NEW BOLER HARDWARE - boler Repair Parts - Fiberglass RV
Old 03-17-2018, 09:59 AM   #1
Ian G.'s Avatar
Spring is just around the corner and it’s time to get your trailer ready, at Camping Treasures we have the best parts you can get for your boler. (click on the bold title to link to our store)
DOOR HINGE REPAIR KIT, No need to replace your hinges, rebuild them and they will be better than new. If the door hinges on your Boler or Scamp trailer worn out or if the bolt or spring are broken or rusted our Stainless Steel Door Hinge Repair Kit is the solution
These kits contain the highest quality parts at a reasonable price that won’t rust and will last for many years?
The kit includes everything you will need to rebuild both hinges, one kit is all you need for your trailer:
  • 2 – solid brass pivot balls (made in USA)
  • 2 – 316 stainless steel bolts
  • 2 – 316 stainless steel nylock nuts
  • 2 – 316 stainless steel springs (made in Canada)
  • 4 – nylon isolation washers
  • Synthetic Teflon assembly lube
DOOR LOCK REPLACEMENT KIT. Our door lock kit is designed to replace the discontinued Bargman L400 and Lyster 20-213 / 20-214 door locks found on many vintage trailers
Using common tools the average DIY’er can replace their door lock with a modern Bauer lockset with deadbolt.
Our complete kit includes:
  • 1 – Bauer Door lock, packaged (available in White or Chrome)
  • 1 – Inner Aluminum Adapter Plate
  • 1 – Outer Aluminum Adapter Plate
  • 1 – Aluminum Striker Plate
  • 2 – #8-32x” Pan Head Machine Screws
  • 4 – #8-32x” Pan Head Machine Screws
  • 4 – #8-321” Pan Head Machine Screws
  • 2 – #10-24x” Flat Head Machine Screws
  • 2 – #10 Flat Washers
  • 2 – #10-24 Nuts
  • 6 – ⅛” Aluminum Rivets
  • 1 roll – Butyl Sealing Tape
  • 1 pair – Disposable Gloves
  • 1 – Dust Mask
Upgrade your door lock today at an incredibly low price
JALOUSIE WINDOW OPERATOR - Worn or broken Jalousie Window Torque Rod Operator can result in windows that don’t close completely, are hard to open, won’t open at all, or flap in the wind while driving. Although several different styles of operators were used on boler’s this one is very common. They fit both dinette windows on most boler’s with the sloping lower sill, but also fits many other trailers manufactured in the 1970’s
Buy now while supplies last. These operators have been very hard to find, but we had the manufacturer custom make us a supply, we recommend that if you need them don’t wait.
Specifications:
  • 1/2 Inch inner diameter hole
  • 11/16 Inch hub projection
  • Fit both windows where the operator is located on the bottom right side
WINDOW GRAVEL GUARD HARDWARE – in Stainless Steel - Camping Treasures now offers high quality stainless steel hangers and latches.
Our Stainless Steel Hardware kit includes:
  • 2 – Stainless steel latches with an integrated safety catch that prevents accidental opening (made in in the UK)
  • 2 – Stainless steel hangers that are easy to use and very strong
**We recommend you also purchase our optional rivet kit is made from high quality, aircraft grade, full stainless steel rivets (even the pin is stainless steel) and stainless steel backing washers and includes:
  • 8 – 5/32” stainless steel pop rivets (w/ stainless steel pins)
  • 8 – 5/32” stainless steel pop rivet backing washers
  • 8 – 3/16” stainless steel pop rivets (w/ stainless steel pins)
  • 8 – 3/16” stainless steel pop rivet backing washers
NOTE: You will need a heavy duty or long handle rivet gun to install the 3/16″ rivets, a standard rivet gun will not set the mandrel.
Visit the Camping Treasure Store to see all our full selection of Key Chains, Necklaces, Earrings, WIne Glass Charms, and Accessories.
Don't forget to buy your tickets to the "boler 50th Anniversary Caravan and Event" tickets are only sold in advance (not available at the event). Make sure you don't miss this once in a lifetime event www.MyBoler.com
Ian G. is offline
Old 03-17-2018, 06:22 PM   #2
mensie's Avatar
Just received my door hinge repair kit.
Thanks Ian.
mensie is offline
Old 03-18-2018, 07:43 AM   #3
Ian G.'s Avatar
Thanks Ian.
Great, thank you for letting me know
If you have any questions on installing them please let me know.
Ian G. is offline
boler
Free: Boler 1700 (79) Bunk Hardware Crackedegg Parts: Buy | Sell | Trade 1 02-22-2015 02:42 PM
Boler - cabinet hardware...where to buy? Natalie M. Problem Solving | Owners Helping Owners 9 09-09-2012 08:18 PM
Wanted: 1978 Trillium 1300 Parts - Replacement Hatch w/fan, hub caps, Door Hardware.... Perseustheegg Parts: Buy | Sell | Trade 1 08-17-2012 05:04 PM
Parts Parts Parts Ken Gronsdahl Classified Archives 5 07-06-2008 11:05 AM
1974 Boler Door Hardware Johnathan Gallant Problem Solving | Owners Helping Owners 1 04-10-2008 07:50 PM
