Solar tax credit - Page 3 - Fiberglass RV
Old 06-11-2015, 11:32 PM   #29
Cathi's Avatar
POBox 1267, Denison, Texas
A Maxx fan is one great fan that can help a lot in hot weather and we would not want a trailer without one. Can be run with solar.
Old 06-12-2015, 06:04 AM   #30
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Since everyone's usage is different, I don't know how much this helps, but my experience:
I started with a 95 watt panel (factory installed in my 2011 Escape 17). It was adequate when combined with a pair of 6V 232 amp hour batteries & LED lighting for summer camping. I added a 1000 watt inverter, and used it to make a pot of coffee each morning (about 6 amp hours). Overall, I averaged around 25 amp hours per day, a bit more when making coffee.
The panel put it back on clear summer days, but did not keep up on overcast days and definitely did not keep up with low angle winter sun combined with overcast. I added a 100 watt panel for a total of 195 watts & carry a 160 watt portable panel. I have not needed the portable so far. I don't carry a generator & have dry camped for 3 weeks at a time.
Old 06-12-2015, 06:27 AM   #31
cpaharley2008's Avatar
According to Internal Revenue Bulletin: 2013-47, the credit is only on your principal residence, not a second home, nor a vacation home. In addition you must reduce your basis in such property and recapture as a gain upon disposition that portion upon which the credit was claimed.
Jim
Never in doubt, often wrong
Old 06-12-2015, 06:29 AM   #32
trumpetguy's Avatar
Trailer: Airstream International CCD 28
Asking a question about solar opens a Pandora box that may take this thread in many directions. There are so many opinions, and experts on these forums that you will be more confused than ever after reading them. Oliver Trailers stock solar package is two 160 WATT panels. I opted for a 2000 WATT inverter, and four Trojan T 105 batteries which provide 450 AH. The installation is like everything else at Oliver...professional. Overkill? Perhaps, but this is our bug out trailer when we have hurricanes and need to evacuate, so I want lots of capacity. Oliver includes a 13500 BTU AC, and for that I carry a 3000 WATT generator. The batteries will not run the AC. Check these resources for more good information on solar. technomadia, AM Solar, Handy Bob.
The consensus seems to be that the 30% tax credit is applicable for RVs.
Good luck.
2007 Airstream International CCD 28
2016 Dodge Ram Sport 5.7 Hemi 4WD
trumpetguy is offline   Reply With Quote
Old 06-12-2015, 06:30 AM   #33
See post #31
Jim
Old 06-12-2015, 07:31 AM   #34
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Jon
That's the most specific I've seen yet and very helpful. Thanks.
Walt
Old 06-12-2015, 07:44 AM   #35
Trailer: Casita 17 ft DLX SD
Originally Posted by WaltP View Post
Problem with that argument is that you can forget using solar for AC or heat.
When you get your trailer you'll need 2,00 watts or close to it for the AC.
And even a small space heater will need about 1,000 watts.
Roughly the same range for a microwave, toaster, or coffee maker.
What solar is useful for is running your lights, which should be LEDs, the fridge control circuit, the fridge itself will be running on propane, water pump, electric element in the water heater if it has one, chargers for your electronics,.....did I forget anything?
Everyone I know of with a Casita finds that 100 watts solar is adequate for all of that. Maybe an Oliver needs more?
Walt
Tax credit or NO tax credit my 100 watt Renogy solar suitcase arrives today . Walt I am hoping you are correct about a Casita only needing 100 watts of solar because I was told by our local solar dealer that I needed 200 to 300 watts .
steve dunham is online now   Reply With Quote
Old 06-12-2015, 07:52 AM   #36
WaltP's Avatar
SW Virginia
Good luck with it Steve. Let us know how well it works for you.
Walt
Old 06-12-2015, 08:11 AM   #37
trumpetguy's Avatar
As I said earlier. "Opinions and experts abound when it comes to solar". IMHO the critical part of the system is battery capacity...not solar, although my 320 WATTS will harvest a small bit of PV even on cloudy days so more may be better.
With a 2000 pure sine wave inverter I can run the following: microwave, toaster oven, hair dryer, all lights (LED), Maxxair fan, stand alone fan, fridge. Not all at once, but I have had the toaster oven AND microwave on at the same time. With 450 AH in the batteries I can go several days without sunlight.
It is more efficient to run the fridge, water heater, and furnace on propane. There is virtually no way to run the AC off batteries, but I did read about a 'smart" inverter that will combine a generator with battery, which would allow one to use a smaller generator for the AC. When I owned a Casita I could use my Honda 2000i because it had a 9200 BTU AC, but the Honda will not work with a larger AC unit.
The make of the trailer is not important, but the usage pattern of the owner is. The good thing is that you can start small and add PV as needed.
Old 06-12-2015, 08:35 AM   #38
WaltP's Avatar
SW Virginia
Good summary David
I can see if you want all of the conveniences of shore power except the AC and want to run several appliances at the same time, that 300 Watts of Solar may be what's needed. I assume that's all roof installed and pretty well everyone I know with Casitas uses a suitcase set of 100 Watts. I still think that's a compromise I'd prefer if/when I go Solar.
On the AC note, I did replace my factory AC with a smaller 9000 BTU model so my Ryobi 1800 generator can run it if necessary. I didn't want to deal with the weight of a larger generator like the Yamaha 3400.
Walt
Old 06-12-2015, 09:21 AM   #39
We only camp a few times a year with out power and only for 2 to 3 days at a time . We are not concerned about running any 120 VAC appliances.
We live in Wisconsin so we often have to run the furnace in the morning and at night even in the summer. If we can keep the battery up to run our fan , led lights , refrigerator (on propane) and the furnace on occasion ,we will be happy. We have no desire to be able to run every appliance in the world when camping.
Old 06-12-2015, 06:11 PM   #40
WaltP's Avatar
SW Virginia
This just points out that we have a wild variety of camping styles, yet we have a warm, sharing community. And it's fun to hear about everyone's differing experiences. I've been more like Steve than Dave, but lately I've been drifting toward the middle. (Getting spoiled)
Walt
Old 06-12-2015, 09:55 PM   #41
Cathi's Avatar
Yes, the form says it is for the main home only and cautions that you only have one main home. So only full-timers need apply.
Old 06-13-2015, 04:56 AM   #42
Pam Garlow's Avatar
Trailer: U-Haul 1985
Nice basic information here. And much more out on the web
How to Choose Portable Solar Panels for Camping.
And lots of info on You Tube
solar
Canadian credit cards at U.S. gas pumps TonyB General Chat 29 12-28-2010 09:51 AM
10 Great Low-Tax Places to Retire Donna D. Fulltiming in a Molded Fiberglass Trailer 11 12-29-2008 12:03 PM
California Sales / Use tax Alan Weinel Money Matters 5 07-16-2008 08:00 AM
New carbon tax CharlynnT Money Matters 6 03-09-2008 03:42 PM
Washington Sales Tax for Non-residents Pete Dumbleton General Chat 6 02-27-2008 01:06 PM
