77 trillium blows breaker inside trailer when trying to make a Keurig coffee. - Fiberglass RV
Old 06-17-2019, 06:53 PM   #1
What needs to be done as most sites we visit are 30 amp and I cannot do anything inside. Is there easy fixes for this?
agreco is offline   Reply With Quote
Old 06-17-2019, 07:54 PM   #2
John in Michigan's Avatar
agreco, if you have the original power center and you are only running the coffee maker when the circuit breaker pops, the push button AC breaker is probably worn out. Just replace it.
Trillium 4500 Journal
http://www.fiberglassrv.com/forums/f...nal-81345.html
Old 06-17-2019, 08:19 PM   #3
Trailer: 2013Escape 21
Iowa
Bad Breaker
Id say Jon is 99 % right. Two other very slim possibilities are a bad plug in where the kureig plugs in or an actual problem with a short in the coffee maker . I say this because once I had a pavilion rental by a high school athletic director and he tripped 8 breakers with a nacho cheese warmer and then called us very upset with our electrical service. We went on site and reset the breakers and he tripped five more. His custodian showed up and just laughed at the AD and told him hed have never made it as a custodian. He was not too bright.
Iowa Dave
Iowa Dave is offline   Reply With Quote
Old 06-17-2019, 08:36 PM   #4
The little white reset button can be replaced have never done that
Old 06-18-2019, 09:04 AM   #5
The little what reset button tells me it's a GFI plug? Or are you talking about on the Keurig? If on the possible GFI, I'm 99.99% it's simply worn out. I have one in my garage and the kitchen. What I've experienced is that when the one in my garage wore out, it simply tripped and would not reset. And yes of course I replaced it.
If in doubt, take the Keurig out and plug it directly into "Shore" power or the campground's pedestal and try it.
Old 06-18-2019, 01:53 PM   #6
Where do I find it John.
Old 06-18-2019, 03:39 PM   #7
agreco, I replaced both the AC and the DC circuit breaker buttons. I found them at Amazon. I purchased the circuit breaker in the link below for the AC side:
"Blue Sea Systems Push Button Reset-Only CLB Circuit Breakers with Quick Connect Terminals"
https://www.amazon.com/Blue-Sea-Syst...76EQHE4YS&th=1
Old 06-18-2019, 06:19 PM   #8
Does this fit the trillium 77 electric original for size?
Old 06-18-2019, 09:01 PM   #9
agreco, for my 1978 Trillium 4500, the Power Center original AC push button circuit breaker was rated at 15 amps, and original DC push button circuit breaker was rated at 10 amps. I replaced both circuit breakers matching the original amperage ratings. I suggest you do the same, i.e., examine the original circuit breakers (may need to remove them) to determine the amperage ratings, then replace with circuit breakers matching original amperage ratings.
(Note: I have a 15 amp Power Center which connects to 15 amp shore power.)
Old 06-18-2019, 11:44 PM   #10
I have no electrical advice, but as a coffee snob perk it on a camp percolator. Any electrical advice for the bean grinder though ��
Jenn C is offline   Reply With Quote
Old 06-19-2019, 05:51 AM   #11
Jenn C, get a manual coffee grinder
I'm sure someone can recommend a manual coffee grinder, but you might need to start a new thread to get feedback...
Old 06-19-2019, 08:15 AM   #12
Somewhat interesting, my 6911 power center clearly states 72 watts 12V capacity = 6 amps. If you have the original incandescent bulbs, you will go over 72 watts quickly!!
Check my Trillium Project Page: https://www.facebook.com/Bills-1977-...dmin_todo_tour
Old 06-25-2019, 04:26 PM   #13
Montana
Here, Here!
LCH in Montana is offline   Reply With Quote
Old 06-25-2019, 05:33 PM   #14
Carol Ann in TO's Avatar
No need for electricity. Lightweight and small.
Carol Ann in TO is offline   Reply With Quote
trillium
Trying to make a decision...Help! papa-t Towing, Hitching, Axles and Running Gear 34 03-05-2013 09:46 PM
How do you make Coffee? bill&sandra Camp Cooking, Food & Recipes 303 06-13-2012 12:13 AM
Husband blows up 5th wheel & wife with homemade cannon Matt in SV General Chat 13 03-08-2012 11:31 PM
UHaul Running Lights Out/Fuse Blows on TV Kevin A Problem Solving | Owners Helping Owners 5 01-08-2012 10:09 AM
1991 16ft Scamp water heater blows black smoke Janine & Jim Problem Solving | Owners Helping Owners 2 10-23-2007 02:26 PM
