Anyone Ever Install an RV (Roof) Air Conditioner Thermostat? - Fiberglass RV
Old 08-16-2016, 04:20 PM   #1
Bruce H's Avatar
Trailer: Bigfoot 25 ft RQ
I am talking about that would start and stop the fan as well as the compressor.
Old 08-16-2016, 07:11 PM   #2
Trailer: Escape 19
This company sells a kit for that:
Aftermarket Auto-fan Kits for Coleman RV Air Conditioners
I thought about getting one, because the first few trips with my Mach 8 it was difficult for me to sleep. I installed LHCs hush kit, but that does not help with interior noise. I must be getting used to the noise, though, because the last trip the air conditioner noise did not bother me.
My main concern with the kit is that the fan and compressor coming on together might be more of an issue than the fan running constantly and the compressor kicking on occasionally.
FlaGman is offline   Reply With Quote
Old 08-17-2016, 10:58 AM   #3
Trailer: 1999 Casita 17' SD
Ohio
There's a thread over on the CasitaForum about doing just that.
http://www.casitaforum.com/invboard/.../page__p__2059
You need to be a member.
Old 08-17-2016, 12:11 PM   #4
Bruce, I did that EXACT thing and it was based on another poster's suggestion as the original idea came from a Casita member that did this. I've used it for the past 5 yrs and it's REMARKABLE for controlling my Scamp's interior temp- heat OR cold! (I have the heat strip).
It starts and stops the entire unit which answers a recent poster on this topic about concerns doing just that. I even spoke with Coleman as my unit is the 9200 BTU Coleman Cub series. They said they now install units with digital thermostats that have the option (like my central unit and room A/Cs) where you can start/stop the entire unit and it wont hurt it. Again, I have 5 yrs proof!
I'm sending a link to my flickr album that has even my wiring diagram but I take NO responsibility/liability for someone that may try to hook it up by my drawings and it fail.
One thing I DO want to mention is attention to the little fan that I actually place IN the thermostat. Without it, placing my Hunter at the end of the counter on the Scamp 13' was useless! The temps STILL varied greatly because there's simply a pocket of dead air there. Believe me, I've tested this for literal HOURS and proved it. The little fan solved it. Yes, you could move the thermostat, but you have to consider the relay, wiring etc that goes with this mod before you do...and where would you put it? I see you have a large BigFoot, so I'm thinking the location of your thermostat will be in a hallway and the air circulation will not be a problem!
Well..if you have any more questions, I'd be glad to try and answer them. This has been my most NECESSARY mod for comfort in the 13'. One final note- I use this setup on a generator and even on "Heat", it doesnt have ANY problems starting up- Champion 3500/4000.
https://www.flickr.com/photos/503516...57626806751813
Install an air conditioner yourself Myron Leski Care and Feeding of Molded Fiberglass Trailers 7 06-29-2015 09:43 AM
Coleman Mini Mach Roof Top Air Conditioner D Davis Classified Archives 2 05-15-2013 07:04 PM
Can a Boler take the weight of a roof air conditioner? dapple Care and Feeding of Molded Fiberglass Trailers 13 04-29-2013 06:10 AM
Boler Roof Air Conditioner? Plus some other questions! dapple Problem Solving | Owners Helping Owners 6 07-14-2012 12:02 AM
