02-27-2012, 02:18 PM
Trailer: Boler B1300
Quebec
any idea for porch light ?
Hi, i need a porch light on my Boler '75, i want to have a flat surface on exterior (like airplane light). Any idea ??
Thank's !
02-27-2012, 06:32 PM
Trailer: Casita, previously u-haul ct13
Virginia
If you have a Walmart in Quebec, you can get for $10.97 outside motion sensor
LED light that runs on batteries and has a holder that sticks on the fiberglass.
It's in their camping dept. I know it's not a permenant solution but it works great.
Just an Idea.
02-27-2012, 06:36 PM
Trailer: 17.5 Bigfoot
02-27-2012, 07:19 PM
Trailer: '84 13' Scamp & '14 homebuilt Benroy Teardrop
Well, this one isn't quite flat, but I've contemplated putting this stainless steel beauty the side of my Scamp. Kinda spendy, but very classy looking I think. It's a deck light. It also comes in other colors that are a little cheaper.
Evergreen SS7011 Stainless Steel Surface Step Light - (Lighting, Electrical, & Tools)
Lil M.
Updates and improvements to LilScamper here
“When one tugs at a single thing in nature, he finds it attached to the rest of the world.” ― John Muir
02-27-2012, 07:21 PM
Trailer: 72 Boler American
Indiana
A cheap tap light and two pieces of Velcro.
02-27-2012, 08:04 PM
Originally Posted by Lil M.
I like/prefer the downward facing "full cut off" of this model. It lights the door area but not the sky. I've added it to my bookmarks. Thx Mark
02-27-2012, 08:32 PM
Trailer: U-Haul 1985
Thank's !
I have a round furnace vent next to my door and I don't have a propane furnace (how lucky!). So I removed the vent, and replaced it with a porch light for an Airstream trailer.
It is completely flush with the trailer when installed. I control it with a toggle switch just inside my door.
02-27-2012, 10:48 PM
The light Pam shows is just like the "hookup lights" used on the back of the cab of truck tractors. I just today found one in my barn in my light collection while looking for a tail light. Made by Grote or Signalstat. Only problem is that it requires about a 4" hole to recess it in. Some reefer truck boxes used a similar light inside on the ceiling, they had a replaceable bulb in them and were always a problem, then they came out with a sealed unit which was better, it mounted in a rubber ring and the wire plugged onto the back of it There are RV surface mount porch lights available. For our vintage teardrop I found at a car show/swap meet a round glass lens with chrome retaining ring to use as an outside light. No idea what it came off of, probably was a front parking light on some old car or truck. Bob
02-28-2012, 06:39 AM
Whatever is flat on one side will bulge out on the other side. Make sure your porch light backs into a cabinet, or you're liable to have a big ole pimple on the inside
02-28-2012, 07:05 AM
I have used these on several mods, as a step light and mounted higher as area light for night time hookups. LED low draw.
Superbrightleds.com- $6
I would not want to cut that big a hole in the side of my trailer for a recessed light!! Pam had the situation where she already had the hole and was able to come up with a good solution to fill it. I've had to do that with both the teardrop and the Uhaul, as in "what can I do to fix the previous owners butcher job and make it look like it belongs there?"
02-28-2012, 07:08 AM
Trailer: scamp 13
12 volt string lights.
02-28-2012, 09:53 AM
Trailer: Escape 17 ft Plan B
It took a bit of work, but I added a portion of a 16' waterproof LED strip light just under the awning of my Escape 17. I used the remainder of the strip to make up a bunch of overhead cabinet lights. I purchased the strip from Bulb America, but they are now available for less on ebay. The strip can be cut between every 3 LEDs and wired to a 12V supply.
03-02-2012, 01:22 AM
I didn't have to cut a hole, there was already a round hole from the furnace vent right next to my door. Since I don't have a propane furnace, no need for the vent. So rather than try to patch that hole, I just 'filled' it with the light. The furnace was in the lower part of my closet. I think that many of the 13footers have closets next to the door, which works fine for a recessed light.
04-14-2012, 12:29 PM
Quebec
Tx to everyone !!
I wanna tx everyone for your ideas...great !!
04-14-2012, 01:09 PM
Jon thats a great idea. Well done!
04-14-2012, 06:07 PM
Newfoundland & Labrador
Check out www.mercersmarine.ca for shipboard lights.
They are located in Clarenville, NL. They are a very reliable company and do mail orders. D.
04-15-2012, 09:01 AM
they have some good prices...
