2 trailer power cord questions - Fiberglass RV
Old 01-13-2016, 06:15 PM   #1
Trailer: 2001 Scamp 16 layout 3
Question 2 trailer power cord questions
Scamp came with 25 foot cord. Is that enough typically? If I add a 25 foot 30 amp extension cord, which I would think you may need occasionally, what about the connection where they plug into each other in the rain? Lastly, has anyone ever needed more than 50 foot to reach the electric box?
denny w is offline   Reply With Quote
Old 01-13-2016, 06:32 PM   #2
IllAnnoy
In almost every case the 25ft cord is adequate. Your idea of carrying an extra 30A cord is a good one.
They make a solid connection with no real concern, but you could always put a plastic bag over the connection and secure it with duct tape.
I would avoid outright mud puddles where ever possible.
I have an extra 30A cord but seldom carry it. We do have a 12G regular extension cord and both adapters which we use when needed.
Be sure and get these adapters, they are cheap and you will need them at some point...
Old 01-13-2016, 06:45 PM   #3
Cathi's Avatar
POBox 1267, Denison, Texas
We have needed another cord many times. When we find we need it, however, we usually only need some. That means that they are connected and put under the trailer at the connection point.
Old 01-13-2016, 06:52 PM   #4
Trailer: Casita 17 ft DLX SD
We have an old plastic milk crate in which we haul wooden pads for our stabilizers and front trailer jack . When camping and the pads are being used , we turn the milk crate upside down and put the 30 amp cord connection on top of the plastic milk crate . It keeps the connection out of the dirt and water .
We have both a 25 ft. 12/3 and a 10/3 extension cord along with a 15 to 30 and a 50 to 30 amp adaptor.
Old 01-13-2016, 08:02 PM   #5
How can you put the connection under the trailer since the reason for the extension cord is because the first cord will not reach the box? If for example it is 35 feet to the box and you have two 25 foot cords the connection can not be under the trailer.
Old 01-13-2016, 10:27 PM   #6
librarianocnj's Avatar
Trailer: Casita Independence "Callimachusita"
Ocean City, NJ
I've been in two campsites where I needed almost 75 feet to reach both water and electricity.
Gordon and Anne
2010 Suzuki Equator "Suzi Q"
2015 Casita Independence "Callimachusita"
Pod Puppies: Josie and Frankie, Casita Kittens: Madison & Razzel & Mrs. Chow
librarianocnj is offline   Reply With Quote
Old 01-13-2016, 10:48 PM   #7
Cathi's Avatar
You could only rarely be 35' away out the side or back, but if we ever have been, never had a problem with it. One case is that you may have the box on the other side of the trailer from the cord, so you can put the connection underneath. Or you may have the box forward so that there is not enough length back to the permanent cord, then the connection can go underneath in that case also.
I guess we needed to have the connection out back or to the side at some time and rain was not a problem. You can look at how tightly connected the cords seem to be. Ours seem to be so tight such that it does not appear that water can get in. If it looks as if it will on yours, you can always use a bag. Since you have not seen the connection point yet, it may not be the problem you think. There is a lot of surface connection there.
Old 01-14-2016, 04:41 AM   #8
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
I carry a little less than 50 feet of cord in the trailer (the Casita has about 20' of cord outside the trailer and I add one 25' extension) and usually, if I remember, toss in another 25’ cord. I have used it (the second extension) about once every other year or so. I use more than 25' of cord once or twice each season so I have the on-board extension connection outside the trailer frequently.
I don’t carry a normal extension cord because we’re talking voltage loss due to length and I want the 10 gauge wire they use in the RV 3 blade extension cords. Voltage loss is wearing on A/C compressors and I do use the A/C whenever I think I’d like it.
I used to just put a branch or stone under the cord joint but I rarely bother now. Electricity will take the least resistive path to ground which would be the ground wire in the cord. Worst case would be, I suppose, the wire shorts to the puddle but I don’t see it getting all the way to wherever I’m standing.
I wouldn't, however, immerse the cord joint in a filled kiddy pool and step in.
Quando omni flunkus, moritati
Steve L. is online now   Reply With Quote
Old 01-14-2016, 09:13 AM   #9
Quartzite
What dates and where is the quartzite gatherer ing? I want to join you there
Brentsdeal is offline   Reply With Quote
Old 01-14-2016, 10:15 AM   #10
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
Check here. And here.
Old 01-14-2016, 12:02 PM   #11
John Linck's Avatar
Madison, Wisconsin
I carry two cords. One 25 and one 60 feet. Both are lighter weight 12 gauge. We seldom plug in at all with solar, but if so the 25 is nearly always adequate. I think we used the 60 one time in the past two years and could have chosen a different site had I not had the longer cord or used propane instead of our little electric heater. We rarely carry a window AC and its rated at 5 amps, so the 12 gauge is fully adequate. On the other hand if you carry a microwave, coffeepot, hair dryer you may need the heavier 10 gauge, 30 amp cord.
I agree with Floyd in that if you avoid standing water a bit of rain will not be a problem with cord connections.
John
John Michael Linck - Toymaker
Subaru Outback 4 cyl cvt
John Linck is offline   Reply With Quote
Old 01-14-2016, 12:05 PM   #12
John Linck's Avatar
Madison, Wisconsin
Smile
Originally Posted by Steve L. View Post
[FONT=Calibri][SIZE=3]
Especially if the salt content of the pool has increased with frequent yellow additions from the kids.
Old 01-14-2016, 12:36 PM   #13
Trailer: Scamp 13 & TDI tugboat
Ohio
We've never needed more than the 25' cord and a 25' water hose at a regular campsite. If I did, I'd reposition the trailer or get a different site.
Cheers,
Jim C
FJ40Jim is offline   Reply With Quote
Old 01-14-2016, 06:07 PM   #14
Timber Wolf's Avatar
North Florida
We have not yet needed more than the Scamp's on-board cord in any of the State campgrounds (FL, GA, AL) we have stayed in to date. Still, I carry an extra 25 foot 10 GA 30 amp RV extension cord just because I have it. I bought three of these extension cords and a 30/20 amp adaptor at an abandoned storage sale several years back for $20.
Shore-power connector replaces pull-out cord peterh Modifications, Alterations and Updates 72 12-18-2016 11:43 AM
Sealing the Power Cord Door when in use Keith Williams Care and Feeding of Molded Fiberglass Trailers 21 09-29-2009 11:47 AM
Lost my power cord cover Kevin K General Chat 8 07-06-2009 10:53 AM
Fusing question for main power cord Parker Buckley Problem Solving | Owners Helping Owners 25 03-21-2009 07:55 PM
Power cord hatch/door Legacy Posts Electrical | Charging, Systems, Solar and Generators 11 10-17-2002 05:46 AM
