2d battery or 2d panel? - Page 2 - Fiberglass RV
Old 06-01-2015, 06:54 AM   #15
MCDenny's Avatar
Trailer: Lil Snoozy
Summer vs winter makes a huge difference.
Denny Wolfe
www.wanderingourway.wordpress.com
MCDenny is offline   Reply With Quote
Old 06-18-2015, 06:44 AM   #16
Night Sailor's Avatar
Connecticut
The rule of thumb is one watt of Solar for every AH of battery capacity. After months of study I found the number to be 1.5 Watts of solar (or more) for every AH in cloudy areas.
My goal was to recover a full charge on a bright overcast day. I know get 1-2 Amp of charge-- not much, but something, on dark heavy rain days. In this case it doesn't matter where your panels are pointing.
My point being that while there is a rule of thumb, someone full
Timing in a camper will always appreciate extra charging capabilities. Extra panels don't hurt.
Finally while I have a mix of flexible panels and rigid. The rigid are slightly more efficient charging, and provide shade for my camper, at the expense of increases wind drag while moving.
One 100 watt panel should provide for your Engel fried/ freezer and another for the house loads with the surplus helping with the fridge. 200 Watts of panels and 200 AH @ 12V for the batteries. Add an extra solar panel in a cloudy area. Leave room to expand as power is addictive and will prolong your battery life.
Old 06-18-2015, 06:57 AM   #17
Timber Wolf's Avatar
North Florida
That fits well with what I surmised last year when studying this issue. I finally came up with the "double everything" rule of thumb. It starts with the batteries. Since you don't want to go below 50% charge, you need twice the battery capacity right off. Cloudy days or poor panel orientation, you might need twice the panels calculated. And so forth. In any event you pays your money and takes your chances. Luckily most of us don’t start out camping weeks on end and depending on a system right off. Most can ease into things with a possibly too small setup and still get by for a few days until they learn their actual usage and needs.
Old 06-18-2015, 07:21 AM   #18
Larry,C's Avatar
Trailer: Casita 17 LD
Kentucky
Of course it depends on where you plan to camp and the weather and your energy needs. With conservative use you should be able to get by with 100 watt solar panel and 1 - 12 volt battery. If you depend on your battery for your electricity (boon docking for more than a couple of days) I recommend additional battery/s. If you go with a permanent panel installation I recommend additional panels because they will not always be in an optimal position to catch the sun. I have set mine up for any conditions. 2 - 6 volt golf cart batteries with 3 - 100 watt panels and 2 - 50 watt panels fixed and oriented in different directions to be able to collect some energy no matter how or where I park. So far I have had enough electricity to meet my not so conservative consumption needs.
Visit Beetlefreak.com to see our complete line of Casita latches and other interesting items.
Larry,C is offline   Reply With Quote
battery
Battery / Solar Panel voltage and current dleverton Electrical | Charging, Systems, Solar and Generators 4 05-14-2015 01:34 PM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
A Battery Where No Battery Has Gone Before Denece Care and Feeding of Molded Fiberglass Trailers 26 01-22-2012 01:20 PM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
Hooking up boler battery to Tug battery Andy H Problem Solving | Owners Helping Owners 3 08-02-2007 12:59 PM
