder from one which has only a gasket (like most front windows). Sometimes it is just dirt in the windows drains. The rotten areas I found were either under the side windows or under the fridge.
Is there a damp smell in the camper - indicating a leak (and rot)? How is the smell inside the cabinets? Are there critters - and damage from them?
Are the cushions in good shape and firm, you will sleep on them so soft, dirty, smelly cushions are not good (a new set is $525, the covers are $290).
Look if the rivets still have intact seals- this is an easy fix.
Is there rust on the metal parts- do they have to be replaced, painted?
What is the age of the tires (there is a code to find that out) - they should be replaced every 6-10 years. New tires with rims are $100-150.
Don't forget to see if the axle is sagging- look at some pictures here of newer scamps (or at scamptrailers.com)- if the tires disappear in the wheel house the axle is worn. Axles are not to expensive to replace.
Does the seller try to cover up flaws? Are all the windows open when you arrive at the camper (to get the rotten smell out), are the tires covered with tire shine? Was the camper not used for the last years- often that means that it was not looked at at in the last years, too and leaks went undetected causing major damage. Was it parked under a roof or in the open most of its live?
Will you need a title to register it and does the owner have a title? If you do not need a title does it have a certificate of origin- if you ever sell it this will be required in some states to apply for a title (and drastically can increase the resell value).
Before buying I tried to get an idea how much time for fixes will be require (mostly by reading posts here), and if they can be done (have a look at the spare part list at scamptrailer.com). I did not find the checklist to useful I rather tried to calculate how long it will take me to get a camper ready to use- from that I estimated the price I am wiling to pay.
chse is offline   Reply With Quote
Old 10-04-2012, 06:10 PM   #8
The check list is just a reminder of things to check (for sure). Sometimes folks get so excited they forget those very important items... like where to find the VIN!
Old 10-04-2012, 06:26 PM   #9
chse's Avatar
Trailer: 13' Scamp
I guess this came out wrong- I went over the checklist before I went to see a trailer (it lists problem spots very nicely), but really filling it out when buying one was a bit much for me- for me the overall appearance was most important.
And yes- most importantly - do not get excited and be prepared to walk away without even making an offer if you feel a trailer was cared for badly.
Wanted - Older 13' Scamp, Boler type near OH techdesigner Wanted: Molded Fiberglass Travel Trailers 1 08-04-2012 11:38 AM
New (Older) Scamp Owner, New Member Harvey Hi, I am.... 12 02-06-2011 09:34 PM
FOUND - Wanted-13'-16' SCAMP/BOLER OLDER, 74-85 Amanda O Wanted: Molded Fiberglass Travel Trailers 5 05-04-2010 07:39 AM
Older Scamp Trailers..what do you think... jimtesla General Chat 14 08-13-2009 10:22 PM
