Electric only Scamp - Fiberglass RV
Old 03-06-2019, 08:42 PM   #1
Wisconsin
Electric only Scamp
Id like to have my propane heater, fridge and stove removed from my 1981 Scamp. I wonder if anyone can give me an idea of what it might cost? Where should I begin looking for someone qualified to do it?
Helga in WI is offline   Reply With Quote
Old 03-06-2019, 08:50 PM   #2
Find someone who wants it and it could be free. Of course you will need to patch outside of trailer where furnace vented.
You might even consider an ad in the for sale section: free appliances if you remove.
Mobile RV service around here is about $75/hour. Id guess 4 hours, but that’s just a guess.
Old 03-06-2019, 10:28 PM   #3
If there is an RV used parts business nearby and the items you want to remove are in working condition and can be resold then they might remove them for a small fee.
But you could also try contacting a local mobile RV service and if they are in good condition for reuse negotiate the price for removal down to something reasonable by including the appliances as part of the service fee.
Old 03-07-2019, 10:38 AM   #4
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Perhaps all it takes is to remove the LP tank(s) on the hitch, the stove top, and heater. The LP piping could be capped off and left in place, in case a future owner would want to restore it. The Fridge can be operated on 12V and 120V so no need to revise that, unless you want to install a compressor type fridge.
Old 03-07-2019, 11:10 AM   #5
You may have partially answered a question/issue I've been dealing with, but I would appreciate your thoughts. I have a '07 Scamp 13 I bought used. The previous owner had an aversion to propane; so, they had the stovetop removed as well as the propane furnace; then they resurfaced the counter top. The outside propane tank is Not connected to the Scamp. Underneath the counteer top are the 2 copper tubings, UNCAPPED that went to the stove & furnace.
What I want to do:
1. Cap only one of the tubes; I have no intention of installing a propane furnace. How is this done safely?
2. I would like to have an adapter attached to the other copper propane tube so I could connect a propane hose to it to go to my Coleman 2-burner camping stove which I will use in lieu of the traditional stove top. Is this feasible/possible & what is involved or what is the best way to go about this?
Thanx in advance for any help/advice you can provide.
Best,
Richard Goudeau
rjg433 is offline   Reply With Quote
Old 03-07-2019, 11:15 AM   #6
Originally Posted by Helga in WI View Post
I’d like to have my propane heater, fridge and stove removed from my 1981 Scamp. I wonder if anyone can give me an idea of what it might cost? Where should I begin looking for someone qualified to do it?
Removal is pretty easy and any good DIYer can handle that in a day. But if you are planning on restoring the many left over holes, then figure $1,500 - $2, 000 or so. A boat shop or some auto body shops could do the fiberglass restoration. Or you can do like I did and go back to Scamp HQ in Backus, MN.
Old 03-07-2019, 11:30 AM   #7
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
Originally Posted by rjg433 View Post
What I want to do:...
I suggest you start a new thread rather that try to hijack Helga's thread.
I'm not saying you'll get a response but her wanting total removal is a different issue than what you are pursuing...
Without adult supervision...
Also,
Old 03-07-2019, 11:57 AM   #8
Trailer: Parkliner
Iowa
What I want to do:
Best,
Richard Goudeau
Any good hardware store should have plugs or caps to fit the open ends of the propane tubes. All ends should be plugged to keep dirt and bugs out.
Also, an extension hose for your stove should be readily available.
Best to go direct from the tank, but, some campers do have an outside LP outlet.
Old 03-07-2019, 12:50 PM   #9
If you were close enough i would do it for what i am taking out. I am in Western NY
kayaker51 is offline   Reply With Quote
Old 03-07-2019, 02:54 PM   #10
Timber Wolf's Avatar
North Florida
I did this to my 1988 Scamp. Plugged or capped the propane lines with the appropriate fittings from Home Depot. I left the lines as I (or someone else) might want to reuse them in the future. I installed a Truckfridge for refrigeration, cook outside, and on those rare occasions I need heat I use a Little Buddy. I plan on installing a Propex heater at some point and use an "insta-hot" water heater someday. In the meantime we heat water on the Coleman in two tea kettles bought cheap at flea markets.
The heater vent holes were closed with a piece of copper sheet and caulk behind the existing Suburban plate. The copper is tarnished and is dark enough that you can't tell it from the old rusty pipes that used to be there. The water heater hole was enlarged and closed with an RV access door bought off ebay. Having the access from the outside is nice! No regrets in making our Scamp suit us and our way of camping and removing decades old appliances.
Only Scamp I have every seen like this.. Gary Little Problem Solving | Owners Helping Owners 14 05-10-2017 08:17 PM
Propane & Electric vs Just Electric Wallo Care and Feeding of Molded Fiberglass Trailers 75 03-06-2014 06:24 PM
1998 Scamp 13 ft Ebay only 3 days left Robin G Classified Archives 0 08-26-2009 08:15 PM
All electric, or gas and electric? Homer Teitsma Electrical | Charging, Systems, Solar and Generators 24 10-07-2007 11:10 AM
» Trailer Showcase
Scamp
bippygma
1985 Scamp
rojo
