24 volt solar panels - Page 2 - Fiberglass RV
Old 02-20-2014, 11:33 AM   #15
Trailer: Trillium Outback - 2004
As long as you're using an MPPT controller there would be no problem using a higher voltage panel so long as the voltage is within the spec of the controller and the controller can charge a 12v system. This is actually the preferred way to use an MPPT controller. I use a 215w panel that sits around 42.5v.
Where we’re going, we don’t need a plug-in.
multi-task is offline   Reply With Quote
solar, solar panel
Two 6 volt vs. 12 volt deep cycle kevin242 Electrical | Charging, Systems, Solar and Generators 15 05-13-2017 09:52 AM
110 volt and 12 volt on the same switch? Chris Jones Modifications, Alterations and Updates 46 04-04-2013 01:36 PM
Making portable solar panels less annoying Gina D. Modifications, Alterations and Updates 26 05-31-2009 11:06 PM
Chinese Solar Panels Lisa H. Care and Feeding of Molded Fiberglass Trailers 10 05-31-2009 12:05 AM
Initial testing of solar panels on the boler kevin61 Modifications, Alterations and Updates 11 02-24-2009 01:34 PM
