Help...Bigfoot...Rare..please help! - Fiberglass RV
Go Back   Fiberglass RV > Fiberglass RV Community Forums > Money Matters
Old 05-01-2010, 06:32 PM   #1
Trailer: Boler and Bigfoot
I have never posted here, but have certainly hung out here for info!
Very intertaining and appreciated.... THANKS!
Having said that, I now really need some help (advice)
To give a bit of a back ground, I have owned several "molded fiberglass rv's
13' boler, 15' Trillium, 17'Boler. 19' Bigfoot. So I am no stranger, but no expert??
Now here's my problem, I'm looking at another Bigfoot.... 5'er...
Its a long distance purchase so I have only seen digital images....
Its a 26.5 ft Bigfoot a 1994 and it weighs 4000 lbs dry...
I have never heard of .. let alone see one like this...
Its bigger than I wanted ... but I'm still dealing ...
Its not a molded fiberglass unit ... seems the roof is but the
sides look like a stick camper???
Looks like they took the molded top and stretched it from the front to the
back.. back, top and front of unit down to hitch look molded?
sides look like any stick camper.
Has anyone heard of such a unit?
any insight wld be greatley appreciated
thanks
tim
ps: if this doesn't post well, its my first ever so please be patient!
have no idea what I'm doing
Tim Walliser is offline   Reply With Quote
Old 05-01-2010, 06:35 PM   #2
BobB's Avatar
Never heard of a Bigfoot like that.
BobB is offline   Reply With Quote
Old 05-01-2010, 06:51 PM   #3
Raya's Avatar
Tim,
The Bigfoot is out of my realm, but I wanted to say to FGRV. You've had a great cross-section of eggs!
Your post came through just fine
Raya
Old 05-01-2010, 07:05 PM   #4
Lizbeth's Avatar
I don't know much about them but Bigfoot did make a bigger "stick built" fifth wheel. I have seen pictures of one. Bigfoot also made bumper pull trailers, motorhomes, and truck campers of the same construction. Not all BFs are of molded construction.
Old 05-01-2010, 08:53 PM   #5
member
Trailer: Bigfoot Rear Queen 25 ft
It is much like a conventional 5th wheel. This is circa 1991
Time K is offline   Reply With Quote
Old 05-01-2010, 08:59 PM   #6
The last molded Bigfoot 5th wheel came out early 1994... then there was a fire and the molds were lost and haven't been remade to date... who knows what may happen when the company is totally resurrected?! Often times molded Bigfoot 5th wheels are considered 20 footers.. no bigger.
What you're looking at Tim ... is a "sticky." The only thing that makes it "rare" is Bigfoot isn't up and running (yet).
Old 05-01-2010, 09:52 PM   #7
Thanks to everyone, really appreciate all the info past and present.
I'm going to get a little crazy here and try and post a picture?
Old 05-01-2010, 10:07 PM   #8
so these are common? Lots of them around?
Old 05-01-2010, 10:08 PM   #9
Mike what is meant by "circa" ?
Old 05-01-2010, 10:47 PM   #10
Gina D.'s Avatar
Circa means "Around that time"
Old 05-02-2010, 07:08 AM   #11
If you're asking if it has added value because these may be "rare." IMHO I'd say no. It isn't considered a classic... like a Shasta, nor collectable like an early Airstream.
You may get more information at the Bigfoot Owners Group
Old 05-02-2010, 07:56 AM   #12
Roger H's Avatar
It's a "stickie" (conventional wood frame, metal side construction). There are probably a bazillion conventional fifth wheels out there in storage lots from the early-to-mid '90s. There probably aren't a lot of Bigfoot 5th wheels out there, because they had low production numbers, and there's probably a few more Bigfoot 5th wheels in the Pacific Northwet in the U.S. and Canada because the factory was there, but it's likely not worth any more than any other brand of 1994 "stickie" fifth wheel out there. Fifth wheels in general don't have the best resale, and they can be hard to sell used because it's a fairly narrow market.
Good luck with your negotiations!
Roger
Old 05-02-2010, 09:23 AM   #13
member
It could very well clean up nicely and you will have yourself a very nice rv that will give you years of service. If its dry (no leaks) I imagine the interior will be in very good condition. My estimate is this will be up around 10,000 lbs wet, do you have a tow vehicle capable?
Tim, it looks like its been idle for some time. What is the history on it?
Old 05-02-2010, 07:27 PM   #14
Thanks Donna, good info, was really looking to replace the Bigfoot with another Bigfoot. Only in a 5th wheel,thought it wld be better for pulling trailer + boat?
Also re: "Bigfoot Owners Group" ... forum. Not as good as FRV, IMHO. Don't want to bash, but this forum and all you folks have been great.. Again my opinion.
Old 05-02-2010, 07:41 PM   #15
Yes, Mike we didn't set out to buy something as heavy. He (seller) insists that it is 4100LBS. I'm thinking as you say 4100KG, 4100kg X 2.21 (kg) to pounds = 9060 LBS. So bingo, yr right on with yr estimate. The "Bigfoot" expert hat still applies. I think yr bang on she wld be a 10,000 LB pull.
And to answer yr question, do i have a tow vehicle capable.... NO. Especially with a boat behind???
He is asking $7,500.00, has no leaks, air, new awning etc etc. But I think she's too big for me.
Love the floor plan also!
Anyway thanks to all, really appreciate the info
Old 05-03-2010, 08:07 AM   #16
Had a look at that one on my ill-fated Bigfoot tour. Cut myself on the tires; there appears to be something seriously out of whack with the running gear. Also roof replaced 3 years ago?
Cam
Cam A is offline   Reply With Quote
bigfoot
1986 16' VT U-Haul For Sale - RARE Carolyn Patterson Classified Archives 24 09-20-2009 09:45 AM
Rare Boler 15 Foot (1500) donalie Care and Feeding of Molded Fiberglass Trailers 6 07-14-2009 07:50 AM
1996 Bigfoot 26 FW (Rare 5th wheel) Robert Stephan Classified Archives 4 05-13-2008 12:24 PM
Rare & Unusual Trailer Carol Christensen General Chat 33 11-26-2006 12:02 PM
Am I unusual or rare? sherman General Chat 5 03-26-2006 12:03 PM
» Trailer Showcase
Stitch
Robs
Scamper
Rodney
