I have a couple of questions.... - Page 2 - Fiberglass RV
Old 12-05-2013, 08:17 AM   #15
tractors1's Avatar
Trailer: Escape 21 - Felicity
I've never heard of a policeman carrying around a weigh scale to check trailer weights. I doubt they're in the business of trying to weigh your trailer - it would have to be pulled over on a flat spot, chocked, and uncoupled from the tow vehicle, plus they'd have to carry a scale with currently valid maintenance certification saying the scale is accurate to issue a citation. Either that or take you to a legal weigh scale station somewhere. I think that's WAY too much overhead....
Charlie Y
Old 12-05-2013, 08:25 AM   #16
cpaharley2008's Avatar
I think we are talking about 2 different numbers here, the actual weight of the trailer and what is the trailer's maximum weight. The maximum weight is normally the concern of the registration people as this determines the rate of tax to be imposed on vehicles using our highways. The weight of the vehicle is determined by having it weighed. Pleas look here for clarity Towing Definitions-Understanding Towing weight terms
Jim
Never in doubt, often wrong
Old 12-05-2013, 01:23 PM   #17
carlkeigley's Avatar
NE Oklahoma
It's been a while, but when I was driving, I ran across several DOT
agents with portable scales. Back then we ran with 2 or 3 log books,
so we might make a quick refreshment stop before we got to them,
if we had time that is. We used light and hand signals between truckers,
so we usually knew what was up ahead. Later on we got CB's. woohoo.
And then radar detectors..............that was when I began getting tickets.
Old 12-05-2013, 04:11 PM   #18
Mary Ann in MN's Avatar
Trailer: 1992 Scamp 13' Deluxe
Thank you all for the info.
Yes, we do have the DOT with the portable weight scales that they set up on hwy 53 in Northern Minnesota. I'm only about 4 blocks from the hwy. We have lots of truck drivers up here logging and hauling into the mines and doing construction. Every once in a while you see the scales here.
Mary Ann & Butch
1992 Scamp 13' Deluxe, 08 Trailblazer
2011 Schnauzer "Butch"
God's Country, Minnesota
Mary Ann in MN is offline   Reply With Quote
Old 12-05-2013, 05:12 PM   #19
Trailer: Homebuilt Teardrop
Just an FYI. In Minnesota if your trailer weights 3000 lbs or more and weighs more than your tow vehicle, you are required to have trailer brakes.
TPMcGinty is offline   Reply With Quote
Old 12-05-2013, 08:22 PM   #20
IllAnnoy
Originally Posted by Mary Ann in MN View Post
This is what I don't understand on my tab slip. Do all 13' scamps have this weight? Just what does that mean? A scamp weighs more then 1500#.
As far a the hitch goes, it looks like a factory install and is welded to the bumper.
Many Scamp 13s weigh less than 1500#, some even less than 1200#, some claim even less, In fact early Scamp13s came with a 1200# capacity axle.
Eggy-Sue is a 2004 Scamp13 deluxe with every single option offered (except the second propane tank) and she still leaves the house (trip loaded) under 2000#. 1700 on the axle.
The real problem with a rear hitch on a Scamp13 is that it is mounted below the bumper. The angle of departure is compromised as a result, and a rack like the one you pictured is likely to exacerbate the problem. If you use it, be particularly careful when entering or leaving such things as driveways gas stations and parking lots.
Old 12-05-2013, 10:49 PM   #21
Thanks Floyd
Mary Ann & Butch
First time out. Couple questions George Nagel General Chat 17 06-04-2013 07:56 PM
Continuing prep, a couple more questions glennco Care and Feeding of Molded Fiberglass Trailers 2 05-23-2013 06:03 AM
hello all....couple of questions about a big mod thenoob Problem Solving | Owners Helping Owners 14 09-17-2010 09:01 PM
DonnZ has a couple of questions DonnZ Problem Solving | Owners Helping Owners 3 05-27-2008 09:33 AM
A couple of Casita questions Lee Hillsgrove Problem Solving | Owners Helping Owners 17 06-26-2007 10:01 PM
