12-09-2012, 06:56 PM
#21
Have you tried a different meter?
12-09-2012, 07:03 PM
#22
Originally Posted by glamourpets
The more stuff you turn on, the lower it drops. The defroster, for example seems to drop the voltage about 0.3volts. A smart charger should see the drop and turn up the alternator output. I'm not seeing that.
That's puzzling. The way to know for sure would be to put an ammeter in series with the battery.
Also, I know an alternator will produce more power at higher RPMs. At highway speed, voltage is still low.
Derek
More amps at higher rpms, but even at idle it should charge adequately. The alternator is sized to maintain charge even when idling for long periods like police, soccer moms, etc.
12-10-2012, 12:12 AM
#23
Trailer: 1984 19' scamp
Kansas
Define "voltage gauge", and why are you measuring at a cigarette lighter? Get a good meter and check at the battery, running and not running. Personally, I stick to fluke meters.
12-10-2012, 07:09 AM
#24
Originally Posted by Bob Miller
Sooooo the real question is "Why is my cars cigarette lighter output voltage reading low" correct?
Before answering here are a few points to consider:
1. If you plug the same gauge into the truck does it read higher? If not the gauge may be defective. I am not a fan of anything less than a "Voltminder" (voltminder.com) for accurately monitoring voltage at a plug connection.
2. You are saying "Cigarette Lighter". Most newer cars don't have a cigarette lighter but a "Power Outlet" or other similar name. These are not always the same as a cigarette lighter plug for 2 reasons: 1) They are not designed to withstand the heat generated by the end of a hot lighter element and, 2) As alternator voltage can spike up to well over 16 volts at startup, some (but not all) of these power outlets have the voltage limited/regulated/clamped to less than 13 volts to assure that you don't plug in an electronic device and damage it from over voltage. A look at your owners manual or a call to your dealer may provide more info on that possibility.
The gauge reads between 13.7 volts and 14.1 volts in the truck when the truck is running. The fluctuation is influenced by acessories turned on and engine RPM. This, to me, is normal. The car readings are significantly lower. Its the low readings that are of issue.
For what its worth, you cannot currently buy voltminders. If you click the buy it now button you can get more details.
Jared, if you would like to hide under the hood while I drive so we get better readings, I'm all for it. Just don't hold me responsible if you die during the process. A cigarette lighter gauge is imperfect, but it can give you readings on the go. Some fluctuations are normal. Battery charge, rpms, and acessories turned on have their influences.
If the alternator is failing, and only producing a portion of its rated capacity, that's a concern. If the alternator is ok but the voltage is filtered, that's good news. Anybody want to take bets on whether I arrive at xmas dinner by tow truck?
Derek
12-10-2012, 07:58 AM
#25
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
Nearly any automotive garage has a "meter" they can use to test your alternator and battery in about 5 minutes.
It's got an amperage meter they put in series with the positive cable to your battery and a HUGE adjustable load so they can watch your alternator in action.
It might be $15 or so to have them tell you what's going on using science!!!
12-10-2012, 11:03 AM
#26
Fluke meters are just a bit expensive. I might also add that they are named very ironically.
12-10-2012, 09:34 PM
#27
Trailer: '78 Trillium 4500
X2....
Or a different point of measuring your voltage other than the cigarette lighter?
Francesca
12-10-2012, 10:16 PM
#28
Trailer: Egg Camper
Oh boy....
No load voltage of a fully charged 12V battery is 12.65V. Charging voltage is specified as 13.8V to 14.2V, with a tolerance to 13.4V on the low end and 14.5V on the high end. Too high voltage and some systems shut down and accessories get damaged. Extended use below 13.4V the battery will not charge correctly and fails early (1-2 years instead of 5-7 years).
Measuring at the power outlet will be after a couple fuse panels and, on some cars, through a control module. So after a half dozen or more connections there can be a significant voltage drop.
[soap box]
How are you checking voltage at the cigarette lighter? It's just a heater coil with a handle that gets hot after being plugged into a power outlet for a few moments.
[/soap box]
And why do you have to drive the car to test the charging system? Attach a good DVOM or volt meter to the battery (I just threw mine out this morning as it was reading .5V low), start the engine and rev it up for about 5-10 seconds before letting it idle. Read the voltage with everything turned off (door shut? dome light?) at idle then at about 2000 to 2500 RPM. Turn on your lights (high beams), a/c fan high (and the a/c), rear window defroster, radio about 50% volume on a strong signal, bum heaters and such if you have them. Read voltage at idle and at 2000 to 2500 RPM. Let the voltage stabilize at both speeds before making your reading.
Now a well designed system in good condition will be able to keep above 13.5V with all those loads on with the RPMs up. A great system can do it at idle. If you get below 13V at idle or 13.3 at higher RPM you will have issues. If you don't think those loads are realistic - So Florida in slow traffic on a cold night will have lights, a/c to keep the humid air from fogging the windows, rear defroster to keep that window clear, heated seats to keep warm while a/c is keeping windows clear, wipers to clear the condensation on the outside (or in a cruel twist when it stars raining). Worst was Missouri though - defroster got the inside of the windshield clear just in time for the condensation build up on the outside.
Back to your regularly scheduled program,
Jason
12-10-2012, 11:48 PM
#29
Yup, John Fluke ironic.
12-10-2012, 11:52 PM
#30
Originally Posted by SilverGhost
Oh boy....
[soap box]
[/soap box]
Jason
Note Bold in Quote. If you use a high impedance voltmeter there voltage drop will be in milivolt range.
12-11-2012, 10:52 AM
#31
Trailer: Egg Camper
Assuming the control module is not regulating the voltage to a preset value.
