12v wiring question - Fiberglass RV
Old 07-01-2012, 10:47 PM   #1
Trailer: 1978 Trillium 4500
12v wiring question
Hello all,
I have a WFCO 8945 converter / distribution panel. I'm trying to figure out how to wire in the 12v wire pairs.
See the picture of my panel below. The battery wires (black and red) are wired in as described in the the manual. I measured the correct voltage across those terminals both when the converter is operating and when the converter is off.
The terminals on the right, are for one side of each 12v circuit.
I measured the voltage between the 12v terminals on the right and point A ==> 12v. Between the 12v terminals on the right and point B ==> 0v.
One wire should go into the 12v terminals on the right, but I can't figure out where to hook in the other wire for each of these circuits.
Ideas?
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 07-02-2012, 12:42 AM   #2
GPJ
Trailer: Looking
To Ground? Aren't these systems wired with a hot side and a ground side?
GPJ is offline   Reply With Quote
Old 07-02-2012, 05:43 AM   #3
Is there a ground bar somewhere?
Something that looks like this picture (most likely smaller) and is connected to ground.
spotcatbug is offline   Reply With Quote
Old 07-02-2012, 06:06 AM   #4
cpaharley2008's Avatar
Follow the negative wire, there should be a ground bar pictured above for all your negative connections.
Old 07-02-2012, 09:01 AM   #5
Jim, Sherman,
In my panel, there is a 120V side , and an 12vDC side. The 120v side has a ground bar (green) and another bar ( white).
The 12v side does not have such a bar.
Anyone with a WFCO unit have an answer?
--Fred
Cheers
--Fred and Natalie
Old 07-02-2012, 10:25 AM   #6
When I did one there was a negative 12v buss connection. Try calling Randy @ Best Converter, he is the expert, 888-828-1893
12V wiring problems in 13' Burro Armymomma Problem Solving | Owners Helping Owners 5 05-01-2012 07:54 PM
Trillium trailer 12V wiring Rick G Care and Feeding of Molded Fiberglass Trailers 91 06-30-2011 08:03 PM
Need help with 12v fuse panel and wiring update Michael Collins Modifications, Alterations and Updates 15 03-27-2011 10:50 AM
Need guidance wiring 12v Distribution panel francene Problem Solving | Owners Helping Owners 13 11-02-2009 12:16 AM
1977 scamp interior light question/12v ? Flygal Problem Solving | Owners Helping Owners 6 06-18-2008 10:03 AM
