Anyone Put Solar Panel on Tow Vehicle? - Fiberglass RV
Old 06-09-2014, 09:57 AM   #1
Trailer: ParkLiner
Virginia
On a small trailer, there is enough room for 1 panel. Maybe 2 if you install them crosswise.
So has anyone considered mounting one on your tow?
Obviously it only does you any good when it is hooked up to the trailer battery, but I'm guessing that is about 1/2 daylight time for many of us.
Huck is offline   Reply With Quote
Old 06-09-2014, 11:32 AM   #2
Timber Wolf's Avatar
North Florida
I had not consdiered a permanent installtion, but have thought about setting a portable rig on top of my camper shell on the tug. Would get it up off the ground and possibly oriented better on a tight campsite, the kind I prefer anyway. It helps that my shell is old and junky and I don't care if I scratch/dent it a little with a couple of "suitcase" panels.
Old 06-09-2014, 12:17 PM   #3
Trailer: 2004 trillium outback 13ft
Alaska
I have thought about this and look forward to the ideas. I thought about maybe mounting some rails on the canopy top for starters, then experimenting with tilting later. Parking where there is sunshine may be a problem as I'm often in the trees. Easily taking them off and moving them to the sun would be helpful.
Ak Ron is offline   Reply With Quote
Old 06-09-2014, 02:57 PM   #4
reeves99's Avatar
Trailer: Escape 13 /Hyundai Santa Fe
RVSUE did this. Google her blog. RV Sue and her Canine Crew
It's not the size.....
reeves99 is offline   Reply With Quote
solar, solar panel
Has anyone tried this to check a tow vehicle? DannyH Towing, Hitching, Axles and Running Gear 14 03-10-2015 01:27 AM
Solar Panels on Roof of Tow Vehicle rvsue Modifications, Alterations and Updates 17 02-11-2013 03:02 PM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
Tow Vehicle power to solar controller? dylanear Modifications, Alterations and Updates 1 07-28-2012 05:23 PM
Does anyone have a solar panel I can borrow? peterh Oregon Gatherings 5 05-05-2012 09:29 AM
