Axle Seals for #3500 Axles - Fiberglass RV
Old 07-31-2012, 11:28 PM   #1
Deb & Chuck's Avatar
Name: Deb & Chuck
Trailer: Bigfoot (8), Boler, Trillium, ECO, U-Haul, Burro, Escape (3), Trailswest, Compact Jr., Casita, Scamp
Axle wheel seals for #3500 pound axles found on Bigfoot and Escape dual axle trailers. When repacking wheel bearings you should replace the axle seals.
Deb & Chuck is offline   Reply With Quote
Old 08-01-2012, 04:53 AM   #2
Trailer: 2014 Escape 21
Virginia
Are these double lip seals like used on the Alko and Dexter EZ lube 3500# axle? What is the I.D and O.D. of the seals?
Thanks Eddie
Old 08-01-2012, 09:30 AM   #3
IllAnnoy
If you repack your bearings by hand every year, then you should be fine with inspecting and replacing only worn or defective seals.
Some extraction methods do destroy the seals though, then(of course) they must be replaced.
Clean the seal and look closely, the seal usually has a part #, either stamped in the metal or molded into the neoprene.
Old 08-01-2012, 09:45 AM   #4
Trailer: Helite
Due to the labor involved I always put in new seals.
Art VanDelay is offline   Reply With Quote
Old 08-01-2012, 10:49 AM   #5
LOL due to lack of finesse in the extraction method the seals always need replacing
Old 08-01-2012, 05:31 PM   #6
Trailer: Casita 17 ft DLX SD
Removing seals
Floyd;
When I had the Scamp factory replace my axle they told me to repack (grease) the bearings every 10,000 miles or once a year (which ever comes first). They told me the type of grease to use and to always replace the seals. I have repacked my boat trailer bearings , inspected the seals and replaced them only when necessary. Is it possible for you to describe the right and wrong way to remove Scamp seals? I would think you could remove and inspect the seals without destroying them if one new the proper procedure
Thanks Steve D
Old 08-01-2012, 07:44 PM   #7
IllAnnoy
Originally Posted by steve dunham View Post
Floyd;
Thanks Steve D
Once the hub is removed and the outboard bearing is out of the way, you simply place the hub, with the inboard side down, on a solid surface with clearance under the seal. Get take a hardwood dowel or an old piece of hardwood broom handle (I keep a hickory hammer handle for this purpose).
Insert the dowel through the outboard side of the hub at an angle sufficient to catch the inner race on the inboard bearing. Sharply and adroitly strike the end of the dowel with a small hammer. The bearing will be ejected taking the seal with it, without harm to either part.
axle
u haul axles h.mike Towing, Hitching, Axles and Running Gear 5 01-21-2012 08:13 AM
Window Seals Pamela McBroome Care and Feeding of Molded Fiberglass Trailers 6 05-07-2010 10:48 PM
al-ko axles Dan B Problem Solving | Owners Helping Owners 2 06-02-2008 10:44 PM
Seals for windows Faith Problem Solving | Owners Helping Owners 2 02-14-2006 07:45 AM
Double Axles Legacy Posts Care and Feeding of Molded Fiberglass Trailers 26 06-15-2003 01:37 PM