And I doubt the type that you plug into the power outlet is very accurate or high impedance (also likely drawing power from the power outlet to operate). But handy for a quick look on overall system voltage.
Jason
12-11-2012, 07:55 PM
#32
Big first question - What is the tow vehicle? Make, model, year, options.
It it is a new or nearly new vehicle the source of the problem could be vastly different than if it is an older vehicle.
Did the problem just show up or has it been continuing?
Test, don't guess. Go to an auto parts store and have them run charging system diagnostics with their test set. It's quite impressive what the new test sets can do and most of them give a printout of test results. Remember, you don't have to buy anything. They all advertise that it is a free test. In most towns there are a few different auto parts store chains so drop by a few and get a second or third opinion.
The complexity of the current generation of cars/trucks is such that simple DC voltage tests can only show that there is a possible problem, not isolate it to a specific component or connection. If I was troubleshooting I would do a systematic test of the charging system and I would have a set of schematics to work from. And that would be after a trip to the local Advance Auto Parts store for that FREE in situ system test.
Trying to troubleshoot a problem (and I agree there is a problem) via remote consultation is doomed to failure. And it could be an expensive failure.
If I was a betting man I would bet that you have already spent money replacing a perfectly good battery by not thoroughly analyzing the problem.
12-12-2012, 06:06 PM
#34
A number of people have suggested that I should go to an automotive mechanic for a full diagnosis. Sadly, my experiences with mechanics has been less than positive.
A couple years ago, my truck failed its emmission test. They quoted $5000 to repace either the injectors or the fuel pump. I took the truck elsewhere. He did an oil change and air filters, and got a very good test pass score.
A few years earlier, I had a car break down at the beginning of a northbound road trip. I had the car towed to a mechanic. When I arrived at the shop, the mechanic said in his russian accent "Car is piece of sheet. Should have towed it to wrecker.". It was Friday, and I went home by bus. That evening I went online and did my research. On Saturday, I went in and fixed it myself. It was running as smooth as silk. The shop was closed on the weekend and the entrance was blocked. On monday I came back and told the mechanic I'd fixed the car and wanted to drive it home. He was totally shocked. That day I earned his respect, and continued to go to him until he moved on to another industry.
I have other stories too, if you would like to hear them.
Sadly, showing up at a mechanic blind is foolish. You need your bullshit detector turned on so you can call them on their BS. I haven't serviced this car yet as we have only had it a few months. I have a referral from a good source, but sometimes referrals aren't guaranteed either.
Derek
12-12-2012, 06:16 PM
#35
A number of people have suggested that I should go to an automotive mechanic for a full diagnosis. Sadly, my experiences with mechanics has been less than positive..........
Derek
I agree with much of what you said. I think a least one person's advice was to go to an auto parts store like Auto Zone where they do free electrical tests. They can test your battery or alternator for free. Of course, they are hoping you will buy parts there, but you can take the free test results with a grain of salt and decide for yourself what to do .
12-12-2012, 07:12 PM
#36
Yes, this was suggested. Around here, I think Canadian tire will do these tests for you. The question is - am I willing to trust my alterator to someone who's primary job skill is looking up part numbers on the in house computer system. *sigh* it sounds mean to even say it. At least a mechanic, with the training and experience he accumulated to get his ticket, should know what he is doing. The challenge is finding a mechanic who applys his skills honestly.
Derek
12-12-2012, 07:24 PM
#37
Derek
Well...you have to start somewhere! And the tests suggested don't fall into the "rocket science" category...if you don't trust the results from the first Canadian Tire guy you take it to, go to the one across town and see if they get the same results there.
There's only so much we internet advocates can do/suggest- sooner or later you'll have to take the plunge and go to a real live person. Getting a simple test done first might better equip you to decide whether the possible mechanic in your future is whistling Dixie or giving you the straight scoop.
Knowledge is power!
Francesca
12-12-2012, 07:47 PM
#38
It does not take a rocket scientist to hook a volt meter to you alternator and tell you if it's producing 14Vs.
If it's producing less than 14 volts you need a new alternator.
12-12-2012, 08:26 PM
#39
Francesca
One of the things I was realizing today, as I pondered this problem- my trailer wiring may provide the answer I seek. The brake controller requires a direct connection to the battery. As I result, I have a connector inside the car cabin that gives direct access to the battery without even opening the hood. A battery needs at least 13 volts to charge. Ideally it should be getting 13.5 to 14 volts under driving conditions. If its not, either the alternator is dieing or the alternator is receiving incorrect output data. Either way there is a problem that needs to be corrected.
I will not get to this task for a few days as we are amidst the chaos of the christmas season. Only 10 days to go!
Thankyou to everyone for their wisdom on the subject. My posting style can be a little bit sarcastic. Sadly, in a world where a mechanic can earn commission by selling you extra parts you don't really need, it is worthwhile to do your research first. The whole "filtered cigarette lighter" idea floated earlier was something I had not even considered.
12-12-2012, 11:03 PM
#40
If only the world were so simple...
The alternator only produces anything if the regulator directs it to, and if any control logic that triggers the regulator is working, and if the wiring connecting those bits is intact.
As I said earlier, when my Focus stopped charging at the high rate, it was not the alternator:
Originally Posted by Brian B-P
My 2004 Ford Focus wasn't charging the battery properly, and I found that it never reached 14V. The problem turned out to be a bad connection in the wiring harness to the alternator: the Focus charging system is designed to work in two steps, dependent on various conditions, and the failed connection was keeping it from being switched into the higher-voltage stage. A replacement wiring harness fixed that. It runs as high as 14.2 V (measured at the lighter socket).
The required replacement wiring harness cost me about $50, which is a small fraction of the price of the alternator... and if I had replaced the alternator, it would not have fixed the problem.
