08-11-2018, 11:16 AM
Nevada
12 volt versus two 6 volt
Hi
Have a 2017 25’RQ Bigfoot trailer. Will be putting 320 watts (2 panels) on the roof. All the lights are led and we charge phones, laptops etc. We are not heavy energy users, but do have the refrigerator fan as well as heater fan (when needed) and water pump.
Do I put in a deep cycle agm 12 volt or two six volts wired in a series.
Thanks for your input.
08-11-2018, 11:54 AM
Originally Posted by Nvboatman
Hi
From what your are describing as your useage IMHO 320 watts is way more than you'll ever need. (I have 65 Watts, charge phones, laptop, etc and run LED lights and heater fan. Need to recharge about every 4 days when using the furnace, the battery is a group 24 Walmart 74amphour deep cycle battery (12Volt))
I suggest before you spend a lot of money on over kill you calculate usage. There are lots of articles about how to do that.
08-11-2018, 12:42 PM
Mid Left Coast
I've got dual golf cart batteries in my Escape 21, for a total of 12V 210AH, and a 160W solar system on the roof, my batteries are usually still at 90% when the sun comes up.
08-11-2018, 01:16 PM
done....
this topic has been done to death around here....
but to your particular situation....
the balancing act is: usage / production / storage.....change one number and you can change one or both of the other two....ad infinitum....the goal is the less dollars and less weight that meets your "usage" requirements
in your case you have a TON of "production"...(as long as you're parked in the sun)...so you could go light on "storage"....I guess....have fun figuring it all out.
08-11-2018, 01:25 PM
and as John says....
160 on the roof is "substantial"....if I were you, I'd buy just one of those two 160s you're planning on....and get a 50 or so portable with an extension cord to cover all your bases (parked in the shade)....I only pick 50 as a number because when you get close to 100 they get pretty big/hard to handle/store easily
Trailer: Casita SD
The two 6V golf cart batteries will give you much more storage capacity than any single 12V of reasonable size. If you have room for them it's an easy decision. Do the calculations of your usage if you are interested but nobody complains about having too much, production or storage.
08-11-2018, 03:00 PM
Trailer: Bigfoot 25 RT
Agreed.
No one complains because they have too much truck, too much solar power or too much battery capacity.
08-12-2018, 10:58 AM
Trailer: 16 ft Scamp
The semi-flexible solar panels are not very heavy. I just lay mine on the bed when on the road.
08-12-2018, 11:15 AM
I considered dual 6 volt batteries but I installed dual 12 volt batteries instead. My reasoning is with 2 six volt batteries, if one battery goes bad you don't have any power. With dual 12 volt batteries if one of the batteries goes bad you can disconnect it and still have usable power.
08-12-2018, 01:01 PM
Trailer: Roamer 1
Smith Valley, Nevada
Originally Posted by Ed Colorado
Agreed.
Usage over time will change as you are able to add more devices or want your cigarette lighter inverter on more of the time. You may add a stereo, a DVD player or other things to make life more fun or comfortable. Then the roof collectors may not be adjustable and will not produce their rated output, or you want to park in the shade sometimes or the collectors get partially shaded or dirty. Then you'll eventually camp in poor weather (that's when I like to go) and the output will be low. Don't count on the rated output of the collectors unless you use a portable setup on the ground that you clean and adjust properly all day.
It seems usage will always rise to meet capacity and capacity may not be what you calculate it "should" be.
Batteries will be much happier if they don't get discharged as deeply each time and if they spend more time in a fully charged state. They will slowly sulfate (especially if they are not repeatedly fully charged) which reduces their capacity. Ideally, they would get driven up to about 14.1 volts every day and rest at about 12.65. Not likely to happen. So, go with more instead of going with just enough. Try to figure in real world deficiencies that don't show up on paper. The whole system will serve you better over time if you allow for the things that make it imperfect.
08-12-2018, 01:45 PM
Trailer: Trillium Outback 2004
Portable Solar Panel
The 120W Go Power suitcase-style portable panel that I use with a 30 ft. cord only weighs about 25 lbs. Zippered suitcase with a handle and fits on the floor of the trailer when travelling. Keeps my 12V electric-only fridge running with two 12V batteries, for at least 3 days if there is no sun. All lights are LED. Haven't used the propane furnace with the fan with it yet.
The 30 ft. cord makes it easy to park my trailer in the shade and have the solar panel in the sun all day with a few adjusts so it's always facing the sun. The panel folds in half and comes with it's own built-in adjustable aluminum stand and charge controller. Not inexpensive, but very usable.
08-12-2018, 04:10 PM
Our experience has been if one battery goes bad the other one is bad also most of the time. But with 2 12 volt batteries you have a lot of capacity. We have a Casita with one battery and it will run out of juice at times if running the furnace. On our motor home we have never run out of juice but have had to replace both batteries when one goes bad since the other one is also. So the idea of one bad battery leaves you one good one is not true a lot of the time.
08-12-2018, 04:36 PM
Trailer: Roamer 1
My truck has two starting batteries wired in parallel. One went bad and would pull the other one down too.
Once I figured out which one was actually the bad one, I was able to take it out and run on the other one until I could get new ones. I think it's best to replace both, but that's because they are the same age, not because they both fail at exactly the same time. If one shorts internally, it will drain the second one, but once isolated, you can keep going until it's convenient to fix it.
My Oliver has four batteries. Two banks of two each, wired in parallel. I'm just about to install a marine isolation switch so I can remove either of the two banks that have a problem simply by turning the switch.
