Advice on Renogy 100W Mobile Solar Panel - Page 2 - Fiberglass RV
Old 09-26-2016, 05:19 PM   #15
Trailer: in the market
I was looking at the renogy solar panels online. they have two different types is one type better that the other, are they meant for different applications?
Judy Too is offline   Reply With Quote
Old 09-26-2016, 05:38 PM   #16
sokhapkin's Avatar
SW Florida
They offer only 1 foldable monocrystalline 100W panel type. With a built in solar charge controller (if your setup doesn't have one already) or without the controller (if you have one already installed in your trailer).
Sergey
www.callwithus.com
sokhapkin is online now   Reply With Quote
Old 09-26-2016, 07:31 PM   #17
I am going to get one or two for the roof and then a foldable one to put out when I need more energy. just what to get the right ones. where do you get the 3M tape. I have not seen it on the renogy site.
Old 09-27-2016, 05:36 AM   #18
Originally Posted by Judy Too View Post
...where do you get the 3M tape. I have not seen it on the renogy site.
I would not use VHB tape except maybe for flat flexible type panels, but using flat flexible panels would not be my first choice either. Thats just me.
There are different types of VHB tape and different sizes and thicknesses. It is important to match the tape to the project.
So... if you do want to try VHB tape then I suggest you do a lot of reading up on it first. I would start here and be sure to read the technical reports.
And then I would read this thread... all 525 posts.
Old 11-15-2016, 04:05 PM   #19
Trailer: 2008 OutBack 13ft., Camp Inn 560
Illinois
Originally Posted by Gilles View Post
I have installed a 100 watt Monocrystalline Renogy with 30 amp controller and thread # 10, if necessary I can add on the roof 2 Pannels additional 100 watts without replacement wire or controller.
Installed this spring 2016, without making holes in the roof, attached with VHB Tape (UV protection) 3M and protected against dust and water, a light UV silicone gasket.
The wires passes into the fan of the bathroom, no holes in the roof to insert the wire ...
I live near Montreal and I traveled to Maryland, then in Gaspesie then the Mingan Islands and the sign still stands.
I check occasionally and it remains securely attached.
I followed the instructions from these videos:
David O. is offline   Reply With Quote
solar, solar panel
Renogy Solar on sale ruscal Electrical | Charging, Systems, Solar and Generators 7 06-18-2015 07:29 AM
New Mobile browsing option | Mobile skin Janet H Forum Admin, News & Announcements 4 03-02-2015 06:19 PM
Portable solar charger from Renogy ruscal Electrical | Charging, Systems, Solar and Generators 43 09-09-2014 08:45 AM
Renogy 100 Watt Bendable Solar Panel Huck Modifications, Alterations and Updates 11 07-26-2014 06:53 AM
