Wanted: Need Scamp door lock - Fiberglass RV
Old 06-26-2018, 08:12 AM   #1
Hopper's Avatar
Indiana
I am in need of 13’ Scamp door lock.
Hopper is offline
Old 06-26-2018, 08:25 AM   #2
Scamp is one source. They have both the outside handle part and the inside latch mechanism.
If it's only the outside lever handle you need, I found an identical replacement at a local RV shop. You can also use a square shaft garage door handle from any hardware store. They come in both T-handle and L-handle styles. You'll have to cut the square shaft to length.
Jon in AZ is offline
Old 06-26-2018, 08:30 AM   #3
Need more details, but assuming it is not a 2018....
If you just need the external handle with the lock and key, you can buy it at your local hardware store. It is a common garage door handle.
Also a truck topper handle will fit , but it is usually a "T" handle.
Of course Scamp still has them, both inside and out as a kit.
https://www.scamptrailers.com/parts-...le-detail.html
floyd is offline
Old 06-26-2018, 10:31 AM   #4
Hopper's Avatar
Indiana
Good to know
Hopper is offline
Trillium 4500: Need replacement door lock/latch Laurie Problem Solving | Owners Helping Owners 19 05-25-2022 02:20 PM
Query about door lock to lock from inside sara maccalman Problem Solving | Owners Helping Owners 4 11-14-2010 07:11 AM
Find replacement Scamp door latch/lock Faith Problem Solving | Owners Helping Owners 2 11-02-2006 06:45 AM
Removing door handle and lock on 13' Scamp Gary Little Problem Solving | Owners Helping Owners 14 02-09-2006 08:58 PM