08-12-2018, 06:46 PM
Parallel batteries might present different impeadance to the charging circuit and draw different currents, resulting in different charge levels.
Series batteries will, by definition, have exactly the same charging and discharging currents.
This is a good thing
08-12-2018, 07:40 PM
Well some people seem to have different ideas. I always assumed the purpose of small light weight trailers was to be frugal with stuff and expenses. But I guess that maximizing gives you bragging rights.
08-12-2018, 08:53 PM
yeah, what Byron said.....
some people buy Hummers to drive to the supermarket...
I never "calculated" my power use....but I got a pretty good feel for it after a few camping trips....then I fine-tuned (added to) the equation (use/production/storage)...given the way and where I used the trailer....and I only spent the money I needed to make it all work...for me.
Lots of fun figuring out this solar stuff...sometimes weight is a prime consideration...(use 10/hr, production 3, storage 32=16 usable)
08-12-2018, 08:57 PM
Originally Posted by Raspy
Usage over time will change ......
This is a huge thing, something that has most definitely happened to me. In my 2009 Escape 19 with no solar I [primarily used my dual 6V batteries for furnace fan and lights. I found the batteries got quite low after 3 nights of temperatures hovering around freezing, a situation quite typical to my camping. I did add a 70W portable that sometimes could keep up, sometimes not, but at least helped boost the batteries.
Fast forward to my 2017 Escape 5.0TA. I knew I was close to doing some really long trips and wanted to be able to do lots of boondocking, possibly for weeks on end. I chose to do solar and research and install myself. I settled on four 60W semi-flexible attached directly to the roof. I also now have an 80W portable, though have not had need to use in in 1 1/2 years, though have lent it out a few times. The biggest change is now that we use a few more 120V devices on the 1500W inverter I installed. My wife can use a hair dryer, I now bring hair trimmers to keep what I have nice and short, I have run a few tools, but the bestest thing yet is I bought a small 2-slice toaster which produces toast so much better than the dried out stuff from using a stovetop toaster. Oh, and I also charge my trolling motor with it too.
I love that I have absolutely no worries about not have enough battery power, or having to conserve a lot often meaning keeping the temperatures quite cold to minimize furnace fan usage. I think 320W is excessive for the OP's described needs as many have pointed out, but would bet in time he will find more uses for it to make his camping more pleasurable. I would also install the dual 6V for storage capacity. Is it needed, no. Is it nice to have if you can, you betcha!
2017 Escape 5.0 TA
2009 Escape 19 (previous)
08-12-2018, 09:06 PM
Trailer: Roamer 1
The way this problem is overcome is to put the charger + on one battery and the charger - on the other battery, with 12 volt batteries connected in parallel. This brings them to the exact same charge level. This allows equal charging and it allows one battery to be pulled out if it fails. It's not necessary to connect batteries in series to get the same charge level. And since batteries fail at different times, parallel 12 volt provides a fail/safe for temporary use.
I agree that both batteries should be replaced at the same time, but since they fail at different times, it gives a warning and a temporary condition to keep you going. Two 6 volt batteries don't give you that option. When one fails you have nothing.
08-12-2018, 09:23 PM
Trailer: Roamer 1
Well, this opens up a much bigger can of worms. For me, the purpose of having a small, lightweight trailer is for easy towing, the ability to camp in a much bigger number of areas, a far longer life trailer than a sticky and to have the maximum amount of fun with the minimum amount of stuff. Having extra battery power is a very nice convenience. In fact, for me, having fun conveniences, way out in the desert, or on a snowy night many miles from anywhere, is a fun bonus. if it's blowing snow, we might have movie night, for instance. Then getting up to a fine hot cup of coffee and producing a fabulous breakfast is fun. Evenings spent with new friends around a fire while sampling a fine wine and pulling a snack out of the fridge is excellent. In this modern world it's nice to be able to work on the computer, and have other electronic things along while enjoying the wild outdoors.
We may want to have music playing, or fix a flat tire on a bike or air up the trailer after a long rocky road, or have a propane fire pit going. BTW, during the last trip to Oregon all fires were banned. Across the state. Period. But not if they could be simply turned off. So out came the propane fire pit and we resumed the campfire fun. Then during the day, out came the bikes.
I'm a firm believer that camping should simply be fun. Whatever you want to bring along to satisfy that goal is fine.
08-12-2018, 09:55 PM
Trailer: Roamer 1
Jim,
I know exactly where you are coming from. I lived on a 42' Ketch for about 17 years and spent a lot of time "out". One of my decadent Sunday morning vices was making coffee with the electric coffee maker run on the inverter as I swung on the hook and took in the bright morning sun, birds working the mud flats and the current swinging us as the tide changed. Cold breakfast fixin's would come out of the compressor driven fridge and a fabulous meal would be built.
My favorite was an anchorage, out of the way and off the beaten path, that I would get to on a Saturday evening. Before leaving I was able to get a Sunday paper and hide it away. Then, Sunday morning with several other boats rafted up next to me, that had wandered out during the previous evening and had come alongside, I'd come out with a carafe of fresh hot coffee and a Sunday paper.
Being on a sailboat seems like a minimalist existence. Not so, if you don't want it to be. The fun is making your own private island into the most fun place there is. Small trailers are even easier to set up with all the things we might want, and making the trip fun means we'll want to do it again. It also means that after a long day of exploring, we can come home to a very comfortable place, have a good dinner and sleep comfortably. No roughing it around here! Where should we go next?
