Kevlar Carbon Hybrid Cutting Scissors - Fiberglass RV
Old 08-11-2015, 03:16 AM   #1
Trailer: none
(China)
WBT-1 electric scissors are lightweight & easy to use. Capable of cutting composite materials glass fiber, carbon fiber, aramid fiber, knitting, clothing, leather, carpet, plastics etc many fields. Rechargeable battery and two blades included.
1.regardless right&left handed
2.lightweight & easy to use
3.chargeable and electric plugged
4.tungsten steel blade
5.continuous work capacity
The below are two operation videos ,if interesting could have a check first :
(video for cutting various materials)
(Special for cutting composite materials )
rnuo2011 is offline
Old 08-11-2015, 10:01 AM   #2
Trailer:
Yeah, if you want to know why bulletproof vests are made from Kevlar/aramid, try cutting Kevlar cloth with regular scissors - it just doesn't work. Sharp scissors will cut carbon fiber (and of course glass fiber) cloth (ie, before resin added) but they just skid off aramid.
Andrew Gibbens is offline
Old 08-12-2015, 09:38 PM   #3
Trailer: none
(China)
Smile
Obvious ,a good pair of electric scissors is a pleasure to use. Opposite a bad pair of scissors is miserable and ineffective.
there are many similar products in market ,
some scissors is just for cutting fabric ,but some brands can even cut fiberglass ,carbon,Kevlar /aramin . maybe it can not killed in a row.
rnuo2011 is offline
Old 08-13-2015, 12:00 AM   #4
Trailer: none
(China)
Smile How to fiberglass vehicle
If you've purchased a fiberglass kit, you'll need to know how to work with these materials or else things are about to get a little messy. The first step is building your mold, and then you can move onto preparing your fiberglass cloth and working with the hardener.
Do the mold, prepare the fiberglass mat or cloth in sheets cut to suitable sizes to cover your form
Then need a good helper for cutting the fiberglass , like WBT-1electric scissors are specifically designed to cut tough fabrics like Aramid, Kevlar, carbon fiber cloth and more.
rnuo2011 is offline
Old 08-13-2015, 11:20 AM   #5
Trailer: Shopping for new RV
Be prepared to work fast as the epoxy compound tends to harden in short order!
If you follow directions you will discover the process is easy.
Uplander is offline
Old 10-28-2015, 09:21 PM   #6
Trailer: none
(China)
Fiberglass is used for many products
Fiberglass (or fibreglass) is a type of fiber reinforced plastic where the reinforcement fiber is specifically glass fiber. The glass fiber may be randomly arranged, flattened into a sheet (called a chopped strand mat), or woven into a fabric. The plastic matrix may be a thermosetting plastic- most often epoxy, polyester resin- or vinylester, or a thermoplastic.
The glass fibers are made of various types of glass depending upon the fiberglass use. These glasses all contain silica or silicate, with varying amounts of oxides of calcium, magnesium, and sometimes boron. To be used in fiberglass, glass fibers have to be made with very low levels of defects.
Fiberglass is a strong lightweight material and is used for many products. Although it is not as strong and stiff as composites based on carbon fiber, it is less brittle, and its raw materials are much cheaper. Its bulk strength and weight are also better than many metals, and it can be more readily molded into complex shapes. Applications of fiberglass include aircraft, boats, automobiles, bath tubs and enclosures, swimming pools, hot tubs, septic tanks, water tanks, roofing, pipes, cladding, casts, surfboards, and external door skins.
carbon fiber, kevlar fiber,fiber scissors, WBT-1electric scissors , fiberglass woven roving,fiberglass mat,fiberglass yarn
rnuo2011 is offline
carbon fabric scissors, fiberglass scissors
Carbon Monoxide Measurements Parker Buckley Problem Solving | Owners Helping Owners 23 03-04-2009 06:36 PM
New carbon tax CharlynnT Money Matters 6 03-09-2008 03:42 PM
carbon monoxide alarm Christi V. Problem Solving | Owners Helping Owners 3 04-18-2006 08:26 AM
Propane detector and Carbon Monoxide detector. Yves Pelchat Problem Solving | Owners Helping Owners 6 02-05-2006 10:28 PM
carbon monixide alarm General Chat 0 01-01-1970 12:00 AM
